Gönderen Konu: Mint 16 Cinnamon üç günlük kullanım sonucunda açılmaz hale geldi/getirdim...  (Okunma sayısı 21749 defa)
Çevrimdışı someanon
  • İleti: 25
  • Dağıtım: LM 16 Cinnamon 64
sanon@sanon-VPCF13S0E ~ $ wget -c http://goo.gl/x4JYAz -O kernel-3.13
--2014-03-08 21:29:20--  http://goo.gl/x4JYAz
Resolving goo.gl (goo.gl)... 173.194.113.169, 173.194.113.164, 173.194.113.160, ...
Connecting to goo.gl (goo.gl)|173.194.113.169|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://dl.dropboxusercontent.com/u/47950494/upubuntu/kernel-3.13 [following]
--2014-03-08 21:29:20--  https://dl.dropboxusercontent.com/u/47950494/upubuntu/kernel-3.13
Resolving dl.dropboxusercontent.com (dl.dropboxusercontent.com)... 54.225.181.95
Connecting to dl.dropboxusercontent.com (dl.dropboxusercontent.com)|54.225.181.95|:443... connected.
HTTP request sent, awaiting response... 206 PARTIAL CONTENT
Length: 1399 (1,4K), 0 remaining [application/octet-stream]
Saving to: ‘kernel-3.13’
100%[++++++++++++++++++++++++++++++++++++++++++++++++++++++] 1.399       --.-K/s   in 0s
2014-03-08 21:29:21 (0,00 B/s) - ‘kernel-3.13’ saved [1399/1399]
sanon@sanon-VPCF13S0E ~ $ chmod +x kernel-3.13
sanon@sanon-VPCF13S0E ~ $ sudo sh kernel-3.13
[sudo] password for sanon:
--- Kernel 3.13 will be installed in an x86_64 system---
Press Enter to continue, or abort by pressing CTRL+C
--2014-03-08 21:30:15--  http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.13-trusty/linux-headers-3.13.0-031300_3.13.0-031300.201401192235_all.deb
Resolving kernel.ubuntu.com (kernel.ubuntu.com)... 91.189.94.216
Connecting to kernel.ubuntu.com (kernel.ubuntu.com)|91.189.94.216|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 12736074 (12M) [application/x-debian-package]
Saving to: ‘linux-headers-3.13.0-031300_3.13.0-031300.201401192235_all.deb’
100%[=====================================================>] 12.736.074   580KB/s   in 21s
2014-03-08 21:30:36 (601 KB/s) - ‘linux-headers-3.13.0-031300_3.13.0-031300.201401192235_all.deb’ saved [12736074/12736074]
--2014-03-08 21:30:36--  http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.13-trusty/linux-headers-3.13.0-031300-generic_3.13.0-031300.201401192235_amd64.deb
Length: 1096366 (1,0M) [application/x-debian-package]
Saving to: ‘linux-headers-3.13.0-031300-generic_3.13.0-031300.201401192235_amd64.deb’
100%[=====================================================>] 1.096.366    438KB/s   in 2,4s
2014-03-08 21:30:38 (438 KB/s) - ‘linux-headers-3.13.0-031300-generic_3.13.0-031300.201401192235_amd64.deb’ saved [1096366/1096366]
--2014-03-08 21:30:38--  http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.13-trusty/linux-image-3.13.0-031300-generic_3.13.0-031300.201401192235_amd64.deb
Length: 51630150 (49M) [application/x-debian-package]
Saving to: ‘linux-image-3.13.0-031300-generic_3.13.0-031300.201401192235_amd64.deb’
100%[=====================================================>] 51.630.150   617KB/s   in 84s
2014-03-08 21:32:03 (599 KB/s) - ‘linux-image-3.13.0-031300-generic_3.13.0-031300.201401192235_amd64.deb’ saved [51630150/51630150]
(Reading database ... 201609 files and directories currently installed.)
Preparing to replace linux-headers-3.13.0-031300-generic 3.13.0-031300.201401192235 (using linux-headers-3.13.0-031300-generic_3.13.0-031300.201401192235_amd64.deb) ...
Unpacking replacement linux-headers-3.13.0-031300-generic ...
Preparing to replace linux-headers-3.13.0-031300 3.13.0-031300.201401192235 (using linux-headers-3.13.0-031300_3.13.0-031300.201401192235_all.deb) ...
Unpacking replacement linux-headers-3.13.0-031300 ...
