Gönderen Konu: [Çözüldü] Calibre Açılmama sorunu  (Okunma sayısı 4706 defa)
Çevrimdışı Trust
  • İleti: 406
  • Dağıtım: Lİnux Mint 19
« : 13 Temmuz 2016, 20:10:05 »
Calibre'yi ilk açtığımda
  File "/usr/lib/calibre/calibre/gui2/main.py", line 276, in initialize_db_stage2
    self.start_gui(db)
  File "/usr/lib/calibre/calibre/gui2/main.py", line 211, in start_gui
    main = self.main = Main(self.opts, gui_debug=self.gui_debug)
  File "/usr/lib/calibre/calibre/gui2/ui.py", line 152, in __init__
    ac = self.init_iaction(action)
  File "/usr/lib/calibre/calibre/gui2/ui.py", line 166, in init_iaction
    ac = action.load_actual_plugin(self)
  File "/usr/lib/calibre/calibre/customize/__init__.py", line 603, in load_actual_plugin
    ac = getattr(importlib.import_module(mod), cls)(gui,
  File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
    __import__(name)
  File "/usr/lib/calibre/calibre/gui2/actions/catalog.py", line 13, in <module>
    from calibre.gui2.tools import generate_catalog
  File "/usr/lib/calibre/calibre/gui2/tools.py", line 16, in <module>
    from calibre.gui2.convert.single import NoSupportedInputFormats
  File "/usr/lib/calibre/calibre/gui2/convert/single.py", line 18, in <module>
    from calibre.gui2.convert.look_and_feel import LookAndFeelWidget
  File "/usr/lib/calibre/calibre/gui2/convert/look_and_feel.py", line 13, in <module>
    from calibre.gui2.convert.look_and_feel_ui import Ui_Form
  File "/usr/lib/calibre/calibre/gui2/convert/look_and_feel_ui.py", line 286, in <module>
    from calibre.gui2.css_transform_rules import RulesWidget
  File "/usr/lib/calibre/calibre/gui2/css_transform_rules.py", line 13, in <module>
    from calibre.ebooks.css_transform_rules import (
  File "/usr/lib/calibre/calibre/ebooks/css_transform_rules.py", line 12, in <module>
    import regex
  File "/usr/lib/calibre/regex/__init__.py", line 392, in <module>
    from . import _regex_core
  File "/usr/lib/calibre/regex/_regex_core.py", line 4135, in <module>
    "d": lookup_property(None, "Digit", True),
  File "/usr/lib/calibre/regex/_regex_core.py", line 1593, in lookup_property
    raise error("unknown property")
error: unknown property
  uyarısı veriyor. İkinci kez açmaya çalıştığımda ise aşağıdaki uyayı veriyor.
Oturumu kapatsamda sistemi yeniden başlatsamda sırasıyla aynı uyarıları alıyorum ama calibre açılmıyor.
« Son Düzenleme: 14 Temmuz 2016, 05:55:06 Gönderen: Trust »
الهى انت مقصودى، ورضاك مطلوبى
Ynt: Calibre Açılmama sorunu
« Yanıtla #1 : 13 Temmuz 2016, 23:00:24 »
Aşağıdaki komutla Calibre başlatıcı dosyasını açınız.
sudo xed /usr/share/applications/calibre-gui.desktop
Exec=calibre %f
aşağıdaki şekilde düzeltip kaydediniz.
Exec=env LC_ALL=C calibre %f
İkinci kez açmaya çalıştığımda ise aşağıdaki uyarıyı veriyor.
İkinci kez açtıysanız aşağıdaki komutu kullanınız.
killall calibre
Çevrimdışı Trust
  • İleti: 406
« Yanıtla #2 : 14 Temmuz 2016, 05:54:42 »
Teşekkürler üstadım :)
