Gönderen Konu: Bilgisayar kapanmıyor  (Okunma sayısı 3202 defa)
« : 15 Temmuz 2016, 17:33:57 »
Yeni kurulum yaptığımız Hp 250 G4 dizüstü kapatılınca yada yeniden başlatılıcınca bu şekilde kalıyor...
Teşekkürler
System:    Host: kalite3 Kernel: 3.19.0-32-generic x86_64 (64 bit gcc: 4.8.2)
           Distro: Linux Mint 17.3 Rosa
Machine:   System: HP product: HP 250 G4 Notebook PC v: Type1ProductConfigId
           Mobo: HP model: 8136 v: 31.35 Bios: Insyde v: F.1E date: 12/25/2015
CPU:       Dual core Intel Core i5-6200U (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9595
           clock speeds: max: 2301 MHz 1: 500 MHz 2: 1300 MHz 3: 1100 MHz
           4: 400 MHz
Graphics:  Card-1: Intel Sky Lake Integrated Graphics bus-ID: 00:02.0
           Card-2: Advanced Micro Devices [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330]
           bus-ID: 01:00.0
           Display Server: X.Org 1.17.1 drivers: ati,radeon,intel (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.3hz
           GLX Renderer: Mesa DRI Intel Skylake ULT GT2
Audio:     Card Intel Device 9d70 driver: snd_hda_intel bus-ID: 00:1f.3
           driver: r8169 v: 2.3LK-NAPI port: 3000 bus-ID: 02:00.0
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
           Card-2: Broadcom BCM43142 802.11b/g/n driver: wl bus-ID: 03:00.0
Drives:    HDD Total Size: 500.1GB (1.9% used)
           ID-1: /dev/sda model: ST500LT012 size: 500.1GB
Partition: ID-1: / size: 454G used: 5.2G (2%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 4.19GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C gpu: N/A
Info:      Processes: 171 Uptime: 25 min Memory: 730.4/3851.2MB
« Son Düzenleme: 15 Temmuz 2016, 17:46:51 Gönderen: mehmethanifi »
Ynt: Bilgisayar kapanmıyor
« Yanıtla #1 : 15 Temmuz 2016, 17:55:10 »
Bağlantıda istenen komutun çıktısını paylaşınız.
« Yanıtla #2 : 15 Temmuz 2016, 18:04:06 »
           clock speeds: max: 2301 MHz 1: 1300 MHz 2: 700 MHz 3: 500 MHz
           4: 400 MHz
           bus-ID: 01:00.0
Partition: ID-1: / size: 454G used: 5.3G (2%) fs: ext4 dev: /dev/sda2
Info:      Processes: 166 Uptime: 20 min Memory: 627.5/3851.2MB
« Yanıtla #3 : 15 Temmuz 2016, 18:12:08 »
Öncelikle sürücü yöneticisini açıp fglrx-updates sürücüsünü kurmayı deneyiniz.
Ardından aşağıdaki komutlarla yapılandırma dosyasını oluşturunuz.
sudo aticonfig --initial
sudo aticonfig --px-igpu
Sonra Intel GPU için eksik olan bazı sembolik bağlantıları aşağıdaki komutları sırasıyla uçbirimde çalıştırarak oluşturunuz ve sistemi yeniden başlatınız
sudo mkdir -p /usr/lib/fglrx/dri/
sudo mkdir -p /usr/lib32/fglrx/dri/
sudo ln -s /usr/lib/x86_64-linux-gnu/dri/i965_dri.so /usr/lib/fglrx/dri/
sudo ln -s /usr/lib/i386-linux-gnu/dri/i965_dri.so /usr/lib32/fglrx/dri/
Bu şekilde sistem Intel GPU etkin, ATI GPU pasif olarak başlayacaktır.
Aşağıdaki komut etkin GPU'yu gösterir.
aticonfig --pxl
Aşağıdaki komut ATI GPU'yu etkinleştirir.
sudo aticonfig --px-dgpu
Aşağıdaki komut Intel GPU'yu etkinleştirir.
Her GPU değişimi sonrası sistemi yeniden başlatmanız gerekiyor. Ya da CTRL+ALT+ GERİ (BACKSPACE) tuşlarına birlikte basarak X sunucusunu yeniden başlatmak denenebilir.
Bu durumda sonucu gözlemleyiniz.
İsterseniz buradan indirebileceğiniz AMD Indicator uygulamacığını kurup GPU değişimini yapmayı deneyebilirsiniz. İndirdiğiniz sıkıştırılmış dosyayı sağ tık ile açıp içindeki .deb paketini sağ tık Gdebi ile kurabilirsiniz.
