Gönderen Konu: Minecraft Crash Veriyor Yardım!  (Okunma sayısı 3972 defa)
Çevrimdışı erdem7712
  • İleti: 4
  • Dağıtım: Ubuntu
  • Masaüstü Ortamı: Bilmiyorum
  • İşlemci: İntel
« : 16 Ağustos 2016, 20:04:17 »
Minecraft TeamExtreme Crash Veriyor
Crash:---- Minecraft Crash Report ----
// I just don't know what went wrong :(
Time: 16.08.2016 20:01
Description: Initializing game
java.lang.ExceptionInInitializerError
   at bcx.ar(SourceFile:624)
   at bcx.an(SourceFile:432)
   at bcx.a(SourceFile:381)
   at net.minecraft.client.main.Main.main(SourceFile:124)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 0
   at org.lwjgl.opengl.XRandR.findPrimary(XRandR.java:326)
   at org.lwjgl.opengl.XRandR.ScreentoDisplayMode(XRandR.java:315)
   at org.lwjgl.opengl.LinuxDisplay$3.run(LinuxDisplay.java:746)
   at org.lwjgl.opengl.LinuxDisplay$3.run(LinuxDisplay.java:743)
   at java.security.AccessController.doPrivileged(Native Method)
   at org.lwjgl.opengl.LinuxDisplay.init(LinuxDisplay.java:743)
   at org.lwjgl.opengl.Display.<clinit>(Display.java:138)
   ... 4 more
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Client thread
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
   Minecraft Version: 1.10.2
   Operating System: Linux (amd64) version 3.19.0-32-generic
   Java Version: 1.7.0_80, Oracle Corporation
   Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
   Memory: 51210304 bytes (48 MB) / 151728128 bytes (144 MB) up to 1060372480 bytes (1011 MB)
   JVM Flags: 5 total; -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
   IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
   Launched Version: 1.10.2
   LWJGL: 2.9.4
   OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
   GL Caps:
   Using VBOs: Yes
   Is Modded: Probably not. Jar signature remains and client brand is untouched.
   Type: Client (map_client.txt)
   Resource Packs:
   Current Language: ~~ERROR~~ NullPointerException: null
   Profiler Position: N/A (disabled)
   CPU: <unknown>
Ynt: Minecraft Crash Veriyor Yardım!
« Yanıtla #1 : 16 Ağustos 2016, 22:32:54 »
Açtığınız konularda daha fazla bilgi paylaşınız.
Minecraft uygulamasını nasıl kurdunuz?
Ayrıca aşağıdaki konuda istenen komutun çıktısını paylaşınız.
