Gönderen Konu: Yeni bilgisayarım için yazılım donanım incelemesi hakkında...  (Okunma sayısı 4773 defa)
Çevrimdışı cmertkucuk
  • İleti: 492
Merhaba;
Birkaç gün önce eski bilgisayarım ile vedalaştım, yeni bilgisayarım için gerekli komutları buraya aktarsam inceleyeblir misiniz ?  (Sistemde donanım ve yazılım konusunda  eksik hata vs sorunlar var mı ?)
c@Linux-System ~ $ inxi -SGx
System:    Host: Linux-System Kernel: 3.19.0-32-generic x86_64 (64 bit gcc: 4.8.2)
           Distro: Linux Mint 17.3 Rosa
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RS780L [Radeon 3000]
           bus-ID: 01:05.0
           Display Server: X.Org 1.17.1 drivers: ati,radeon (unloaded: fbdev,vesa)
           Resolution: 1440x900@59.9hz
           GLX Renderer: Gallium 0.4 on AMD RS780
c@Linux-System ~ $ glxinfo | grep render
OpenGL renderer string: Gallium 0.4 on AMD RS780
c@Linux-System ~ $ lspci | egrep 'VGA|3D|Display'
01:05.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RS780L [Radeon 3000]
c@Linux-System ~ $ xrandr
Screen 0: minimum 320 x 200, current 1440 x 900, maximum 8192 x 8192
VGA-0 connected primary 1440x900+0+0 (normal left inverted right x axis y axis) 408mm x 255mm
   1440x900       59.9*+   75.0
   1280x1024      75.0     60.0
   1280x720       60.0
   1024x768       75.1     60.0
   800x600        75.0     60.3
   640x480        75.0     72.8     66.7     60.0
   720x400        70.1
c@Linux-System ~ $ cat /etc/X11/xorg.conf
c@Linux-System ~ $
c@Linux-System ~ $ inxi -SMAx
Machine:   Mobo: ASUSTeK model: M5A78L-M LX V2 v: Rev X.0x
           Bios: American Megatrends v: 1201 date: 09/04/2012
Audio:     Card Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA)
           driver: snd_hda_intel bus-ID: 00:14.2
c@Linux-System ~ $ cat /proc/asound/card0/codec#* | grep Codec
Codec: Realtek ALC887-VD
c@Linux-System ~ $ cat /proc/asound/modules
 0 snd_hda_intel
c@Linux-System ~ $ lsmod | grep snd
snd_hda_codec_realtek    81920  1
snd_hda_codec_generic    69632  1 snd_hda_codec_realtek
snd_hda_intel          36864  3
snd_hda_codec         143360  4 snd_hda_codec_realtek,snd_hda_codec_generic,snd_hda_intel,snd_hda_controller
snd_pcm               106496  3 snd_hda_codec,snd_hda_intel,snd_hda_controller
snd                    86016  16 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
c@Linux-System ~ $ aplay -l
**** PLAYBACK Donanım Aygıtlarının Listesi ****
kart 0: SB [HDA ATI SB], aygıt 0: ALC887-VD Analog [ALC887-VD Analog]
  Altaygıtlar: 1/1
  Altaygıt #0: subdevice #0
kart 0: SB [HDA ATI SB], aygıt 1: ALC887-VD Digital [ALC887-VD Digital]
  Altaygıtlar: 1/1
c@Linux-System ~ $
c@Linux-System ~ $ inxi -SNx
           driver: r8169 v: 2.3LK-NAPI port: e800 bus-ID: 02:00.0
c@Linux-System ~ $ lspci -nnk | grep -iA2 net
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 09)
    Subsystem: ASUSTeK Computer Inc. P8 series motherboard [1043:8505]
    Kernel driver in use: r8169
c@Linux-System ~ $ lsusb
Bus 001 Device 002: ID 03f0:b011 Hewlett-Packard
Bus 004 Device 002: ID 09da:c10a A4 Tech Co., Ltd
Bus 003 Device 002: ID 045e:0750 Microsoft Corp. Wired Keyboard 600
c@Linux-System ~ $ rfkill list
c@Linux-System ~ $ sudo lshw -C network
[sudo] password for c:
  *-network
       açıklama: Eternet interface
       physical id: 0
       bus info: pci@0000:02:00.0
       mantıksal ad: eth0
       sürüm: 09
       serial: 50:46:5d:6a:ec:35
       boyut: 100Mbit/s
       kapasite: 1Gbit/s
       genişlik: 64 bits
       saat: 33MHz
       yapılandırma: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168f-1_0.0.5 06/18/12 ip=192.168.2.254 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       kaynaklar: irq:25 ioport:e800(boyut=256) bellek:fdfff000-fdffffff bellek:fdff8000-fdffbfff
c@Linux-System ~ $ iwconfig | grep Power
pci_stub               16384  1
vboxpci                24576  0
vboxnetadp             28672  0
vboxnetflt             28672  0
vboxdrv               450560  4 vboxnetadp,vboxnetflt,vboxpci
rfcomm                 69632  0
bluetooth             491520  10 bnep,rfcomm
usblp                  24576  0
kvm                   479232  0
scsi_dh                16384  1 dm_multipath
edac_core              53248  0
edac_mce_amd           24576  0
i2c_piix4              24576  0
asus_atk0110           20480  0
shpchp                 40960  0
xts                    16384  1
gf128mul               16384  1 xts
dm_crypt               24576  1
hid                   110592  2 hid_generic,usbhid
amdkfd                 81920  1
radeon               1556480  3
i2c_algo_bit           16384  1 radeon
ttm                    94208  1 radeon
drm_kms_helper        126976  1 radeon
drm                   344064  6 ttm,drm_kms_helper,radeon
psmouse               114688  0
pata_atiixp            16384  0
wmi                    20480  0
c@Linux-System ~ $
Teşekkür ederim.
ϜϓſϞ EY TÜRK!
(Bilge Kağan)ϜϓſϞ
Çevrimdışı minteger
  • İleti: 381
Onboard grafik kartı olan bir masaüstü mü bu ?
  • İleti: 492
Onboard kısmını bilmiyorum ama  masaüstü :)
ϜϓſϞ EY TÜRK!
(Bilge Kağan)ϜϓſϞ
Çevrimdışı minteger
  • İleti: 381
Bir bak istersen kasaya harici ekran kartı var mı ?.
Ben anormal bir durum göremedim açıkcası.
  • İleti: 492
Dahili ve harici ekran kartının nasıl anlaşılacağını tam olarak bilmiyorum, sanırım dahili çünkü Sistem Bilgisinde ram düşük gözüküyor.
8 gb yerine 7.5 gb gözüküyor.
Anakartın üzerinde Ekran kartı göremiyorum sanırım dahili ekran kartına sahibim.
« Son Düzenleme: 06 Mart 2016, 14:41:19 Gönderen: ckursadturk »
ϜϓſϞ EY TÜRK!
(Bilge Kağan)ϜϓſϞ
Çevrimdışı minteger
  • İleti: 381
Evet anakartın üzerine takılı olmaydığında anakartın üzerinde oluyor onboard oluyor genellikle. (grafik işlem birimini içinde barındıran cpu lar hariç. ki eski bilgisayarlarda bulunmuyor.)  Hayırlı olsun.
  • İleti: 492
Teşekkür ederim.
ϜϓſϞ EY TÜRK!
(Bilge Kağan)ϜϓſϞ
