Gönderen Konu: [Çözüldü] Steam Oyundan Atma ve Donma Sorunu  (Okunma sayısı 8773 defa)
Çevrimdışı civan35
  • İleti: 9
  • Dağıtım: rafaela
  • Grafik Kartı: nvidia 840m
  • İşlemci: intel haswell
« : 17 Ekim 2015, 01:52:59 »
glmark2 2012.08
    OpenGL Information
    GL_VENDOR:     NVIDIA Corporation
    GL_RENDERER:   GeForce 840M/PCIe/SSE2
    GL_VERSION:    4.5.0 NVIDIA 346.96
[build] use-vbo=false: FPS: 635 FrameTime: 1.575 ms
[build] use-vbo=true: FPS: 1074 FrameTime: 0.931 ms
[texture] texture-filter=nearest: FPS: 817 FrameTime: 1.224 ms
[texture] texture-filter=linear: FPS: 860 FrameTime: 1.163 ms
[texture] texture-filter=mipmap: FPS: 853 FrameTime: 1.172 ms
[shading] shading=gouraud: FPS: 737 FrameTime: 1.357 ms
[shading] shading=blinn-phong-inf: FPS: 728 FrameTime: 1.374 ms
[shading] shading=phong: FPS: 701 FrameTime: 1.427 ms
[bump] bump-render=high-poly: FPS: 649 FrameTime: 1.541 ms
[bump] bump-render=normals: FPS: 1008 FrameTime: 0.992 ms
[bump] bump-render=height: FPS: 1078 FrameTime: 0.928 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 692 FrameTime: 1.445 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 476 FrameTime: 2.101 ms
[pulsar] light=false:quads=5:texture=false: FPS: 857 FrameTime: 1.167 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 377 FrameTime: 2.653 ms
[desktop] effect=shadow:windows=4: FPS: 471 FrameTime: 2.123 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 345 FrameTime: 2.899 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 406 FrameTime: 2.463 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 321 FrameTime: 3.115 ms
[ideas] speed=duration: FPS: 688 FrameTime: 1.453 ms
[jellyfish] <default>: FPS: 351 FrameTime: 2.849 ms
[terrain] <default>: FPS: 95 FrameTime: 10.526 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 838 FrameTime: 1.193 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 787 FrameTime: 1.271 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 857 FrameTime: 1.167 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 910 FrameTime: 1.099 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 869 FrameTime: 1.151 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 920 FrameTime: 1.087 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 927 FrameTime: 1.079 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 920 FrameTime: 1.087 ms
                                  glmark2 Score: 708
Şu değerler nasıldır? Linux Mint steam oyunlarında sorun yaşıyorum, kapalı kaynak sürücüleri yüklü daha doğrusu yüklüdür heralde, yöneticiden kurdum.
Düzenleme : İmla, Türkçe karşılıklar ve kod etiketi
driver => sürücü
manager => yönetici
« Son Düzenleme: 17 Ekim 2015, 14:11:20 Gönderen: civan35 »
Ynt: Steam Oyundan Atma ve Donma Sorunu
« Yanıtla #1 : 17 Ekim 2015, 08:25:14 »
Lütfen, yazım kurallarına elimizden geldiğince özen gösterelim. Forum Kuralları
Kapalı kaynak sürücü kurulu görünüyor. Steam ile ilgili ne sorun yaşadığınızı belitmemişsiniz. Bununla ilgili aşağıdaki komutların çıktılarını da paylaşarak Oyun bölümünde yeni bir konu açabilirsiniz.
« Son Düzenleme: 17 Ekim 2015, 08:29:40 Gönderen: Butterfly »
Çevrimdışı civan35
  • İleti: 9
  • Dağıtım: rafaela
« Yanıtla #2 : 17 Ekim 2015, 11:48:31 »
System:    Host: civan-HP-Pavilion-15-Notebook-PC Kernel: 3.16.0-38-generic x86_64 (64 bit, gcc: 4.8.2)
Machine:   System: Hewlett-Packard product: HP Pavilion 15 Notebook PC version: 0976100000405F10000610180
           Mobo: Hewlett-Packard model: 2281 version: 77.35 Bios: Insyde version: F.34 date: 12/19/2014
CPU:       Dual core Intel Core i5-4210U CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9577.76
           Clock Speeds: 1: 2303.625 MHz 2: 2236.875 MHz 3: 2400.00 MHz 4: 2402.625 MHz
Graphics:  Card: Intel Haswell-ULT Integrated Graphics Controller bus-ID: 00:02.0
           X.Org: 1.15.1 driver: nvidia Resolution: [email]1366x768@60.0hz[/email]
           GLX Renderer: GeForce 840M/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 346.96 Direct Rendering: Yes
Audio:     Card-1: Intel Lynx Point-LP HD Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Card-2: Intel Haswell-ULT HD Audio Controller driver: snd_hda_intel bus-ID: 00:03.0
Network:   Card-1: Realtek RTL8101E/RTL8102E PCI Express Fast Ethernet controller
           driver: r8169 ver: 2.3LK-NAPI port: 4000 bus-ID: 09:00.0
           Card-2: Broadcom BCM43142 802.11b/g/n driver: wl bus-ID: 08:00.0
Drives:    HDD Total Size: 750.2GB (3.2% used) 1: id: /dev/sda model: HGST_HTS541075A9 size: 750.2GB
