Gönderen Konu: [Çözüldü] "nss-myhostname not installed, please install it" Uyarısı hakkında  (Okunma sayısı 3805 defa)
Çevrimdışı dirent
  • İleti: 293
  • Grafik Kartı: Nvidia 8400GS
  • İşlemci: P4 3.2 GHz
Selam,
Forumu gezerken gördüğüm çözümleri ya da iyileştirmeleri be nde uygulamaya çalışıyorum.
Bir yerde
dmesg komutunun çıktısı istenmiş.
bu komutun oldukça uzun bir çıktısı var.
Ama en satılarında;
[   19.276662] input: gspca_zc3xx as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/input/input8
[   19.277207] usbcore: registered new interface driver gspca_zc3xx
[   19.277800] device-mapper: multipath: version 1.7.0 loaded
[   19.354724] snd_emu10k1 0000:01:01.0: Installing spdif_bug patch: SB Audigy 2 ZS [SB0350]
[   19.478551] MPU-401 device not found or device busy
[   19.481726] init: cups main process (549) killed by HUP signal
[   19.481757] init: cups main process ended, respawning
[   19.612981] snd_hda_intel 0000:04:00.1: Disabling MSI
[   19.613003] snd_hda_intel 0000:04:00.1: Handle VGA-switcheroo audio client
[   20.348065] init: failsafe main process (647) killed by TERM signal
[   20.435526] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:04:00.1/sound/card1/input9
[   20.436296] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:04:00.1/sound/card1/input10
[   20.436729] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:04:00.1/sound/card1/input11
[   20.437147] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:04:00.1/sound/card1/input12
[   21.144063] floppy0: no floppy controllers found
[   22.289326] r8169 0000:02:00.0 eth0: link down
[   22.289344] r8169 0000:02:00.0 eth0: link down
[   22.289577] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   22.521681] init: samba-ad-dc main process (846) terminated with status 1
[   22.893906] init: plymouth-upstart-bridge main process ended, respawning
[   23.663509] nvidia 0000:04:00.0: irq 44 for MSI/MSI-X
[   24.001114] r8169 0000:02:00.0 eth0: link up
[   24.001127] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   25.322209] init: plymouth-stop pre-start process (1511) terminated with status 1
[  855.510542] systemd-hostnamed[3118]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
[ 1192.594618] systemd-hostnamed[3232]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
[ 1978.051953] perf interrupt took too long (2501 > 2500), lowering kernel.perf_event_max_sample_rate to 50000
[ 2667.707407] systemd-hostnamed[3580]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
[ 5332.619192] perf interrupt took too long (5001 > 5000), lowering kernel.perf_event_max_sample_rate to 25000
[ 5718.156170] systemd-hostnamed[4481]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
[ 6998.691066] systemd-hostnamed[4942]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
yazmakta.
19.478551 ile başlayan satırda, bilgisayar açılırken aldığım ve şuradasorduğum sorunun yani MPU-401 hatası ile ilgili veri de var.
Bu kurmamı istediği şey nedir, neden kurmalıyım, ya da kurmalı mıyım?
Yardımcı olmanızı rica ederim.
Şimdiden teşekkürler.
« Son Düzenleme: 09 Aralık 2015, 00:41:20 Gönderen: dirent »
Bayılıyorum buraya
Çevrimiçi Danny
dmesg | grep MPU
çıktısına bakalım.
Çevrimdışı dirent
  • İleti: 293
Cevabınız için teşekkürler. Çıktı:
dmesg | grep MPU
Bayılıyorum buraya
Çevrimiçi Danny
Bununla ilgili bir kaç dağıtımın sayfasında hata kaydı açılmış ama elle tutulur bir çözüm yolu bulamadım, zannedersem ses sürücülerinde bir değişiklik yapmışsınız bu değişiklik bu çıktıyı vermesine sebep oluyor.
Çevrimdışı dirent
  • İleti: 293
Ses sürücülerinde bugün değişikliklik oldu biraz ama bu sorunu ilk kurulduğu günden beri alıyorum.
 İncelemek isterim derseniz size history de gönderebilirim.
"nss-myhostname not installed, please install it" konusu için ne düşünüyorsunuz?
Bayılıyorum buraya
Aşağıdaki komut ile libnss-myhostname paketini kurunuz.
sudo apt-get install libnss-myhostname
Ek olarak aşağıdaki komutun çıktısına bakalım.
uname -r
Çevrimdışı dirent
  • İleti: 293
Selam,
Kurulumun çıktısı:
  audacious-plugins audacious-plugins-data ladspa-sdk libaudcore3 libbs2b0
  libcue1 libqt5multimedia5 libsidplayfp libsoxr0 swh-plugins
  libnss-myhostname
0 paket yükseltilecek, 1 yeni paket kurulacak, 0 paket kaldırılacak ve 6 paket yükseltilmeyecek.
14,6 kB arşiv dosyası indirilecek.
Bu işlem tamamlandıktan sonra 61,4 kB ek disk alanı kullanılacak.
Alınıyor: 1 http://archive.ubuntu.com/ubuntu/ trusty/universe libnss-myhostname i386 0.3-6 [14,6 kB]
0 sn.'de 14,6 kB alındı (27,3 kB/s)
Önceden seçili olmayan libnss-myhostname:i386 paketi seçiliyor.
(Veritabanı okunuyor... mevcut 216125 dosya veya klasör yüklü.)
Açılmaya hazırlanan .../libnss-myhostname_0.3-6_i386.deb ...
libnss-myhostname:i386 (0.3-6) paketi açılıyor ...
libnss-myhostname:i386 (0.3-6) ayarlanıyor...
First installation detected...
Checking NSS setup...
libc-bin (2.19-0ubuntu6.6) için tetikleyiciler işleniyor ...
Bu noktadan sonra bitti. Kuruldu falan demedi ve uçbirim ekranı tekrar bir şeyler yazmaya hazır hale geldi.
İstediğiniz komutun çıktısı:
uname -r
3.16.0-53-generic
nss-myhostname şu an kurulu görünüyor.
İlaveten;
önerisi için,
sudo apt-get autoremovekomutunu uyguladım, o eski artıklar da gitmiş oldu.
Bu arada,
uname -r
3.16.0-55-generic
durumda.
Bu sorunu çözülmüş olarak işaretliyorum. Teşekkürler.
« Son Düzenleme: 09 Aralık 2015, 00:40:59 Gönderen: dirent »
Bayılıyorum buraya
