Gönderen Konu: Bumblebee Nvidia GPU Seçim Hatası - [XORG] (EE) Failed to load module  (Okunma sayısı 11487 defa)
Çevrimdışı ahme_t
  • İleti: 13
  • Dağıtım: Linux Mint 18
  • Grafik Kartı: Nvidia 840M
  • İşlemci: İntel İ5
Merhabalar linuxde çok yeniyim.
kurulum yaparken [XORG] (EE) Failed to load module "mouse" (module does not exist, 0) hatsı alıyorum çözümünü bulamadım yardımcı olursanız sevinirim.
optirun -vvv glxgears
[ 1958.537502] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 1958.537968] [INFO]Configured driver: nvidia
[ 1958.538237] [DEBUG]optirun version 3.2.1 starting...
[ 1958.538266] [DEBUG]Active configuration:
[ 1958.538287] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 1958.538306] [DEBUG] X display: :8
[ 1958.538320] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-370:/usr/lib32/nvidia-370
[ 1958.538331] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 1958.538339] [DEBUG] Accel/display bridge: auto
[ 1958.538353] [DEBUG] VGL Compression: proxy
[ 1958.538363] [DEBUG] VGLrun extra options:
[ 1958.538378] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 1958.538460] [DEBUG]Using auto-detected bridge virtualgl
[ 1958.850852] [INFO]Response: No - error: [XORG] (EE) Failed to load module "mouse" (module does not exist, 0)
[ 1958.850869] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) Failed to load module "mouse" (module does not exist, 0)
[ 1958.850874] [DEBUG]Socket closed.
[ 1958.850888] [ERROR]Aborting because fallback start is disabled.
[ 1958.850891] [DEBUG]Killing all remaining processes.
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=nvidia
# Xorg binary to run
XorgBinary=/usr/lib/xorg/Xorg
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
[driver-nvidia]
KernelDriver=nvidia-370
PMMethod=auto
LibraryPath=/usr/lib/nvidia-370:/usr/lib32/nvidia-370
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia-370/xorg,/usr/lib/xorg/modules
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
Section "ServerLayout"
    Identifier  "Layout0"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
    BusID "PCI:0a:00:0"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
Section "Screen"
    Identifier "Default Screen"
    Device "DiscreteNvidia"
ii  bumblebee                                    3.2.1-96~xenialppa1                        amd64        NVIDIA Optimus support for Linux
ii  nvidia-370                                   370.28-0ubuntu0~gpu16.04.2                 amd64        NVIDIA binary driver - version 370.28
ii  nvidia-modprobe                              361.28-1                                   amd64        utility to load NVIDIA kernel modules and create device nodes
ii  nvidia-opencl-icd-370                        370.28-0ubuntu0~gpu16.04.2                 amd64        NVIDIA OpenCL ICD
ii  nvidia-settings                              370.28-0ubuntu0~gpu16.04.1                 amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                       20150328-3~xenialppa1                      amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                            20150328-3~xenialppa1                      amd64        Shared libraries for primus
ii  primus-libs:i386                             20150328-3~xenialppa1                      i386         Shared libraries for primus
ii  primus-libs-ia32:i386                        20150328-3~xenialppa1                      i386         Shared libraries for primus (32-bit)
0a:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 840M] (rev a2)
Bir kaç önceki mesajda çözümü mevcut, lütfen aldığınız hataya göre forum içi arama yapmayı ihmal etmeyiniz.
https://forum.linuxmint.net.tr/index.php?topic=6258.msg43120#msg43120
Çevrimdışı ahme_t
  • İleti: 13
  • İşlemci: İntel İ5
maalesef o yolu daha önce  denemiştim ama çözüme ulaşamadım.
ilginiz için teşekkürler
    Driver      "nvidia"
    BusID "PCI:0a:00:0"
Section "Screen"
Aynı sorun benim sistemimde de mevcuttu, öneri ile çözülüyor. Hatta ilgili satırları dosyadan silince aynı hatayı alıyorum. Aşağıdaki komutla Bumblebeee servisini yeniden başlatmayı deneyebilirsiniz.
Sorun çözülmezse satırlar ekli olduğu halde aşağıdaki komutun çıktısını yeniden paylaşınız.
Çevrimdışı ahme_t
  • İleti: 13
  • İşlemci: İntel İ5
malesef ilgili satırlar olmasına rağmen hala aynı hatayı almaya devam ediyorum.
nvidia-370 sürücüsünü kullanıyorum 367 364 361 sürücülerinide ilgili yerleri değiştirerek denedim nedense sonuç aynı
biyerde hata yapıyorum ama bulamadım bi türlü  :)
İLginiz için teşekkürler
[20870.691068] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[20870.691311] [INFO]Configured driver: nvidia
[20870.691502] [DEBUG]optirun version 3.2.1 starting...
[20870.691511] [DEBUG]Active configuration:
[20870.691519] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[20870.691525] [DEBUG] X display: :8
[20870.691535] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-370:/usr/lib32/nvidia-370
[20870.691543] [DEBUG] Socket path: /var/run/bumblebee.socket
[20870.691548] [DEBUG] Accel/display bridge: auto
[20870.691555] [DEBUG] VGL Compression: proxy
[20870.691561] [DEBUG] VGLrun extra options:
[20870.691568] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[20870.691640] [DEBUG]Using auto-detected bridge virtualgl
[20889.595163] [INFO]Response: No - error: [XORG] (EE) Failed to load module "mouse" (module does not exist, 0)
[20889.595182] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) Failed to load module "mouse" (module does not exist, 0)
[20889.595186] [DEBUG]Socket closed.
