Gönderen Konu: [Çözüldü] Mint 17.3 Cinnamon kapanma sorunu  (Okunma sayısı 17973 defa)
Çevrimdışı topal karga
  • İleti: 63
  • ex nihilo nihil fit!
  • Dağıtım: Mint 119.2 Mate 64 Bit
« : 08 Haziran 2016, 21:40:00 »
Disk identifier: 0x000109ad
/dev/sda1   *        2048   968548351   484273152   83  Linux
/dev/sda2       968550398   976771071     4110337    5  Extended
Partition 2 does not start on physical sector boundary.
/dev/sda5       968550400   976771071     4110336   82  Linux swap / Solaris
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdb: 2003 MB, 2003828736 bytes
255 heads, 63 sectors/track, 243 cylinders, total 3913728 sectors
Disk identifier: 0x3c2c30ee
/dev/sdb1   *           0     3071167     1535584    0  Empty
/dev/sdb2           11864       16407        2272   ef  EFI (FAT-12/16/32)
kapat komutu sonrası sayfalarca hata veriyor ve kapanmıyor. Her seferinde farklı bir hata gördüm;
"error formatting volume unable to handle kernel", "ACPİ PCC probe failed" vs.
Laptop yeni. ilk kurulum yaparken "diski sil, mint yükle" komutunu seçtim. Sonuç bu.
« Son Düzenleme: 08 Haziran 2016, 22:54:57 Gönderen: topal karga »
Ynt: Mint 17.3 Cinnamon kapanma sorunu
« Yanıtla #1 : 08 Haziran 2016, 22:09:07 »
Yeni dizüstünüz hayırlı olsun diyelim, güle güle kullanın.
  • İleti: 63
« Yanıtla #2 : 08 Haziran 2016, 22:14:43 »
Teşekkür ederim :)
System:    Host: tranko-buskas Kernel: 3.19.0-32-generic x86_64 (64 bit gcc: 4.8.2)
           Distro: Linux Mint 17.3 Rosa
Machine:   System: LENOVO product: 80E5 v: Lenovo G50-80
           Mobo: LENOVO model: Lenovo G50-80 v: 31900059 WIN
           Bios: LENOVO v: B0CN69WW date: 06/20/2014
CPU:       Dual core Intel Core i5-5200U (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 8779
           clock speeds: max: 2700 MHz 1: 2414 MHz 2: 2520 MHz 3: 2297 MHz
           4: 2344 MHz
Graphics:  Card-1: Intel Broadwell-U Integrated Graphics bus-ID: 00:02.0
           Card-2: Advanced Micro Devices [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330]
           bus-ID: 04:00.0
           Display Server: X.Org 1.17.1 drivers: ati,radeon,intel (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.0hz
           GLX Renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2)
Audio:     Card-1 Intel Wildcat Point-LP High Definition Audio Controller
           Card-2 Intel Broadwell-U Audio Controller
           driver: r8169 v: 2.3LK-NAPI port: 5000 bus-ID: 02:00.0
           Card-2: Realtek RTL8723BE PCIe Wireless Network Adapter
           driver: rtl8723be port: 4000 bus-ID: 03:00.0
Drives:    HDD Total Size: 502.1GB (8.5% used)
           ID-1: /dev/sda model: ST500LM000 size: 500.1GB
           ID-2: USB /dev/sdb model: PDM09_2G_ABF2.0 size: 2.0GB
Partition: ID-1: / size: 455G used: 36G (9%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 4.21GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 58.0C mobo: N/A gpu: N/A
Info:      Processes: 196 Uptime: 6:20 Memory: 1139.7/3871.9MB
« Yanıtla #3 : 08 Haziran 2016, 22:23:11 »
Sürücü Yöneticisini açıp fglrx-updates sürücüsünü kurunuz ve ardından aşağıdaki komutları sırasıyla uçbirimde çalıştırınız.
sudo aticonfig --initial -f --adapter=all
sudo aticonfig --px-igpu
Ardından sisteminizi yeniden başlatmayı deneyiniz.