Partition: ID: / size: 680G used: 23G (4%) fs: ext4 ID: swap-1 size: 8.52GB used: 0.02GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 62.0C mobo: N/A gpu: 0.0:54C
Info:      Processes: 215 Uptime: 10:30 Memory: 1813.3/7915.1MB Runlevel: 2 Gcc sys: 4.8.4
0a:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 840M] (rev a2)
ii  nvidia-346-updates                          346.96-0ubuntu0.0.1                                 amd64        NVIDIA binary driver - version 346.96
ii  nvidia-cuda-dev                             5.5.22-3ubuntu1                                     amd64        NVIDIA CUDA development files
ii  nvidia-cuda-toolkit                         5.5.22-3ubuntu1                                     amd64        NVIDIA CUDA toolkit
rc  nvidia-libopencl1-346-updates               346.96-0ubuntu0.0.1                                 amd64        NVIDIA OpenCL Driver and ICD Loader library
ii  nvidia-opencl-icd-346-updates               346.96-0ubuntu0.0.1                                 amd64        NVIDIA OpenCL ICD
ii  nvidia-prime-applet                         1.0.3                                               all          An applet for NVIDIA Prime
ii  nvidia-profiler                             5.5.22-3ubuntu1                                     amd64        NVIDIA Profiler for CUDA and OpenCL
ii  nvidia-settings                             346.72-0ubuntu1                                     amd64        Tool for configuring the NVIDIA graphics driver
Section "ServerLayout"
    Identifier "layout"
    Screen 0 "nvidia"
    Inactive "intel"
    Identifier "intel"
    Driver "modesetting"
    BusID "PCI:0@0:2:0"
Section "Screen"
    Identifier "intel"
    Device "intel"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:10@0:0:0"
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
Çok fazla forum kurallarını bilmediğimden buraya açtım, özür dilerim. Öncelikle cinnamon arayüzü çok geç tepki veriyor, herhangi bir uygulama açtıgımda (mozilla,yazılım yöneticisi,steam,chrome ,vlc vs. hemen hemen hepsinde ) ama benim için steamda oyunlarda takılmalar atmalar yaşıyorum. Ubuntu da böyle bir sorun yaşamıyordum, Windowsdan nefret ettiğimden kullanmıyorum. Ubuntuda Unıty arayüzü hoşuma gitmiyordu, Linux Mint arayüzü hoşuma gidiyor. =) Şimdiden teşekkür ederim.
    Identifier "layout"
    Screen 0 "nvidia"
    Inactive "intel"
    Identifier "intel"
    BusID "PCI:0@0:2:0"
Section "Screen"
    Identifier "intel"
    Device "intel"
    Identifier "nvidia"
    Driver "nvidia"
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
Bu kadar yapabildim özür dilerim, şimdiden steamda oyundan atma veya 3-4 dakikada donma yaşıyorum.
Düzenleme : Yazım kuralları
Lütfen yazım kurallarına ve noktalama işaretlerine özen gösteriniz.
« Son Düzenleme: 17 Ekim 2015, 13:01:44 Gönderen: Butterfly »
« Yanıtla #3 : 17 Ekim 2015, 13:19:20 »
Sistemi Intel GPU ile açıp oturumu yeniden başlatınız.
Sonrasında aşağıdaki komut ile nvidia paketlerini sistemden kaldırınız.
sudo apt-get purge nvidia*
Ardından aşağıdaki şekilde sisteminizi güncelleyiniz.
Güncelleme Yöneticisi => Düzenle menüsü => Tercihler => Seviyeler kısmından 4. seviye güncellemeleri işaretleyiniz ve Yenile düğmesine tıklayıp Güncellemeleri Kur düğmesine tıklayarak sisteminizi güncelleyiniz.
Ardından, Güncelleme Yöneticisi => Görünüm menüsü => Linux çekirdekleri aracı yardımıyla 3.19.x serisi çekirdeğin son sürümünü (şu an itibariyle 3.19.0-30 sürümde) kurunuz.
Sistemi yeniden başlatıp aşağıdaki komutlar ile Nvidia'nın güncel sürücüsünü kurunuz.
sudo apt-get install nvidia-352 nvidia-settings nvidia-prime
Ayrıca buradaki düzenlemeyi de yapıp sistemi yeniden başlatmayı deneyiniz.
Cinnamon masaüstü için, Menü => Sistem Ayarları => Genel => "Tam ekran pencerelerde görüntü birleştirme (compositing) özelliğini pasifleştir" seçeneğini etkinleştirmeyi deneyebilirsiniz. Bu ayar ile sadece tam ekran çalışan uygulamalarda compositing pasifleşir ve bunun performans artışına katkısı olabilir.
« Son Düzenleme: 17 Ekim 2015, 13:21:22 Gönderen: Butterfly »
Çevrimdışı civan35
  • İleti: 9
  • Dağıtım: rafaela
« Yanıtla #4 : 17 Ekim 2015, 13:56:11 »
Oldu teşekkürler. Forum kurallarını ihlal ettığim için özür dilerim tekrardan çözüldü problem dediklerinizin hepsini uyguladıkdan sonra =)
« Yanıtla #5 : 17 Ekim 2015, 14:06:12 »
[member=128]civan35[/member], rica ederiz. Sorun çözüme kavuştuğuna göre, konu başlığını etiketlerseniz konuyu kilitleyebiliriz. Çözülen başlıkların etiketlenmesi hakkında
