Gönderen Konu: [Çözüldü] Ralink RT3070 surucu yukleme  (Okunma sayısı 5220 defa)
Çevrimdışı efe
  • İleti: 84
  • Dağıtım: linux mint 17.3
  • Masaüstü Ortamı: xfce
« : 10 Şubat 2016, 16:22:51 »
iyiakşamlar,
 Ralink RT3070 suruculu bir adaptor aldım uzerinde linux uyumlu diyor fakat mint 17.3 kurulu bilgisayar adaptoru gormuyor.yardımcı olurmusunuz?
« Son Düzenleme: 12 Şubat 2016, 19:23:45 Gönderen: efe »
Çevrimdışı efe
  • İleti: 84
Ynt: Ralink RT3070 surucu yukleme
« Yanıtla #2 : 10 Şubat 2016, 17:36:56 »
efe[member=1868]efe[/member] ~ $ inxi -SNx
System:    Host: efe Kernel: 4.2.0-27-generic i686 (32 bit gcc: 4.8.2)
           Desktop: Xfce 4.12.2 (Gtk 2.24.23) Distro: Linux Mint 17.3 Rosa
Network:   Card-1: NVIDIA MCP61 Ethernet
           driver: forcedeth port: d480 bus-ID: 00:07.0
           Card-2: Realtek RTL8192CU 802.11n WLAN Adapter
           driver: rtl8192cu usb-ID: 001-002
           Card-3:  Atheros TP-Link TL-WN322G v3 / TL-WN422G v2 802.11g [Atheros AR9271]
           driver: ath9k_htc usb-ID: 002-004
           Card-4:  Atheros TP-Link TL-WN322G v3 / TL-WN422G v2 802.11g [Atheros AR9271]
           Card-5:  Ralink RT2870/RT3070 Wireless Adapter
           driver: rt2800usb v: 2.3.0 usb-ID: 002-034
efe[member=1868]efe[/member] ~ $ lspci -nnk | grep -iA2 net
00:07.0 Bridge [0680]: NVIDIA Corporation MCP61 Ethernet [10de:03ef] (rev a2)
Subsystem: ASUSTeK Computer Inc. Device [1043:8234]
Kernel driver in use: forcedeth
efe[member=1868]efe[/member] ~ $ lsusb
Bus 001 Device 002: ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n WLAN Adapter
Bus 002 Device 014: ID 09da:000a A4 Tech Co., Ltd Optical Mouse Opto 510D
Bus 002 Device 003: ID 04d9:1603 Holtek Semiconductor, Inc. Keyboard
Bus 002 Device 004: ID 0cf3:1006 Atheros Communications, Inc. TP-Link TL-WN322G v3 / TL-WN422G v2 802.11g [Atheros AR9271]
Bus 002 Device 034: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Bus 002 Device 002: ID 03eb:0902 Atmel Corp. 4-Port Hub
efe[member=1868]efe[/member] ~ $ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: phy1: Wireless LAN
Soft blocked: no
Hard blocked: no
efe[member=1868]efe[/member] ~ $ sudo lshw -C network
[sudo] password for efe:
  *-network:0
       açıklama: Kablosuz arayüz
       physical id: 1
       bus info: usb@2:2.4
       mantıksal ad: wlan0
       serial: 00:27:19:f3:07:fc
       yapılandırma: broadcast=yes driver=ath9k_htc driverversion=4.2.0-27-generic firmware=1.3 ip=192.168.150.1 link=yes multicast=yes wireless=IEEE 802.11bgn
  *-network:1
       physical id: 2
       bus info: usb@1:1
       mantıksal ad: wlan2
       serial: 10:fe:ed:26:61:ce
       yapılandırma: broadcast=yes driver=rtl8192cu ip=192.168.1.105 multicast=yes wireless=IEEE 802.11bg
  *-network:2 ETKİSİZLEŞTİRİLDİ
       physical id: 3
       bus info: usb@2:2.3
       mantıksal ad: wlan1
       serial: 00:25:22:4e:51:a9
       yapılandırma: broadcast=yes driver=rt2800usb driverversion=4.2.0-27-generic firmware=0.29 link=no multicast=yes wireless=IEEE 802.11bgn
efe[member=1868]efe[/member] ~ $ iwconfig | grep Power
mon.wlan0  IEEE 802.11bgn  Mode:Monitor  Tx-Power=20 dBm
          Power Management:off
wlan0     IEEE 802.11bgn  Mode:Master  Tx-Power=20 dBm
          Mode:Managed  Access Point: Not-Associated   Tx-Power=0 dBm
efe[member=1868]efe[/member] ~ $ lsmod
rt2800usb              28672  0
rt2x00usb              20480  1 rt2800usb
rt2800lib              86016  1 rt2800usb
rt2x00lib              49152  3 rt2x00usb,rt2800lib,rt2800usb
crc_ccitt              16384  1 rt2800lib
drbg                   28672  1
ctr                    16384  3
ccm                    20480  3
