Yukarıda anlatıldığı gibi grub'u tekrar kurduktan sonra deneyebilir misiniz ?
Boot repair aracini calisitirinca su hatayi veriyor hocam.
The current session is in Legacy mode. Please reboot the computer, and use this software in an EFI session. This will enable this feature. For example, use a live-USB of Boot-Repair-Disk-64bit (
www.sourceforge.net/p/boot-repair-cd), after making sure your BIOS is set up to boot USB in EFI mode.
Grubu ucbirim ile kurmayi deniyorum bu hatayi aliyorum ayrica.
grub-install.real: warning: this GPT partition label contains no BIOS Boot Partition; embedding won't be possible.
grub-install.real: warning: Embedding is not possible. GRUB can only be installed in this setup by using blocklists. However, blocklists are UNRELIABLE and their use is discouraged..
grub-install.real: error: will not proceed with blocklists.