  • İleti: 63
« Yanıtla #4 : 08 Haziran 2016, 22:52:18 »
Teşekkürler [member=8]Butterfly[/member]. İki kez yeniden başlatıım, iki kez de kapatıp açtım. Şu an sorun yok.  çözüldü diyorum, umarım yanılmam :) İyi geceler dilerim.
Ynt: [Çözüldü] Mint 17.3 Cinnamon kapanma sorunu
« Yanıtla #5 : 08 Haziran 2016, 23:12:47 »
Aşağıdaki komutların çıktılarına bir bakalım.
fglrxinfo
inxi -Gx
  • İleti: 63
« Yanıtla #6 : 08 Haziran 2016, 23:21:27 »
     fglrxinfo
display: :0  screen: 0
OpenGL renderer string: AMD Radeon (TM) R5 M330
OpenGL version string: 4.5.13399 Compatibility Profile Context 15.201.1151
     inxi -Gx
           bus-ID: 04:00.0
           Display Server: X.Org 1.17.1 drivers: fglrx (unloaded: intel)
           GLX Renderer: AMD Radeon R5 M330
           GLX Version: 4.5.13399 - CPC 15.201.1151 Direct Rendering: Yes
Fan oldukça hızlı dönmeye başladı. Bir de skype ekranında görüntü iki renge bölündü.
« Yanıtla #7 : 08 Haziran 2016, 23:42:45 »
Aşağıdaki komutu uçbirimde çalıştırıp sistemi yeniden başlatmayı deneyiniz, bu komut dahili Intel GPU'yu etkinleştirecektir.
Ardından önceki komutların çıktılarına yeniden bakalım.
  • İleti: 63
« Yanıtla #8 : 08 Haziran 2016, 23:53:21 »
f
glrxinfo
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 5500 (Broadwell GT2)
OpenGL version string: 3.0 Mesa 10.5.9
 inxi -Gx
           bus-ID: 04:00.0
Skype ekranı renk bozulması düzeldi. Fan da daha iyi.
« Yanıtla #9 : 09 Haziran 2016, 00:20:23 »
Hala ATI GPU etkin görünüyor, aşağıdaki komutun çıktısına bir bakalım.
  • İleti: 63
« Yanıtla #10 : 09 Haziran 2016, 00:35:29 »
PowerXpress: Integrated GPU is selected (Power-Saving mode), please restart Xserver(s) for changes to take effect!
Bumblebee sorunum vardı, önceki laptopda. Bu da benzer bir sorun galiba?
« Yanıtla #11 : 09 Haziran 2016, 00:42:10 »
Sistemi yeniden başlattınız mı? Intel GPU'nun etkin olması için komutdan sonra sistemin yeniden başlatılması gerekiyor.
  • İleti: 63
« Yanıtla #12 : 09 Haziran 2016, 00:45:31 »
Evet. Başlattım. Önceki çıktılara da yeniden baktım. Deişim yok. Redshift kullanılamıyor şu an. Tek değişen o :)
« Yanıtla #13 : 09 Haziran 2016, 00:53:07 »
  • İleti: 63
« Yanıtla #14 : 09 Haziran 2016, 00:59:06 »
Section "ServerLayout"
    Identifier "amd-layout"
    Screen 0 "amd-screen" 0 0
    Identifier "intel"
    Driver "intel"
    Option "AccelMethod" "uxa"
    BusID "PCI:0@0:2:0"
    Identifier "amd-device"
    Driver "fglrx"
    BusID "PCI:4:0:0"
Section "Monitor"
    Identifier "amd-monitor"
    Option "VendorName" "ATI Proprietary Driver"
    Option "ModelName" "Generic Autodetecting Monitor"
    Option "DPMS" "true"
Section "Screen"
    Identifier "amd-screen"
    Device "amd-device"
    Monitor "amd-monitor"
    DefaultDepth 24
    SubSection "Display"
        Viewport   0 0
        Depth     24
    EndSubSection
