Gönderen Konu: [Çözüldü] Sistem Gözlemcisi'nde ram 2,9 GİB olarak görünüyor  (Okunma sayısı 4140 defa)
Çevrimdışı thedumper
  • İleti: 25
merhaba arkadaşlar,linux mint 17.3 mate 64 bit kullanıyorum.daha yeni kurdum.fakat sorun şu ki sistemimde 3 gb ram olduğu halde Sistem Gözlemcisi'nde 2,9 GİB olarak gözüküyor.sorun nedir?
« Son Düzenleme: 21 Mart 2016, 16:56:09 Gönderen: thedumper »
Ynt: Sistem Gözlemcisi'nde ram 2,9 GİB olarak görünüyor
« Yanıtla #1 : 20 Mart 2016, 17:29:21 »
Çıktıya bakalım.
sudo inxi -Fxmz
  • İleti: 25
« Yanıtla #2 : 20 Mart 2016, 17:39:48 »
Çıktıya bakalım.
sudo inxi -Fxmz
System:    Host: ozgur-System-Product-Name Kernel: 3.19.0-32-generic x86_64 (64 bit gcc: 4.8.2)
           Distro: Linux Mint 17.3 Rosa
Machine:   Mobo: ASUSTeK model: P5LD2-X v: Rev x.xx
           Bios: American Megatrends v: 0104 date: 05/18/2007
CPU:       Dual core Intel Core2 Duo E6550 (-MCP-) cache: 4096 KB
           flags: (lm nx sse sse2 sse3 ssse3 vmx) bmips: 7466
           clock speeds: max: 2331 MHz 1: 2331 MHz 2: 2331 MHz
Memory:    Array-1 capacity: 4 GB (est) devices: 2 EC: None
           max module size: 2 GB
           Device-1: DIMM0 size: 2 GB speed: 333 MHz type: DDR2 part: N/A
           Device-2: DIMM1 size: 1 GB speed: 333 MHz type: DDR2 part: N/A
Graphics:  Card: NVIDIA G92 [GeForce 9800 GT] bus-ID: 04:00.0
           Display Server: X.org 1.17.1 drivers: nouveau (unloaded: fbdev,vesa)
           tty size: 80x24 Advanced Data: N/A for root
Audio:     Card Intel NM10/ICH7 Family High Definition Audio Controller
Network:   Card: Qualcomm Atheros Attansic L2 Fast Ethernet
           driver: atl2 v: 2.2.3 bus-ID: 02:00.0
Drives:    HDD Total Size: 250.1GB (4.5% used)
           ID-1: /dev/sda model: WDC_WD2500AAJS size: 250.1GB temp: 34C
Partition: ID-1: / size: 227G used: 7.7G (4%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 3.22GB used: 0.01GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 44.0C mobo: N/A
           Fan Speeds (in rpm): cpu: 2280 sys-1: 0
Info:      Processes: 160 Uptime: 1:08 Memory: 2664.3/3008.6MB
           Client: Shell (sudo) inxi: 2.2.28
« Yanıtla #3 : 20 Mart 2016, 18:01:35 »
Çıktıya göre bir sorun yok, grafik arayüzlü uygulamada bir hata olabilir. MATE yakında bir güncelleme alacak, şu anda romeo deposunda 1.12.1 sürüm paketler test ediliyor. Bu güncelleme ile sorun da çözülebilir. Bununla birlikte eksik tanınan bir RAM miktarı olmadığını söyleyebiliriz.
  • İleti: 25
« Yanıtla #4 : 20 Mart 2016, 18:24:02 »
teşekkür ederim :) .