8021q                  24576  0
garp                   16384  1 8021q
mrp                    20480  1 8021q
stp                    16384  1 garp
llc                    16384  2 stp,garp
ipt_MASQUERADE         16384  1
nf_nat_masquerade_ipv4    16384  1 ipt_MASQUERADE
iptable_nat            16384  1
nf_conntrack_ipv4      16384  1
nf_nat_ipv4            16384  1 iptable_nat
nf_nat                 24576  2 nf_nat_ipv4,nf_nat_masquerade_ipv4
nf_conntrack           94208  4 nf_nat,nf_nat_ipv4,nf_nat_masquerade_ipv4,nf_conntrack_ipv4
ip_tables              20480  1 iptable_nat
x_tables               24576  2 ip_tables,ipt_MASQUERADE
arc4                   16384  4
rfcomm                 65536  0
bluetooth             454656  10 bnep,rfcomm
snd_hda_codec_analog    16384  1
snd_hda_codec_generic    69632  1 snd_hda_codec_analog
8192cu                475136  0
snd_hda_intel          32768  5
snd_hda_codec         114688  4 snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel,snd_hda_codec_analog
ath9k_htc              69632  0
ath9k_common           36864  1 ath9k_htc
ath9k_hw              454656  2 ath9k_common,ath9k_htc
snd_hda_core           57344  5 snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_hda_codec_analog
ath                    24576  3 ath9k_common,ath9k_htc,ath9k_hw
mac80211              647168  4 rt2x00lib,rt2x00usb,rt2800lib,ath9k_htc
snd_pcm                94208  4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_core
kvm_amd                57344  0
cfg80211              471040  5 ath,ath9k_common,mac80211,rt2x00lib,ath9k_htc
kvm                   442368  1 kvm_amd
snd_timer              24576  2 snd_pcm,snd_seq
amd64_edac_mod         32768  0
edac_core              49152  2 amd64_edac_mod
scsi_dh                16384  1 dm_multipath
snd                    69632  21 snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device,snd_hda_codec_analog
edac_mce_amd           24576  1 amd64_edac_mod
k8temp                 16384  0
i2c_nforce2            16384  0
asus_atk0110           20480  0
lp                     16384  0
dm_region_hash         16384  1 dm_mirror
hid_a4tech             16384  0
hid                    98304  3 hid_a4tech,hid_generic,usbhid
radeon               1433600  3
i2c_algo_bit           16384  1 radeon
ttm                    86016  1 radeon
drm_kms_helper        114688  1 radeon
drm                   303104  6 ttm,drm_kms_helper,radeon
forcedeth              61440  0
sata_nv                24576  2
floppy                 61440  0
pata_amd               16384  0
« Yanıtla #3 : 10 Şubat 2016, 20:46:18 »
Şu an sürücüler kurulu ve etkin görünyor, ama ilgili aygıt pasifleştirilmiş. Aşağıdaki komutla etkinletirmek denenebilir.
sudo rfkill unblock all
Sorun çözülmezse çıktıları diğer USB aygıtları takılı olmadığı halde alıp yeniden paylaşınız.
Çevrimdışı efe
  • İleti: 84
« Yanıtla #4 : 11 Şubat 2016, 15:43:12 »
son komutu denedim fakat hala adaptor gorunmuyor.daha dogrusu surekli baglanıp kapanıyor.saniyede iki defa baglanıp kopuyor.
« Yanıtla #5 : 11 Şubat 2016, 17:55:41 »
Aşağıdaki komutu uçbirimde çalıştırıp sistemi yeniden başlatmayı deneyiniz.
echo "options rt2800usb nohwcrypt=1" | sudo tee  /etc/modprobe.d/rt2800usb.conf
Çevrimdışı efe
  • İleti: 84
« Yanıtla #6 : 12 Şubat 2016, 08:05:53 »
buda olmadı,hala gorunmuyor.surucusunu yuklemeyi denesek faydası olurmu ?nasıl yuklenir tam olarak yazarsanız.
« Yanıtla #7 : 12 Şubat 2016, 09:46:29 »
Bu aygıtın sürücüsü çekirdek ile geliyor, ayrıca bir sürücü kurmaya gerek olacağını sanmıyorum. Aşağıdaki komutun çıktısını paylaşırsanız, güncel bir çekirdeği elle kurmayı deneyelim.
