Gönderen Konu: .Net Framework 3.0 Sorunu  (Okunma sayısı 5889 defa)
Çevrimdışı özgürpenguen
  • İleti: 54
  • Dağıtım: KDE Neon
  • Grafik Kartı: NVIDIA GeForce 920M
  • İşlemci: Intel® Core™ i3-5015U
« : 05 Mayıs 2014, 08:50:55 »
winetricks dotnet30 çıktısı:
Executing w_do_call dotnet35
Executing load_dotnet35
dotnet35 does not yet fully work or install on wine.  Caveat emptor.
Executing w_do_call dotnet30sp1
Executing load_dotnet30sp1
dotnet30sp1 does not yet fully work or install on wine.  Caveat emptor.
If install fails, set /proc/sys/kernel/yama/ptrace_scope to 0.  See http://bugs.winehq.org/show_bug.cgi?id=30410
Executing w_do_call dotnet20
dotnet20 already installed, skipping
Installing .net 3.0 runtime takes 3 minutes on a very fast machine, and the Finished dialog may hide in the taskbar.
Setting Windows version to winxp
Executing winetricks_early_wine regedit C:\windows\Temp\_dotnet30\set-winver.reg
Current wine does not have wine bug 30845, so not applying workaround
Executing wine netframework3.exe
fixme:clusapi:GetNodeClusterState ((null),0x33ec04) stub!
fixme:advapi:DecryptFileA "d:\\d1f2cc526ba01ca25f1a\\" 00000000
fixme:ntdll:find_reg_tz_info Can't find matching timezone information in the registry for bias -120, std (d/m/y): 26/10/2014, dlt (d/m/y): 31/03/2014
fixme:ole:CoInitializeSecurity ((nil),-1,(nil),(nil),0,3,(nil),0,(nil)) - stub!
fixme:advapi:LsaOpenPolicy ((null),0x33ef78,0x00000001,0x33ef94) stub
fixme:advapi:LsaClose (0xcafe) stub
fixme:advapi:LsaOpenPolicy ((null),0x33e618,0x00000001,0x33e640) stub
fixme:ngen:wmain stub: L"C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\ngen.exe" L"queue" L"pause"
fixme:advapi:LsaOpenPolicy ((null),0x33dd88,0x00000001,0x33ddb0) stub
fixme:storage:create_storagefile Storage share mode not implemented.
err:msi:msi_load_all_components can't initialize assembly caches
fixme:msi:MsiGetFeatureValidStatesW 1 L"WAP_1.0_Core" 0x33aaf4 stub returning 8
fixme:msi:MsiGetFeatureValidStatesW 1 L"Servicing_Key" 0x33aaf4 stub returning 8
err:richedit:ReadStyleSheet skipping optional destination
fixme:advapi:LsaOpenPolicy ((null),0x33d0bc,0x00000001,0x33d0e4) stub
fixme:imm:ImmDisableIME (-1): stub
err:ole:CoInitializeEx Attempt to change threading model of this apartment from multi-threaded to apartment threaded
fixme:richedit:ME_HandleMessage EM_SETMARGINS: stub
err:ole:CoUninitialize Mismatched CoUninitialize
fixme:wininet:CommitUrlCacheEntryInternal file of size 29 bytes fills cache
err:ole:CoRevokeClassObject called from wrong apartment, should be called from 1300000012
fixme:ngen:wmain stub: L"C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\ngen.exe" L"queue" L"continue"
Note: command 'wine netframework3.exe' returned status 67.  Aborting.
Ynt: .Net Framework 3.0 Sorunu
« Yanıtla #1 : 05 Mayıs 2014, 09:26:55 »
Framework 3.0 hakkında
https://appdb.winehq.org/objectManager.php?sClass=version&iId=9828
burada bir çok hata bildirimi geçilmiş sanırım diğer taraftan kaynaklanan bir sorun. Gördüğüm kadarıyla Ubuntu tarafında sorun yaratırken Fedora ve Sabayon tarafında başarıyla kurulmuş.
