Gönderen Konu: Bumblebee Cs:Go Başlatma ve FPS Sorunu  (Okunma sayısı 8049 defa)
Çevrimdışı EmrahSakaci
  • İleti: 6
    • emrahsakaci
  • Dağıtım: Linux Mint 18.1
  • Masaüstü Ortamı: Cinnamon 64-bit
  • Grafik Kartı: GeForce GT 540M
  • İşlemci: İntel Core İ5-2430M @ 2,4 GHZ*2
« : 10 Şubat 2017, 14:07:25 »
optirun -vvv glxgears
[ 1105.307348] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 1105.307910] [INFO]Configured driver: nvidia
[ 1105.308201] [DEBUG]optirun version 3.2.1 starting...
[ 1105.308214] [DEBUG]Active configuration:
[ 1105.308218] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 1105.308222] [DEBUG] X display: :8
[ 1105.308226] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-378:/usr/lib32/nvidia-378
[ 1105.308231] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 1105.308235] [DEBUG] Accel/display bridge: auto
[ 1105.308239] [DEBUG] VGL Compression: proxy
[ 1105.308242] [DEBUG] VGLrun extra options:
[ 1105.308249] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 1105.308348] [DEBUG]Using auto-detected bridge virtualgl
[ 1105.309114] [INFO]Response: Yes. X is active.
[ 1105.309142] [INFO]Running application using virtualgl.
[ 1105.309301] [DEBUG]Process vglrun started, PID 3778.
4580 frames in 5.0 seconds = 915.826 FPS
4727 frames in 5.0 seconds = 945.373 FPS
4563 frames in 5.0 seconds = 912.588 FPS
4676 frames in 5.0 seconds = 935.029 FPS
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=nvidia
# Xorg binary to run
XorgBinary=/usr/lib/xorg/Xorg
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
[driver-nvidia]
KernelDriver=nvidia-378
PMMethod=auto
LibraryPath=/usr/lib/nvidia-378:/usr/lib32/nvidia-378
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia-378/xorg,/usr/lib/xorg/modules
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
Section "ServerLayout"
    Identifier  "Layout0"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
    BusID "PCI:01:00:0"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
ii  bumblebee                                   3.2.1-96~xenialppa1                                    amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                            3.2.1-96~xenialppa1                                    amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-378                                  378.09-0ubuntu0~gpu16.04.1                             amd64        NVIDIA binary driver - version 378.09
ii  nvidia-settings                             378.09-0ubuntu0~gpu16.04.1                             amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                      20150328-3~xenialppa1                                  amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                           20150328-3~xenialppa1                                  amd64        Shared libraries for primus
ii  primus-libs:i386                            20150328-3~xenialppa1                                  i386         Shared libraries for primus
ii  primus-libs-ia32:i386                       20150328-3~xenialppa1                                  i386         Shared libraries for primus (32-bit)
ii  virtualgl                                   2.4.1-1~xenialppa1                                     amd64        Toolkit for displaying OpenGL applications to thin clients
ii  virtualgl-libs:amd64                        2.4.1-1~xenialppa1                                     amd64        Library files for virtualgl
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 540M] (rev a1
glxspheres64
Polygons in scene: 62464 (61 spheres * 1024 polys/spheres)
Visual ID of window: 0xa7
Context is Direct
OpenGL Renderer: Mesa DRI Intel(R) Sandybridge Mobile
60.643920 frames/sec - 53.766899 Mpixels/sec
60.139711 frames/sec - 53.319868 Mpixels/sec
60.200069 frames/sec - 53.373381 Mpixels/sec
optirun glxspheres64
Visual ID of window: 0x20
Context is Direct
OpenGL Renderer: GeForce GT 540M/PCIe/SSE2
179.555617 frames/sec - 159.194010 Mpixels/sec
178.204756 frames/sec - 157.996336 Mpixels/sec
vblank_mode=0 glxspheres64
ATTENTION: default value of option vblank_mode overridden by environment.
