System: Host: pc Kernel: 3.16.0-38-generic i686 (32 bit, gcc: 4.8.2)
Desktop: Cinnamon 2.6.11 Distro: Linux Mint 17.2 Rafaela
Graphics: Card: NVIDIA GM107 [GeForce GTX 750 Ti] bus-ID: 04:00.0
X.Org: 1.15.1 drivers: nvidia (unloaded: fbdev,vesa,nouveau) Resolution: 1360x768@60.0hz
GLX Renderer: GeForce GTX 750 Ti/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 346.72 Direct Rendering: Yes
[code]
[code]direct rendering: Yes
OpenGL renderer string: GeForce GTX 750 Ti/PCIe/SSE2
GL_NV_path_rendering, GL_NV_pixel_data_range, GL_NV_point_sprite, [code]
[code]04:00.0 VGA compatible controller: NVIDIA Corporation GM107 [GeForce GTX 750 Ti] (rev a2)
[code]
[code]Screen 0: minimum 8 x 8, current 1440 x 900, maximum 16384 x 16384
DVI-I-0 connected primary 1440x900+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1024x768 60.0 +
1360x768 60.0* 59.8
1152x864 60.0
800x600 72.2 60.3 56.2
680x384 60.0 59.8
640x480 59.9
512x384 60.0
400x300 72.2
320x240 60.1
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)[code]
[code]cat: /etc/X11/xorg.conf: Böyle bir dosya ya da dizin yok
