Gönderen Konu: Nvidia-Prime Nvidia kapanmıyor  (Okunma sayısı 5006 defa)
Çevrimdışı 00burak00
  • İleti: 45
  • Dağıtım: Linux Mint 18
« : 04 Ağustos 2016, 01:07:32 »
ben nvidia-367 ve nvidia-prime yükledim ancak Nvidia Ekran kartı İntel ekran kartına geçtiğimde kapanmıyor daha önce kapandığını hatırlıyorum.
lspci -v
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor DRAM Controller (rev 06)
Subsystem: Toshiba America Info Systems Xeon E3-1200 v3/4th Gen Core Processor DRAM Controller
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel modules: ie31200_edac
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 24
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: f6000000-f70fffff
Prefetchable memory behind bridge: 00000000e0000000-00000000f1ffffff
Kernel driver in use: pcieport
Kernel modules: shpchp
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06) (prog-if 00 [VGA controller])
Subsystem: Toshiba America Info Systems 4th Gen Core Processor Integrated Graphics Controller
Flags: bus master, fast devsel, latency 0, IRQ 27
Memory at f7400000 (64-bit, non-prefetchable) [size=4M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Expansion ROM at <unassigned> [disabled]
Kernel driver in use: i915
Kernel modules: i915
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
Subsystem: Toshiba America Info Systems Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 30
Memory at f7a14000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 04) (prog-if 30 [XHCI])
Subsystem: Toshiba America Info Systems 8 Series/C220 Series Chipset Family USB xHCI
Flags: bus master, medium devsel, latency 0, IRQ 25
Memory at f7a00000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
Subsystem: Toshiba America Info Systems 8 Series/C220 Series Chipset Family MEI Controller
Flags: bus master, fast devsel, latency 0, IRQ 28
Memory at f7a1e000 (64-bit, non-prefetchable) [size=16]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 04) (prog-if 20 [EHCI])
Subsystem: Toshiba America Info Systems 8 Series/C220 Series Chipset Family USB EHCI
Flags: bus master, medium devsel, latency 0, IRQ 21
Memory at f7a1c000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 04)
Subsystem: Toshiba America Info Systems 8 Series/C220 Series Chipset High Definition Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at f7a10000 (64-bit, non-prefetchable) [size=16K]
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 16
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: cf200000-cf3fffff
Prefetchable memory behind bridge: 00000000cf400000-00000000cf5fffff
00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 18
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: f7900000-f79fffff
00:1c.3 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 (rev d4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 19
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: f7800000-f78fffff
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 04) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at f7a1b000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge: Intel Corporation HM86 Express LPC Controller (rev 04)
Subsystem: Toshiba America Info Systems HM86 Express LPC Controller
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
Subsystem: Toshiba America Info Systems 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 26
I/O ports at f0b0 [size=8]
I/O ports at f0a0 [size=4]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at f7a1a000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 04)
Subsystem: Toshiba America Info Systems 8 Series/C220 Series Chipset Family SMBus Controller
Flags: medium devsel, IRQ 4
Memory at f7a19000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
Kernel modules: i2c_i801
01:00.0 3D controller: NVIDIA Corporation GK208M [GeForce GT 740M] (rev a1)
Subsystem: Toshiba America Info Systems GK208M [GeForce GT 740M]
Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
[virtual] Expansion ROM at f7000000 [disabled] [size=512K]
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_367, nvidia_367_drm
03:00.0 Network controller: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter (rev 01)
Subsystem: Lite-On Communications Inc QCA9565 / AR9565 Wireless Network Adapter
Memory at f7900000 (64-bit, non-prefetchable) [size=512K]
Expansion ROM at f7980000 [disabled] [size=64K]
Kernel driver in use: ath9k
Kernel modules: ath9k
04:00.0 Ethernet controller: Qualcomm Atheros QCA8171 Gigabit Ethernet (rev 10)
Subsystem: Toshiba America Info Systems QCA8171 Gigabit Ethernet
Flags: bus master, fast devsel, latency 0, IRQ 31
Memory at f7800000 (64-bit, non-prefetchable) [size=256K]
I/O ports at d000 [size=128]
Kernel driver in use: alx
Kernel modules: alx
acaba bir sorun mu var ?
sudo prime-select intel
Info: the current GL alternatives in use are: ['nvidia-367-prime', 'nvidia-367-prime']
Info: the current EGL alternatives in use are: ['nvidia-367-prime', 'nvidia-367-prime']
Info: the intel profile is already in use
sudo prime-switch intel
/etc/modprobe.d is not a file
Error: can't open /lib/modules/4.4.0-21-generic/updates/dkms
update-alternatives: hata: x86_64-linux-gnu_gfxcore_conf için hiçbir alternatif bulunmuyor
initctl: Unable to connect to Upstart: Failed to connect to socket /com/ubuntu/upstart: Connection refused
rmmod: ERROR: Module nvidia_uvm is not currently loaded
rmmod: ERROR: Module nvidia_modeset is in use by: nvidia_drm
rmmod: ERROR: Module nvidia is in use by: nvidia_modeset
« Son Düzenleme: 04 Ağustos 2016, 11:26:40 Gönderen: 00burak00 »
Ynt: Nvidia-Prime Nvidia kapanmıyor
« Yanıtla #1 : 04 Ağustos 2016, 11:36:33 »
Aşağıdaki komutların çıktısını Intel ve Nvidia GPU etkinken alarak ayrı ayrı paylaşınız.
inxi -Gx
  • İleti: 45
« Yanıtla #2 : 04 Ağustos 2016, 11:37:46 »
inxi -Gx
           Card-2: NVIDIA GK208M [GeForce GT 740M] bus-ID: 01:00.0
           Display Server: X.Org 1.18.3 drivers: intel (unloaded: fbdev,vesa) FAILED: nouveau
           Resolution: 1366x768@59.96hz
« Yanıtla #3 : 04 Ağustos 2016, 12:41:18 »
Nvidia GPU etkinken istenen çıktıları paylaşmamışsınız.
Intel GPU etkinken aşağıdaki komutla nouveau sürücüsünü pasifleştirdiğinizde durum ne oluyor?
sudo rmmod nouveau
  • İleti: 45
« Yanıtla #4 : 04 Ağustos 2016, 12:43:26 »
sudo rmmod nouveau
[sudo] password for burak:
rmmod: ERROR: Module nouveau is not currently loaded
« Yanıtla #5 : 04 Ağustos 2016, 12:45:42 »
Nvidia-361 sürücüsüne dönüş yapmayı dener misiniz?
  • İleti: 45
« Yanıtla #6 : 04 Ağustos 2016, 13:17:59 »
nvidia-364 yükledim bu sürücü ile daha önce  mint 17.3 te çalışmışdı sanırım bu bug mint 18 ile ilgili
« Yanıtla #7 : 04 Ağustos 2016, 17:55:57 »
Aşağıdaki komutla grub dosyasını açınız.
sudo xed /etc/default/grub
Açılan dosyada aşağıdaki satırı bulunuz.
GRUB_CMDLINE_LINUX=""
Tırnak işaretleri arasına modprobe.blacklist=nouveau değişkenini ekleyip dosyayı kaydediniz.
GRUB_CMDLINE_LINUX="modprobe.blacklist=nouveau"
Ardından aşağıdaki komutla grub yapılandırma dosyasını güncelleyiniz ve sistemi yeniden başlatmayı deneyiniz.
sudo update-grub