Context is Direct
179.991804 frames/sec - 159.580733 Mpixels/sec
162.924387 frames/sec - 144.448762 Mpixels/sec
vblank_mode=0 optirun glxspheres64
Context is Direct
184.669257 frames/sec - 163.727764 Mpixels/sec
182.090045 frames/sec - 161.441034 Mpixels/sec
187.027404 frames/sec - 165.818497 Mpixels/sec
181.691074 frames/sec - 161.087306 Mpixels/sec
Cs:Go gelişmiş açılış seçeneklerinde  vblank_mode=0 optirun -b primus %command%    kodu girili
Öncelikle merhabalar.  Forumda girip çıkmadığım kontrol etmediğim konu kalmadı benim sorunuma yakın sorunları olan arkadaşları inceledim fakat olmuyor. Cs:Go'ya hala girmeye çalıştığım zaman OpenGL ile açılıyor oyun ve max 118 fps offline modda ve max 40 fps online modda alıyorum bu sizce normal mi.? Nvidia ile oyuna neden giremiyorum? yani primusrun kodu ile 945 fps alabilirken oyuna girince bu kadar düşmesi normalmidir acaba? Birisi yardımcı olursa cidden çok mutlu olurum.
« Son Düzenleme: 10 Şubat 2017, 16:01:16 Gönderen: EmrahSakaci »
Ynt: Bumblebee Cs:Go Başlatma ve FPS Sorunu
« Yanıtla #1 : 10 Şubat 2017, 17:54:12 »
Primusrun komutu ile çalışan primus köprüsü dikey senkronizasyon (vsync) etkin olarak çalıştığından FPS değerlerini sınırlıyor olabilir.
  • İleti: 6
    • emrahsakaci
« Yanıtla #2 : 10 Şubat 2017, 18:09:16 »
Peki ne yapmamı önerirsiniz.? Yeni Linux kullanıcısıyım pek bilmiyorum. Gezinmediğim forum kalmadı kendi web sitesini de araştırdım fakat bir sonuç elde edemiyorum. Bir yerde bir sorun var ve bulamıyorum. Hangi komutu verirsem vereyim OpenGL ile açıyor oyunu.
« Yanıtla #3 : 10 Şubat 2017, 19:42:04 »
Zaten OpenGL ile mecburen açacak.Linux'ta OpenGL ve Vulkan apı ları var.Windows'ta ise DirectX,OpenGL ve Vulkan var.
Optirun değilde Primusrun şeklinde açmayı dener misiniz?
  • İleti: 6
    • emrahsakaci
« Yanıtla #4 : 10 Şubat 2017, 21:13:16 »
Şöyle ki ben steami optirun ile açınca özelliklerden kontrol edince OpenGL'yi görüyor primusrun ile açınca Nvidia ile açıyor. Ordan da kütüphaneden Cs:Go gelişmiş açma seçeneklerinde vblank_mode=0 optirun -b primus %command%  işli direk aç dediğim zaman OpenGL ile açıyor ve düşük fps alıyorum. Ne yapıcağımı bulamadım bir türlü kafayı yiycem kurcalarken yine Cinnamon çöktü forumda bahsedildiği üzere bumblebee'yi sildim şimdi tekrar adım adım baştan yüklüycem Nvidia 378 driver ile birlite bakalım ne olucak.
« Yanıtla #5 : 10 Şubat 2017, 21:34:48 »
Anlatamadım sanırım,oyun OpenGL api kullanıyor.OpenGL ile yine açtı tabiri yanlış.
Intel ile açıyor demeye çalışıyorsunuz tahminen.
Büyük ihtimal 378 driver ile düzelir.
  • İleti: 6
    • emrahsakaci
« Yanıtla #6 : 10 Şubat 2017, 21:44:14 »
Mazur görün kaç gündür uğraşıyorum dikkatimi topluyamıyorum inat ettim resmen ama kalkamadım başından evet intel ile açıyor fakat zaten nvidia-378 kuruluydu. Şimdi tekrar adım adım sil baştan yaptım herşeyi atlamadan sıkıntısız kurdum şuan glxgears değerlerini alıyorum tekrardan fakat nvidia x settings bende herkesinkinden çok farklı bakalım bu sefer ne olucak. Aslına bakarsanız ben sanırım sıkıntı mı tam olarak aktaramıyorum. Benim sıkıntım şu ki ben ne zaman herhangi bir oyun açmak istesem İntel ile açabiliyorum Nvidia ile açılış yapamıyorum. Tam olarak sorunum bu.