Selecting previously unselected package linux-image-3.13.0-031300-generic.
Unpacking linux-image-3.13.0-031300-generic (from linux-image-3.13.0-031300-generic_3.13.0-031300.201401192235_amd64.deb) ...
Done.
Setting up linux-headers-3.13.0-031300 (3.13.0-031300.201401192235) ...
Setting up linux-image-3.13.0-031300-generic (3.13.0-031300.201401192235) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-031300-generic /boot/vmlinuz-3.13.0-031300-generic
run-parts: executing /etc/kernel/postinst.d/dkms 3.13.0-031300-generic /boot/vmlinuz-3.13.0-031300-generic
Error! Bad return status for module build on kernel: 3.13.0-031300-generic (x86_64)
Consult /var/lib/dkms/virtualbox-guest/4.2.16/build/make.log for more information.
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-031300-generic /boot/vmlinuz-3.13.0-031300-generic
update-initramfs: Generating /boot/initrd.img-3.13.0-031300-generic
Warning: No support for locale: en_US.utf8
run-parts: executing /etc/kernel/postinst.d/pm-utils 3.13.0-031300-generic /boot/vmlinuz-3.13.0-031300-generic
run-parts: executing /etc/kernel/postinst.d/zz-update-grub 3.13.0-031300-generic /boot/vmlinuz-3.13.0-031300-generic
Generating grub.cfg ...
Found linux image: /boot/vmlinuz-3.13.0-031300-generic
Found initrd image: /boot/initrd.img-3.13.0-031300-generic
Found linux image: /boot/vmlinuz-3.11.0-12-generic
Found initrd image: /boot/initrd.img-3.11.0-12-generic
  No volume groups found
Found Windows Recovery Environment (loader) on /dev/sda1
Found Windows 7 (loader) on /dev/sda2
done
Setting up linux-headers-3.13.0-031300-generic (3.13.0-031300.201401192235) ...
Examining /etc/kernel/header_postinst.d.
run-parts: executing /etc/kernel/header_postinst.d/dkms 3.13.0-031300-generic /boot/vmlinuz-3.13.0-031300-generic
Çevrimdışı someanon
  • İleti: 25
Laptop'un fanını temizledim iki gün önce. Bu şekilde biraz denemek istedim fakat gene birkaç kez kapanma sorunu yaşadım. Çıkan hava eskisi kadar sıcak olmasa da fanın devri yükselince bir süre sonra sistem kapanıyor.
Yukarıda da biraz önce yaptığım çekirdek yükseltme işlemiyle ilgili çıktıyı paylaştım. Sonlara doğru bir hata var...
Çevrimdışı someanon
  • İleti: 25
Şu anda nvidia-331 (331.49-0ubuntu1-xedgers13.10.3) sürücüsünü kullanıyorum.
Yeni çekirdek kurulumunda Virtualbox ile ilgili bir sorun oluşmuş. Virtulabox'ı kadırıp yeni çekirdeği bu şekilde kurmanızı öneririm. Bununla ilgili uyarıyı yapmıştım hatırlarsanız.
(Not : Sistemde Virtualbox kuruluysa çekirdek güncellemesi öncesi kaldırmanızı öneriririm.)
Çevrimdışı someanon
  • İleti: 25
Sistemime Virtualbox yüklemedim. LM16 kurulurken geliyorsa bilmiyordum... Şu anda nasıl kaldıracağımı da bilmiyorum; programlar içinde bulamadım.
Çevrimdışı someanon
  • İleti: 25
Ekran görüntüsündeki 3 paketi kaldırıp sonrasında da aynı çekirdek yükseltme komutlarını tekrar uygulamam mı gerekiyor?
Aşağıdaki komut ile kaldırmayı deneyiniz.
sudo apt-get purge virtualbox-guest*
Çevrimdışı someanon
  • İleti: 25
Virtualbox'u verdiğiniz komutla kaldırdıktan sonra önceden vermiş olduğunuz 3 komutu kullanarak tekrar çekirdek güncellemesi yaptım; sanırım bu sefer bir sorun oluşmadı:
--2014-03-09 03:01:32--  http://goo.gl/x4JYAz
Resolving goo.gl (goo.gl)... 173.194.113.167, 173.194.113.162, 173.194.113.160, ...
Connecting to goo.gl (goo.gl)|173.194.113.167|:80... connected.
