Gönderen Konu: Linux Mint 17.2 Cinnamon - Nvidia Ekranda Karelenme Sorunu  (Okunma sayısı 4679 defa)
Çevrimdışı akcan_80
  • İleti: 17
  • Dağıtım: Linux Mint 18 sarah
  • Grafik Kartı: Nvidia GTX 650 Ti Boost SLİ
  • İşlemci: AMD FX 6300
Merhabalar. 17.2 rafaela cinnamon 32 bit kullanıyorum. Ekran kartı asus nvidia gtx 650 ti boost. Sistem başladıktan 5-10 dk sonra karelenmeler başlıyor. Çözüm için ne yapabilirim.
Çevrimdışı akcan_80
  • İleti: 17
Ynt: Linux Mint 17.2 Cinnamon - Nvidia Ekranda Karelenme Sorunu
« Yanıtla #2 : 26 Aralık 2015, 18:57:13 »
inxi -SGx
System:    Host: nafuku-desktop Kernel: 3.16.0-38-generic i686 (32 bit, gcc: 4.8.2)
Graphics:  Card-1: NVIDIA GK106 [GeForce GTX 650 Ti Boost] bus-ID: 01:00.0
           Card-2: NVIDIA GK106 [GeForce GTX 650 Ti Boost] bus-ID: 08:00.0
           X.Org: 1.15.1 drivers: nvidia,nouveau (unloaded: fbdev,vesa) Resolution: 1920x1080@60.0hz
           GLX Renderer: GeForce GTX 650 Ti BOOST/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 352.63 Direct Rendering: Yes
OpenGL renderer string: GeForce GTX 650 Ti BOOST/PCIe/SSE2
    GL_NV_compute_program5, GL_NV_conditional_render,
nafuku@nafuku-desktop ~ $ lspci | egrep 'VGA|3D|Display'
01:00.0 VGA compatible controller: NVIDIA Corporation GK106 [GeForce GTX 650 Ti Boost] (rev a1)
08:00.0 VGA compatible controller: NVIDIA Corporation GK106 [GeForce GTX 650 Ti Boost] (rev a1)
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 476mm x 268mm
   1920x1080      60.0*+   59.9     50.0     60.0     50.0
   1680x1050      60.0
   1440x900       59.9
   1280x1024      75.0     60.0
   1280x960       60.0
   1280x800       59.8
   1280x720       60.0     59.9     50.0
   1152x864       75.0
   1024x768       75.0     70.1     60.0
   800x600        75.0     72.2     60.3     56.2
   720x576        50.0
   720x480        59.9
   640x480        75.0     59.9     59.9
   480x576        50.0
   480x480        59.9
DP-0 disconnected (normal left inverted right x axis y axis)
DVI-D-0 disconnected (normal left inverted right x axis y axis)
« Son Düzenleme: 26 Aralık 2015, 19:00:12 Gönderen: akcan_80 »
« Yanıtla #3 : 26 Aralık 2015, 19:06:22 »
Aşağıdaki komutu uçbirimde çalıştırıp, sistemi yeniden başlatmayı deneyiniz.
sudo nvidia-xconfig
Sonrasında aşağıdaki komutların çıktısına yeniden bakalım.
inxi -Gx
Çevrimdışı akcan_80
  • İleti: 17
« Yanıtla #4 : 26 Aralık 2015, 19:17:07 »
inxi -Gx
           X.Org: 1.15.1 driver: nvidia Resolution: 1920x1080@60.0hz
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 352.63  (buildmeister@swio-display-x64-rhel04-18)  Sat Nov  7 22:01:48 PST 2015
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
Section "Files"
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Identifier     "Keyboard0"
    Driver         "kbd"
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       28.0 - 33.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
    Identifier     "Device0"
    Driver         "nvidia"
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
« Yanıtla #5 : 26 Aralık 2015, 19:21:24 »
Yapılandırma dosyasını oluşturmadan önce nvidia ve nouveau (açık kaynak sürücü) birlikte etkinleşiyordu.
Sonrasında sadece nvidia sürücüsünün etkinleştiğini görüyoruz. Bu durumda sorunun nüksedip etmeyeceğini gözlemleyiniz.
Çevrimdışı akcan_80
  • İleti: 17
« Yanıtla #6 : 26 Aralık 2015, 19:27:47 »
Teşekkürler. Gözlemleyip sonucu paylaşırım.
720p yada 1080p çözünürlükteki videolar sanki daha kötü çözünürlükte. Windows ortamında izlediğim 1080p aynı video sanki 240p yada 360p kalitesinde aynı çözünürlükte değil. Sizce aynı görüntüye ulaşabilmek için ne yapabilirim?
« Son Düzenleme: 26 Aralık 2015, 20:03:36 Gönderen: akcan_80 »
« Yanıtla #7 : 26 Aralık 2015, 20:10:45 »
[member=596]akcan_80[/member], forumda aynı başlık altında birbirinden farklı soru ve sorunlar hakkında konuşmuyoruz. Bu konu başlığı altında Cinnamon sorunu hakkında devam edelim. Video sorunu için uygun bir forum bölümüne yeni konu açmanızı rica edelim.
Çevrimdışı akcan_80
  • İleti: 17
« Yanıtla #8 : 26 Aralık 2015, 20:24:34 »
Teşekkürler. Forum kurallarını ihlal etmek istemedim.