« Yanıtla #7 : 10 Şubat 2017, 22:03:05 »
Acaba 378 daha beta olduğu için olabilir mi?En son betadaydı daha 2 hafta önce,çıktıysa bilmiyorum ama Nvidia sitesinden baktım,daha en son 375.26 görünüyor
367 veya 370 i kurmayı dener misiniz?
  • İleti: 6
    • emrahsakaci
« Yanıtla #8 : 10 Şubat 2017, 22:20:00 »
Tabi ki de hemen deneyip size dönücem.
30 fps kafayı yemek üzereyim. Yanlış anlamayın cidden sadece kendime kızıyorum çünkü anlamıyorum yani. Bişey sormak istiyorum size hangi ekran kartıyla oyunu açıp açmadığını nasıl anlıyabilirim.?
« Son Düzenleme: 10 Şubat 2017, 23:13:57 Gönderen: EmrahSakaci »
« Yanıtla #9 : 11 Şubat 2017, 14:08:41 »
[member=4481]EmrahSakaci[/member] İlginç,diğer arkadaşlarda bu işe yarıyordu.
Son olarak Nvidia Prime'ı deneyin,forumda kurulum rehberi var.Onunla da olmazsa ne yapılabilir bilmiyorum
  • İleti: 6
    • emrahsakaci
« Yanıtla #10 : 11 Şubat 2017, 15:38:14 »
Biraz forumlarda gezindikten sonra en azından Nvidia ile oyuna giriş yapabilmeyi buldum. Belki aynı sorun başka bir arkadaş da olur diye kısaca tarif etmek isterim.  Bizim forumda tarif edildiği üzere bumblebee ve ekran kartlarımı kurdum. reboot edip sistem hazır hale geldikten sonra Yazılım Yöneticisinde Nvidia yazıp arattım ordan Nvidia settings'in benim ekran kartımla uyumlu 2 versiyonunu daha buldum bir tanesi direk GPU ısısını gösteriyor. Onu kurduktan sonra Terminal'den normal olarak Steam'i başlattım. Steam>Kütüphane>Cs:Go>Özellikler>Başlatma seçenekleri>
LD_PRELOAD="libpthread.so.0 libGL.so.1" __GL_THREADED_OPTIMIZATIONS=1 optirun %command% kodunu girip>Yerel dosyalar>Oyun Önbelleğinin Bütünlüğünü Doğrula dedikten sonra steam>kütüphane üzerinden oyunu açmak istediğimiz zaman Nvidia ile giriş yapabiliyoruz oyuna. Evet halen fps sorunu yaşıyorum fakat eskisi kadar kasmıyor. Onun da kaynağının Nvidia'nın sürücüsünün güncel olmadığı için yapmış olabiliceğini tahmin ediyorum. Bugün bir boşluk bulursam onu da deneyip konuyu kilitliycem. Ekstra bir tavsiyeniz olursa denemek isterim. Şuan Nvidia-370 kurulu sistemimde.
rc  nvidia-304                                  304.134-0ubuntu0.16.04.1                              amd64        NVIDIA legacy binary driver - version 304.134
ii  nvidia-370                                  370.28-0ubuntu0~gpu16.04.3                            amd64        NVIDIA binary driver - version 370.28
rc  nvidia-378                                  378.09-0ubuntu0~gpu16.04.1                            amd64        NVIDIA binary driver - version 378.09
ii  nvidia-prime                                0.8.2linuxmint1                                       amd64        Tools to enable NVIDIA's Prime
ii  virtualgl-libs:i386                         2.4.1-1~xenialppa1                                    i386         Library files for virtualgl
ii  virtualgl-libs-ia32:i386                    2.4.1-1~xenialppa1                                    i386         Library files for virtualgl (32-bit)
vblank_mode=0  glxgears
39177 frames in 5.0 seconds = 7835.320 FPS
39115 frames in 5.0 seconds = 7822.882 FPS
vblank_mode=0 optirun glxgears
6471 frames in 5.0 seconds = 1294.039 FPS
6486 frames in 5.0 seconds = 1297.054 FPS
« Yanıtla #11 : 11 Şubat 2017, 15:43:11 »
Umarım tam anlamıyla çözülür
