Gönderen Konu: Nvidia Ekran Tazeleme Hızı (Hertz) Sorunu  (Okunma sayısı 6982 defa)
Çevrimdışı darkl0ve
  • İleti: 15
« : 14 Ocak 2016, 21:13:15 »
Arkadaşlar, Nvidia ekran kartında 75 hertz kullanamıyorum. Sadece 60 hertz var nasıl 75 yapabilirim?
Düzenleme : Yazım kuralları
Forum Kuralları
« Son Düzenleme: 14 Ocak 2016, 21:47:41 Gönderen: Butterfly »
Çevrimdışı darkl0ve
  • İleti: 15
Ynt: Nvidia Ekran Tazeleme Hızı (Hertz) Sorunu
« Yanıtla #2 : 14 Ocak 2016, 22:55:27 »
System:    Host: Mustafa Kernel: 3.16.0-38-generic x86_64 (64 bit gcc: 4.8.2)
           Distro: Linux Mint 17.3 Rosa
Graphics:  Card: NVIDIA GF108 [GeForce GT 430] bus-ID: 01:00.0
           Display Server: X.Org 1.15.1 drivers: nvidia (unloaded: fbdev,vesa,nouveau)
           Resolution: 1152x864@60.0hz
           GLX Renderer: GeForce GT 430/PCIe/SSE2
           GLX Version: 4.5.0 NVIDIA 352.63 Direct Rendering: Yes
OpenGL renderer string: GeForce GT 430/PCIe/SSE2
01:00.0 VGA compatible controller: NVIDIA Corporation GF108 [GeForce GT 430] (rev a1)
Screen 0: minimum 8 x 8, current 1152 x 864, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
VGA-0 connected primary 1152x864+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
   1024x768       60.0 +
   1360x768       60.0     59.8
   1152x864       60.0*
   800x600        72.2     60.3     56.2
   680x384        60.0     59.8
   640x480        59.9
   512x384        60.0
   400x300        72.2
   320x240        60.1
« Yanıtla #3 : 14 Ocak 2016, 22:59:56 »
Çözünürlük ile ilgili öneriyi denemediniz mi?
https://forum.linuxmint.net.tr/index.php?topic=5177.msg32952#msg32952
Çevrimdışı darkl0ve
  • İleti: 15
« Yanıtla #4 : 14 Ocak 2016, 23:04:37 »
Buyrun
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 346.72  (buildd@toyol)  Tue May 19 14:39:51 UTC 2015
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    Option         "Xinerama" "0"
Section "Files"
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Identifier     "Keyboard0"
    Driver         "kbd"
Section "Monitor"
    # HorizSync source: builtin, VertRefresh source: builtin
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "CRT-1"
    HorizSync       28.0 - 55.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
    Identifier     "Device0"
    Driver         "nvidia"
    BoardName      "GeForce GT 430"
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "CRT-1"
    Option         "metamodes" "1024x768 +0+0"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
« Yanıtla #5 : 14 Ocak 2016, 23:07:55 »
Şimdi sistemi yeniden başlatıp, Nvidia Ayar Yöneticisinden tazeleme hızını değiştirmeyi dener misiniz?
Çevrimdışı darkl0ve
  • İleti: 15
« Yanıtla #6 : 14 Ocak 2016, 23:13:06 »
malesef degişmiyor sadece 60 ve auto var :S