--2014-03-09 03:01:32--  https://dl.dropboxusercontent.com/u/47950494/upubuntu/kernel-3.13
Resolving dl.dropboxusercontent.com (dl.dropboxusercontent.com)... 50.17.227.107
Connecting to dl.dropboxusercontent.com (dl.dropboxusercontent.com)|50.17.227.107|:443... connected.
100%[+++++++++++++++++++++++++++++++++++++++++++++++++++++++] 1.399       --.-K/s   in 0s
2014-03-09 03:01:33 (0,00 B/s) - ‘kernel-3.13’ saved [1399/1399]
--2014-03-09 03:02:04--  http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.13-trusty/linux-headers-3.13.0-031300_3.13.0-031300.201401192235_all.deb
100%[============================================================================================>] 12.736.074   618KB/s   in 20s
2014-03-09 03:02:24 (617 KB/s) - ‘linux-headers-3.13.0-031300_3.13.0-031300.201401192235_all.deb’ saved [12736074/12736074]
--2014-03-09 03:02:24--  http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.13-trusty/linux-headers-3.13.0-031300-generic_3.13.0-031300.201401192235_amd64.deb
100%[============================================================================================>] 1.096.366    599KB/s   in 1,8s
2014-03-09 03:02:26 (599 KB/s) - ‘linux-headers-3.13.0-031300-generic_3.13.0-031300.201401192235_amd64.deb’ saved [1096366/1096366]
--2014-03-09 03:02:26--  http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.13-trusty/linux-image-3.13.0-031300-generic_3.13.0-031300.201401192235_amd64.deb
100%[============================================================================================>] 51.630.150   618KB/s   in 82s
2014-03-09 03:03:48 (618 KB/s) - ‘linux-image-3.13.0-031300-generic_3.13.0-031300.201401192235_amd64.deb’ saved [51630150/51630150]
(Reading database ... 206236 files and directories currently installed.)
Preparing to replace linux-image-3.13.0-031300-generic 3.13.0-031300.201401192235 (using linux-image-3.13.0-031300-generic_3.13.0-031300.201401192235_amd64.deb) ...
Done.
Unpacking replacement linux-image-3.13.0-031300-generic ...
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.13.0-031300-generic /boot/vmlinuz-3.13.0-031300-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.13.0-031300-generic /boot/vmlinuz-3.13.0-031300-generic
Running depmod.
Not updating initrd symbolic links since we are being updated/reinstalled
(3.13.0-031300.201401192235 was configured last, according to dpkg)
Not updating image symbolic links since we are being updated/reinstalled
done
Yeni çekirdek ile durumda bir değiiklik oldu mu?
Aşağıdaki komutların çıktılarını da paylaşır mısınız?
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
Sisteminizdeki BIOS güncel mi? Değilse ve güncelleme imkanınız varsa güncellemeyi deneyebilirsiniz.
Çevrimdışı someanon
  • İleti: 25
Yeteri kadar kullanıp test edemedim ama kullandığım süre içerisinde ısınma kaynaklı kapanma yaşamadım ve bilgisayarı kapatırken de daha önce yaşadığım kapanmama sorununu yaşamadım.
BIOS'umla ilgili bilgisayarı aldığımdan beri (kabaca 2 yıl) herhangi bir değişiklik yapmadım; herhalde güncel değildir. BIOS güncelleme konusunda bir tecrübem yok. Biraz araştırma yapıp altından kalkabileceğimi düşünürsem denerim. Tavsiye ettiğiniz bir kaynak var mı bu konuda?
Yazdığınız komutların çıktısı:
sanon@sanon-VPCF13S0E ~ $ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
1734000 1733000 1599000 1466000 1333000 1199000 1066000 933000
sanon@sanon-VPCF13S0E ~ $ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors
conservative ondemand userspace powersave performance
sanon@sanon-VPCF13S0E ~ $ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
ondemand
Aşağıdaki komut ile CPU kullanma yöntemini powersave olarak değiştirmeyi deneyebilirsiniz.
su
echo powersave >  /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
Şu an için sanırım sorun çözülmüş görünüyor. BIOS'u Windows altında güncellemenizi öneririm.
Çoğu markanın görsel BIOS güncelleme yazılımları bulunuyor. Bunlar ile BIOS güncelleme artık oldukça kolay.
Ama PC konusunda tecrübeli bir tanıdığınız varsa güncelleme işlemini onun gözetiminde yapmanız en makulu olabilir.
