Gönderen Konu: nvidia x setting ayarlarını kaydetmiyor  (Okunma sayısı 3879 defa)
Çevrimdışı YusufASLAN
  • İleti: 4
« : 24 Nisan 2016, 23:54:15 »
Ekran çözünürlüğünü 1280*720 yapıyorum ama kendisi auto olarak bir sonraki açılışta sıfırlıyor ayarları x configurasyon dosyasınada kaydettim hala aktif olmuyor
inxi -SGx
System:    Host: Machine Kernel: 3.19.0-32-generic i686 (32 bit gcc: 4.8.2)
           Desktop: Cinnamon 2.8.8 (Gtk 2.24.23) Distro: Linux Mint 17.3 Rosa
Graphics:  Card: NVIDIA GT215M [GeForce GT 335M] bus-ID: 01:00.0
           Display Server: X.Org 1.17.1 driver: nvidia
           Resolution: 1366x768@60.0hz
           GLX Renderer: GeForce GT 335M/PCIe/SSE2
           GLX Version: 3.3.0 NVIDIA 304.131 Direct Rendering: Yes
OpenGL renderer string: GeForce GT 335M/PCIe/SSE2
    GL_NVX_conditional_render, GL_NVX_gpu_memory_info,
    GL_NV_blend_square, GL_NV_complex_primitives, GL_NV_conditional_render,
    GL_OES_depth_texture, GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
01:00.0 VGA compatible controller: NVIDIA Corporation GT215M [GeForce GT 335M] (rev a2)
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 8192 x 8192
LVDS-0 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1366x768       60.0*+
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 331.20  (buildd@komainu)  Mon Feb  3 15:11:14 UTC 2014
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    Option         "Xinerama" "0"
Section "Files"
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Identifier     "Keyboard0"
    Driver         "kbd"
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "cPATH"
    HorizSync       30.0 - 75.0
    VertRefresh     59.0
    Option         "DPMS"
    Identifier     "Device0"
    Driver         "nvidia"
    BoardName      "GeForce GT 335M"
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-0"
    Option         "metamodes" "nvidia-auto-select +0+0 {viewportin=1280x720, viewportout=1365x768+0+0}"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
« Son Düzenleme: 25 Nisan 2016, 00:08:38 Gönderen: YusufASLAN »
Ynt: nvidia x setting ayarlarını kaydetmiyor
« Yanıtla #1 : 26 Nisan 2016, 13:48:34 »
Aşağıdaki komutlarla grafik sürücüsü PPA deposunu ekleyip,
sonra Güncelleme Yöneticisini açınız, Yenile düğmesine tıklayıp paket bilgisi önbelleğini güncelledikten sonra güncellemeleri kurmayı deneyiniz.