Olmazsa buradaki öneriyi deneriz.
Çevrimdışı efe
  • İleti: 84
« Yanıtla #8 : 12 Şubat 2016, 14:58:08 »
efe[member=1868]efe[/member] ~ $ inxi -Fxz
Machine:   Mobo: ASUSTeK model: M2N v: Rev 1.xx
           Bios: American Megatrends v: 0407 date: 12/19/2006
CPU:       Dual core AMD Athlon 64 X2 4200+ (-MCP-) cache: 1024 KB
           flags: (lm nx pae sse sse2 sse3 svm) bmips: 4018
           clock speeds: max: 2200 MHz 1: 1000 MHz 2: 1000 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RV620 LE [Radeon HD 3450]
           bus-ID: 02:00.0
           Display Server: X.Org 1.15.1 drivers: ati,radeon (unloaded: fbdev,vesa)
           Resolution: 1280x1024@60.0hz
           GLX Renderer: Gallium 0.4 on AMD RV620
           GLX Version: 3.0 Mesa 10.1.3 Direct Rendering: Yes
Audio:     Card-1 NVIDIA MCP61 High Definition Audio
           driver: snd_hda_intel bus-ID: 00:05.0
           Card-2 Advanced Micro Devices [AMD/ATI] RV620 HDMI Audio [Radeon HD 3400 Series]
           driver: snd_hda_intel bus-ID: 02:00.1
           Sound: Advanced Linux Sound Architecture v: k4.2.0-27-generic
           driver: rtl8192cu usb-ID: 001-005
           IF: wlan2 state: N/A mac: N/A
           Card-3:  Ralink RT2870/RT3070 Wireless Adapter
           driver: rt2800usb v: 2.3.0 usb-ID: 002-012
           IF: wlan1 state: N/A mac: N/A
           IF: mon.wlan0 state: N/A mac: N/A
           Card-5:  Atheros TP-Link TL-WN322G v3 / TL-WN422G v2 802.11g [Atheros AR9271]
           IF: wlan0 state: N/A mac: N/A
Drives:    HDD Total Size: 265.6GB (14.0% used)
           ID-1: /dev/sda model: ST3250410AS size: 250.1GB
           ID-2: USB /dev/sdb model: TransMemory size: 15.5GB
Partition: ID-1: / size: 229G used: 23G (11%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 1.07GB used: 0.01GB (1%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 22.0C mobo: 20.0C
           Fan Speeds (in rpm): cpu: 2960 psu: 1928 sys-1: 0
Info:      Processes: 176 Uptime: 5:56 Memory: 351.1/1000.6MB
Düzenleme: Kod etiketi düzeltildi.
« Son Düzenleme: 12 Şubat 2016, 16:21:07 Gönderen: Quaoar »
« Yanıtla #9 : 12 Şubat 2016, 17:26:00 »
Aşağıdaki komutla çekirdeğin 4.4.1 32 bit sürümünü kurmayı deneyebilirsiniz.
mkdir linux4.4.1; cd linux4.4.1; wget -c --no-check-certificate kernel.ubuntu.com/~kernel-ppa/mainline/v4.4.1-wily/linux-headers-4.4.1-040401-generic_4.4.1-040401.201601311534_i386.deb kernel.ubuntu.com/~kernel-ppa/mainline/v4.4.1-wily/linux-headers-4.4.1-040401_4.4.1-040401.201601311534_all.deb kernel.ubuntu.com/~kernel-ppa/mainline/v4.4.1-wily/linux-image-4.4.1-040401-generic_4.4.1-040401.201601311534_i386.deb; sudo dpkg -i *.deb
Çevrimdışı efe
  • İleti: 84
« Yanıtla #10 : 12 Şubat 2016, 18:45:41 »
tesekkurler sorun çözüldü.baska bir sorun dikkatimi cekti syslog ve kernlog dosyalarının mb degerleri surekli artıyor.sudo rsyslog stop diyerek durdurdum root olarak giriş yapıp çöpe attım fakat çöpte görünmüyor.bilgisayarı yeniden baslattım aynı dosya degerleri artmaya devam ediyor.çöpteki verilerde gorunmediği için tamamen silemiyorum.ne yapmalıyım?
« Yanıtla #11 : 12 Şubat 2016, 19:00:48 »
bunun için yeni bir konu açmanız gerekiyor, aynı başlık altında sadece o konu ile ilgili sorunları çözüyoruz. ayrıca lütfen sorun çözüldüyse çözüldü etiketi eklemeyi unutmayınız.
Çözülen başlıkların etiketlenmesi hakkında
« Son Düzenleme: 12 Şubat 2016, 19:03:19 Gönderen: Danny »