[20889.595203] [ERROR]Aborting because fallback start is disabled.
[20889.595206] [DEBUG]Killing all remaining processes.
dpkg -l | grep xserver-xorg-legacy
Çevrimdışı ahme_t
  • İleti: 13
  • İşlemci: İntel İ5
Bu çıktıyı alıyorum
ii  xserver-xorg-legacy                          2:1.18.4-0ubuntu0.1                        amd64        setuid root Xorg server wrapper
« Son Düzenleme: 24 Ekim 2016, 22:01:52 Gönderen: ahme_t »
Aşağıdaki komutla xserver-xorg-legacy paketini kaldırıp sistemi yeniden başlatmayı deneyiniz.
sudo apt-get purge xserver-xorg-legacy
Çevrimdışı ahme_t
  • İleti: 13
  • İşlemci: İntel İ5
malesef yine olmadı
linuxminti yeniden kurdum 361 370 arası tüm srücüleri tek tek denedim sonuç aynı malesef  :(
/etc/bumblebee/xorg.conf.nvidia  dosyasını açıp, aşağıdaki satırı silip
yerine girintilere dikkat ederek aşağıdaki satırı eklemeyi dener misiniz?
    Option "ConnectedMonitor" "DFP"
Aşağıdaki gibi olacak.
Çevrimdışı ahme_t
  • İleti: 13
  • İşlemci: İntel İ5
Emekleriniz için çok teşekkür ederim ama malesef sonuç aynı
sudo nano /etc/bumblebee/xorg.conf.nvidia
    Driver      "nvidia"
    BusID "PCI:0a:00:0"
Section "Screen"
# to take effect.
[bumblebeed]
VirtualDisplay=:8
# server exits.
# be ignored.
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
[driver-nvidia]
PMMethod=auto
[driver-nouveau]
PMMethod=auto
rc  nvidia-361                                   361.45.18-0ubuntu0~gpu16.04.1              amd64        NVIDIA binary driver - version 361.45.18
[  197.280963] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[  197.281608] [INFO]Configured driver: nvidia
[  197.281928] [DEBUG]optirun version 3.2.1 starting...
[  197.281953] [DEBUG]Active configuration:
[  197.281968] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[  197.281984] [DEBUG] X display: :8
[  197.281996] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-370:/usr/lib32/nvidia-370
[  197.282011] [DEBUG] Socket path: /var/run/bumblebee.socket
[  197.282025] [DEBUG] Accel/display bridge: auto
[  197.282039] [DEBUG] VGL Compression: proxy
[  197.282054] [DEBUG] VGLrun extra options:
[  197.282068] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[  197.282157] [DEBUG]Using auto-detected bridge virtualgl
[  197.578840] [INFO]Response: No - error: [XORG] (EE) Failed to load module "mouse" (module does not exist, 0)
[  197.578857] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) Failed to load module "mouse" (module does not exist, 0)
[  197.578862] [DEBUG]Socket closed.
[  197.578878] [ERROR]Aborting because fallback start is disabled.
[  197.578882] [DEBUG]Killing all remaining processes.
Aşağıdaki satırları /etc/bumblebee/xorg.conf.nvidia dosyasından silmeyi dener misiniz?
Section "Screen"
Çevrimdışı ahme_t
  • İleti: 13
  • İşlemci: İntel İ5
ilginiz için çok teşekkürler ama malesef hala sonuç aynı
[  102.305782] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[  102.306007] [INFO]Configured driver: nvidia
[  102.306090] [DEBUG]optirun version 3.2.1 starting...
[  102.306102] [DEBUG]Active configuration:
[  102.306107] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[  102.306113] [DEBUG] X display: :8
[  102.306119] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-370:/usr/lib32/nvidia-370
[  102.306126] [DEBUG] Socket path: /var/run/bumblebee.socket
[  102.306131] [DEBUG] Accel/display bridge: auto
[  102.306138] [DEBUG] VGL Compression: proxy
[  102.306142] [DEBUG] VGLrun extra options:
[  102.306147] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[  102.306176] [DEBUG]Using auto-detected bridge virtualgl
[  102.607099] [INFO]Response: No - error: [XORG] (EE) Failed to load module "mouse" (module does not exist, 0)
[  102.607114] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) Failed to load module "mouse" (module does not exist, 0)
[  102.607119] [DEBUG]Socket closed.
[  102.607133] [ERROR]Aborting because fallback start is disabled.
[  102.607137] [DEBUG]Killing all remaining processes.
Intel GPU ile ilgili yapılandırma dosyası oluşturdunuz mu hiç, aşağıdaki komutların çıktısına bakalım.
ls /usr/share/X11/xorg.conf.d/
Çevrimdışı ahme_t
  • İleti: 13
  • İşlemci: İntel İ5
malesef yapıp yapmadığımı bilmiyorum. işlem basamaklarını harfiyyen uyguladım sadece
10-amdgpu.conf        11-evdev-trackpoint.conf        50-wacom.conf
10-evdev.conf         50-nvidia-drm-outputclass.conf  51-synaptics-quirks.conf
10-quirks.conf        50-synaptics.conf               glamoregl.conf
11-evdev-quirks.conf  50-vmmouse.conf
