Gönderen Konu: Kali Linux Wifi Sorunu  (Okunma sayısı 7828 defa)
Çevrimdışı Corpax
  • İleti: 2
  • Dağıtım: Kali Linux
  • Grafik Kartı: Nvidia Gt430
  • İşlemci: Amd Athlon X2 64 4000+
« : 30 Nisan 2016, 18:56:42 »
Hiçbir Ağa Bağlanamamaktayım , Şifresizlerde Dahil .
Çevrimdışı Corpax
  • İleti: 2
Ynt: Kali Linux Wifi Sorunu
« Yanıtla #2 : 01 Mayıs 2016, 22:23:07 »
root@localhost:~# lspci -nnk
00:00.0 RAM memory [0500]: NVIDIA Corporation MCP61 Memory Controller [10de:03ea] (rev a1)
Subsystem: NVIDIA Corporation Device [10de:cb84]
00:01.0 ISA bridge [0601]: NVIDIA Corporation MCP61 LPC Bridge [10de:03e0] (rev a2)
00:01.1 SMBus [0c05]: NVIDIA Corporation MCP61 SMBus [10de:03eb] (rev a2)
Kernel driver in use: nForce2_smbus
00:01.2 RAM memory [0500]: NVIDIA Corporation MCP61 Memory Controller [10de:03f5] (rev a2)
00:02.0 USB controller [0c03]: NVIDIA Corporation MCP61 USB 1.1 Controller [10de:03f1] (rev a3)
Kernel driver in use: ohci-pci
00:02.1 USB controller [0c03]: NVIDIA Corporation MCP61 USB 2.0 Controller [10de:03f2] (rev a3)
Kernel driver in use: ehci-pci
00:04.0 PCI bridge [0604]: NVIDIA Corporation MCP61 PCI bridge [10de:03f3] (rev a1)
00:05.0 Audio device [0403]: NVIDIA Corporation MCP61 High Definition Audio [10de:03f0] (rev a2)
Subsystem: NVIDIA Corporation MCP61 High Definition Audio [10de:03f0]
Kernel driver in use: snd_hda_intel
00:06.0 IDE interface [0101]: NVIDIA Corporation MCP61 IDE [10de:03ec] (rev a2)
Kernel driver in use: pata_amd
00:07.0 Bridge [0680]: NVIDIA Corporation MCP61 Ethernet [10de:03ef] (rev a2)
Kernel driver in use: forcedeth
00:08.0 IDE interface [0101]: NVIDIA Corporation MCP61 SATA Controller [10de:03f6] (rev a2)
Kernel driver in use: sata_nv
00:09.0 PCI bridge [0604]: NVIDIA Corporation MCP61 PCI Express bridge [10de:03e8] (rev a2)
Kernel driver in use: pcieport
00:0b.0 PCI bridge [0604]: NVIDIA Corporation MCP61 PCI Express bridge [10de:03e9] (rev a2)
00:0c.0 PCI bridge [0604]: NVIDIA Corporation MCP61 PCI Express bridge [10de:03e9] (rev a2)
00:18.0 Host bridge [0600]: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration [1022:1100]
00:18.1 Host bridge [0600]: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map [1022:1101]
00:18.2 Host bridge [0600]: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller [1022:1102]
00:18.3 Host bridge [0600]: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control [1022:1103]
Kernel driver in use: k8temp
01:06.0 Multimedia audio controller [0401]: C-Media Electronics Inc CMI8738/CMI8768 PCI Audio [13f6:0111] (rev 10)
Subsystem: C-Media Electronics Inc CMI8738/C3DX PCI Audio Device [13f6:0111]
Kernel driver in use: snd_cmipci
root@localhost:~# lsusb
Bus 002 Device 003: ID 046d:c326 Logitech, Inc.
Bus 002 Device 002: ID 2357:0100
root@localhost:~# rfkill liss
Usage: rfkill [options] command
Options:
--version show version (0.4-1 (Debian))
Commands:
help
event
list [IDENTIFIER]
block IDENTIFIER
unblock IDENTIFIER
where IDENTIFIER is the index no. of an rfkill switch or one of:
<idx> all wifi wlan bluetooth uwb ultrawideband wimax wwan gps fm
root@localhost:~# iwconfig
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry short limit:7 RTS thr=2347 B Fragment thr:off
Encryption key:off
Power Management:off
lo no wireless extensions.
eth0 no wireless extensions.
root@localhost:~# lsmod
Module Size Used by
fuse 81701 3
nfnetlink_log 17065 0
nfnetlink 12896 1 nfnetlink_log
binfmt_misc 12726 1
loop 26085 0
dm_crypt 22256 0
arc4 12487 2
snd_hda_codec_hdmi 44456 4
rtl8192cu 65515 0
rtl_usb 17368 1 rtl8192cu
nouveau 1124780 2
rtl8192c_common 39611 1 rtl8192cu
rtlwifi 49850 3 rtl_usb,rtl8192c_common,rtl8192cu
mac80211 446741 3 rtl_usb,rtlwifi,rtl8192cu
cfg80211 357998 2 mac80211,rtlwifi
rfkill 18414 3 cfg80211
mxm_wmi 12467 1 nouveau
joydev 16884 0
wmi 17147 2 mxm_wmi,nouveau
snd_cmipci 35939 2
snd_mpu401_uart 13299 1 snd_cmipci
video 17803 1 nouveau
snd_rawmidi 22278 1 snd_mpu401_uart
snd_opl3_lib 17206 1 snd_cmipci
ttm 72071 1 nouveau
i2c_nforce2 12527 0
drm_kms_helper 67474 1 nouveau
drm 212860 5 ttm,drm_kms_helper,nouveau
i2c_algo_bit 12647 1 nouveau
snd_seq_device 12980 2 snd_rawmidi,snd_opl3_lib
parport_pc 25991 0
psmouse 93523 0
8250_fintek 12687 0
parport 35171 1 parport_pc
gameport 13306 1 snd_cmipci
evdev 17172 5
i2c_core 36867 5 drm,drm_kms_helper,i2c_algo_bit,nouveau,i2c_nforce2
k8temp 12482 0
snd_hda_intel 26011 2
snd_hda_controller 26422 1 snd_hda_intel
