Gönderen Konu: wifi baglantisi bir sure sonra kopuyor  (Okunma sayısı 2232 defa)
Çevrimdışı hazar1907
  • İleti: 5
« : 04 Mayıs 2016, 12:19:27 »
merhaba mint 17.3 xfce kurdum ama şöyle bir sorunum var..
pc açılınca wifi bağlanıyor ama 4 -5 dakika sonra nete giremiyorum. ağa bağlıyım ama net yok. pc acınca düzeliyor.
Şu an wifi adaptörten bağlanıyorum çözüm nedir
hazar@GNB-1150-B1-N2 ~ $ inxi -SNx
System:    Host: GNB-1150-B1-N2 Kernel: 3.19.0-32-generic x86_64 (64 bit gcc: 4.8.2)
           Desktop: Xfce 4.12.2 (Gtk 2.24.23) Distro: Linux Mint 17.3 Rosa
Network:   Card-1: Realtek RTL8101E/RTL8102E PCI Express Fast Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 01:00.2
           Card-2: Realtek RTL8723BE PCIe Wireless Network Adapter
           driver: rtl8723be port: d000 bus-ID: 02:00.0
           Card-3: Ralink RT2870/RT3070 Wireless Adapter
           driver: rt2800usb v: 2.3.0 usb-ID: 001-006
hazar@GNB-1150-B1-N2 ~ $ lspci -nnk | grep -iA2 net
01:00.2 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller [10ec:8136] (rev 06)
Subsystem: CLEVO/KAPOK Computer Device [1558:5471]
Kernel driver in use: r8169
02:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter [10ec:b723]
Subsystem: Realtek Semiconductor Co., Ltd. Device [10ec:b729]
Kernel driver in use: rtl8723be
Bus 001 Device 005: ID 04f2:b46d Chicony Electronics Co., Ltd
Bus 001 Device 006: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Bus 001 Device 004: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 001 Device 003: ID 058f:6254 Alcor Micro Corp. USB Hub
Bus 001 Device 002: ID 0bda:b002 Realtek Semiconductor Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hu
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: phy1: Wireless LAN
Soft blocked: no
sudo lshw -C network
[sudo] password for hazar:
PCI (sysfs)
iwconfig | grep Power
          Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
          Power Management:off
          Bit Rate=52 Mb/s   Tx-Power=20 dBm
lsmod
rt2800usb              28672  0
rt2x00usb              24576  1 rt2800usb
rt2800lib              90112  1 rt2800usb
rt2x00lib              57344  3 rt2x00usb,rt2800lib,rt2800usb
crc_ccitt              16384  1 rt2800lib
ctr                    16384  1
ccm                    20480  1
intel_powerclamp       20480  0
kvm_intel             151552  0
kvm                   479232  1 kvm_intel
scsi_dh                16384  1 dm_multipath
cryptd                 20480  1 ghash_clmulni_intel
arc4                   16384  4
rtl8723be              94208  0
btcoexist              53248  1 rtl8723be
rtl8723_common         24576  1 rtl8723be
rtl_pci                28672  1 rtl8723be
rtlwifi                73728  2 rtl_pci,rtl8723be
mac80211              708608  6 rtl_pci,rtlwifi,rt2x00lib,rt2x00usb,rt2800lib,rtl8723be
cfg80211              524288  3 mac80211,rtlwifi,rt2x00lib
snd_hda_codec_via      32768  1
snd_hda_codec_generic    69632  1 snd_hda_codec_via
rtsx_pci_ms            20480  0
snd_intel_sst_acpi     16384  0
memstick               20480  1 rtsx_pci_ms
videobuf2_core         53248  1 uvcvideo
v4l2_common            16384  1 videobuf2_core
snd_intel_sst_core     73728  1 snd_intel_sst_acpi
snd_hda_intel          36864  4 snd_hda_codec_hdmi
videodev              159744  3 uvcvideo,v4l2_common,videobuf2_core
snd_soc_sst_mfld_platform    77824  1 snd_intel_sst_core
snd_soc_core          196608  1 snd_soc_sst_mfld_platform
snd_compress           20480  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
shpchp                 40960  0
snd_hda_codec         143360  5 snd_hda_codec_hdmi,snd_hda_codec_via,snd_hda_codec_generic,snd_hda_intel,snd_hda_controller
mei_txe                20480  0
mei                    90112  1 mei_txe
snd_pcm               106496  7 snd_soc_core,snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_soc_sst_mfld_platform,snd_hda_controller,snd_pcm_dmaengine
btusb                  40960  0
rfcomm                 69632  12
bluetooth             491520  22 bnep,btusb,rfcomm
iosf_mbi               16384  1 intel_rapl
snd                    86016  20 snd_soc_core,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_hda_codec_via,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_soc_sst_mfld_platform,snd_seq_device,snd_compress
snd_soc_sst_acpi       16384  0
hid                   110592  2 hid_generic,usbhid
rtsx_pci_sdmmc         24576  0
psmouse               114688  0
i915                 1048576  4
rtsx_pci               49152  2 rtsx_pci_ms,rtsx_pci_sdmmc
wmi                    20480  0
drm_kms_helper        126976  1 i915
video                  20480  1 i915
drm                   344064  6 i915,drm_kms_helper
Ynt: wifi baglantisi bir sure sonra kopuyor
« Yanıtla #1 : 04 Mayıs 2016, 20:59:40 »
Lütfen konu açmadan önce forum içi arama özelliğini kullanmayı göz ardı etmeyelim.
https://forum.linuxmint.net.tr/index.php?topic=5744.0
