Gönderen Konu: [Çözüldü] Preparing to install Linux Mint ekranında donma  (Okunma sayısı 4415 defa)
Çevrimdışı Commodor
  • İleti: 51
İyi günler,
Mint kurulumu yaparken bu ekranda donup kalıyor.şuan bu postuda live da yapıyorum.Sık sık bu kurulum ekranında anormal beklediğim oluyordu fakat bu sefer hiç gelmemeye başladı.
System:    Host: mint Kernel: 3.19.0-32-generic x86_64 (64 bit gcc: 4.8.2)
           Desktop: Cinnamon 2.8.6 (Gtk 3.10.8~8+qiana) Distro: Linux Mint 17.3 Rosa
Machine:   System: SAMSUNG product: 550P5C/550P7C v: P09ABI
           Mobo: SAMSUNG model: NP550P5C-S04TR v: SEC_SW__1234567890ABCD
           Bios: American Megatrends v: P09ABI.026.141024.dg date: 10/24/2014
CPU:       Quad core Intel Core i7-3630QM (-HT-MCP-) cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 19157
           clock speeds: max: 3400 MHz 1: 1438 MHz 2: 1353 MHz 3: 1326 MHz 4: 3053 MHz 5: 1866 MHz 6: 1320 MHz
           7: 1944 MHz 8: 2844 MHz
           Card-2: NVIDIA GK107M [GeForce GT 650M] bus-ID: 01:00.0
           Display Server: X.Org 1.17.1 drivers: intel (unloaded: fbdev,vesa) FAILED: nouveau
           Resolution: 1600x900@60.1hz
           GLX Renderer: Mesa DRI Intel Ivybridge Mobile GLX Version: 3.0 Mesa 10.5.9 Direct Rendering: Yes
Network:   Card-1: Intel Centrino Advanced-N 6235 driver: iwlwifi v: in-tree: bus-ID: 02:00.0
           driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 03:00.0
Drives:    HDD Total Size: 1024.2GB (1.6% used) ID-1: /dev/sda model: ST1000LM024_HN size: 1000.2GB temp: 50C
           ID-2: /dev/sdb model: SanDisk_SSD_i100 size: 8.0GB temp: 0C
           ID-3: USB /dev/sdc model: Cruzer_Blade size: 16.0GB temp: 0C
Partition: ID-1: / size: 3.9G used: 92M (3%) fs: overlay dev: N/A
           ID-2: swap-1 size: 6.97GB used: 0.00GB (0%) fs: swap dev: /dev/sdb3
           ID-3: swap-2 size: 8.47GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 66.0C mobo: 66.0C gpu: N/A
Info:      Processes: 251 Uptime: 41 min Memory: 956.1/7871.6MB Init: Upstart runlevel: 2 Gcc sys: 4.8.4
« Son Düzenleme: 20 Şubat 2016, 15:25:21 Gönderen: Commodor »
Ynt: Preparing to install Linux Mint ekranında donma
« Yanıtla #1 : 20 Şubat 2016, 10:30:21 »
Uyumluluk kipi (compatibilty mode) ile kurulum denediniz mi?
Sistemi hangi USB ile kuruyorsunuz, 8 GB. olan mı 16 GB. olan mı?
Çevrimdışı Commodor
  • İleti: 51
« Yanıtla #2 : 20 Şubat 2016, 10:33:31 »
Uyumluluk modunda hiç denemedim.16 gb olan usb bellek ile kurulum yapmaya çalışıyorum.Usb kaynaklı olduğunu düşünmüyorum bi kaç usb de denememe rağmen bu şekilde donma yaşadım.Uyumluluk modunda deneyip tekrardan dönüş yapayım.Teşekkür ederim.
edit : şuan sadece 16 gb usb takılı
« Son Düzenleme: 20 Şubat 2016, 10:34:32 Gönderen: Commodor »
« Yanıtla #3 : 20 Şubat 2016, 10:43:20 »
Kurulum yaparken GPT disk bölümleme tablosuna sahip 8 GB.'lık USB bellek takılı olmasın.
Çevrimdışı Commodor
  • İleti: 51
« Yanıtla #4 : 20 Şubat 2016, 10:56:06 »
Uyumluluk modunda açmama rağmen sorun devam ediyor.
USB 16 gb.8 gb lik herhangi birşey pc de takılı değil.sadece telefonu sarj icin taktım oda 128 gb.ama 8gb ssd mevcut.dediğinizi tam anlamadım
« Yanıtla #5 : 20 Şubat 2016, 12:44:41 »
8 GB.'lık birimi görünce bunun da USB bellek olabileceğini düşünmüştüm.
Kurulum sihirbazını aşağıdaki komut ile uçbirimden çalıştırmayı deneyiniz, aldığınız hata çıktısı olursa paylaşınız.
sudo ubiquity
Çevrimdışı Commodor
  • İleti: 51
« Yanıtla #6 : 20 Şubat 2016, 13:44:37 »
Söylediğiniz komut ile çalıştırdım kurulumu, fakat yine aynı yerde kaldı.
Internet bağlantımı keserek yapmamın bir faydası olabilir mi acaba
edit : This problem occurred because some partitions were having bad sectors. I've formatted them and then the installation worked fine. Another work around is to mount the partitions with gnome disks and then the installer works fine.
forumda onaylanmış böyle bi post gördüm.sanırım bad sector yani hdd iptal gibi duruyor artık bunaldım  :) iyi ama ben şuan nasıl harddiskimi biçimlendirebilirim herhangi bi os  bilgisayarda kurulu değilken.hdd biçimlendirilecek kısma kadar ulaşamıyorum ki
« Son Düzenleme: 20 Şubat 2016, 13:56:48 Gönderen: Commodor »
« Yanıtla #7 : 20 Şubat 2016, 14:19:55 »
Gparted ile diskinizi biçimlendirebilirsiniz.
Çevrimdışı Commodor
  • İleti: 51
« Yanıtla #8 : 20 Şubat 2016, 15:25:08 »
Teşekkür Butterfly yardımların için.
söylediğinin yerine direk disc bölümünde diski biçimlendirdim ve sorun halloldu.konu kitlenebilir.
ÇÖZÜM : Diskte oluşan bad sector hataları kaynaklı sistemin kurulacağı hdd,ssd vs. diski biçimlendirmek.
Ynt: [Çözüldü] Preparing to install Linux Mint ekranında donma
« Yanıtla #9 : 20 Şubat 2016, 17:53:27 »
Rica ederiz.
