Gönderen Konu: Linux Mint logo sonrasi siyah ekran - sistem açılmıyor.  (Okunma sayısı 4525 defa)
Çevrimdışı TYeniyayla
  • İleti: 19
    • tyeniyayla
  • Grafik Kartı: Nvidia GTX960M - İntel HD Graphics 530
  • İşlemci: İntel i7 6700HQ
Linux mint logosundan sonra siyah ekranda takılıyor 1dk sonra fan hızı rahatsız edecek seviyede artıyor. Tty ekranına düştüğümde daha giriş yapamadan takılıyor ve hiçbir şey yazamıyorum.
[info]inxi -Fxz[/info]
System:    Host: tunahan--pc Kernel: 4.4.0-53-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.2.6 (Gtk 3.18.9-1ubuntu3.1) Distro: Linux Mint 18.1 Serena
Machine:   System: ASUSTeK (portable) product: GL752VW v: 1.0
           Mobo: ASUSTeK model: GL752VW v: 1.0 Bios: American Megatrends v: GL752VW.214 date: 04/18/2016
CPU:       Quad core Intel Core i7-6700HQ (-HT-MCP-) cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 20737
           clock speeds: max: 3500 MHz 1: 800 MHz 2: 1170 MHz 3: 800 MHz 4: 800 MHz 5: 800 MHz 6: 828 MHz
           7: 805 MHz 8: 800 MHz
Graphics:  Card-1: Intel Skylake Integrated Graphics bus-ID: 00:02.0
           Card-2: NVIDIA GM107M [GeForce GTX 960M] bus-ID: 01:00.0
           Display Server: X.org 1.18.4 drivers: intel (unloaded: fbdev,vesa) FAILED: nouveau
           tty size: 144x23 Advanced Data: N/A for root
Audio:     Card Intel Sunrise Point-H HD Audio driver: snd_hda_intel bus-ID: 00:1f.3
Network:   Card-1: Intel Wireless 7265 driver: iwlwifi bus-ID: 02:00.0
           IF: wlp2s0 state: down mac: <filter>
           driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 03:00.1
           IF: enp3s0f1 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 2000.4GB (1.3% used) ID-1: USB /dev/sda model: Expansion size: 1000.2GB temp: 0C
           ID-2: /dev/sdb model: HGST_HTS721010A9 size: 1000.2GB temp: 35C
Partition: ID-1: / size: 94G used: 9.4G (11%) fs: ext4 dev: /dev/sda2
           ID-2: /boot size: 464M used: 60M (14%) fs: ext4 dev: /dev/sda5
           ID-3: swap-1 size: 16.38GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 46.0C mobo: N/A
           Fan Speeds (in rpm): cpu: 2100
Info:      Processes: 228 Uptime: 45 min Memory: 890.3/15942.9MB Init: systemd runlevel: 3 Gcc sys: 5.4.0
Ynt: Linux Mint logo sonrasi siyah ekran - sistem açılmıyor.
« Yanıtla #1 : 11 Mart 2017, 21:21:05 »
Bu çıktıları nereden aldınız, kurulum yaptığınız çalışan DVD/USB yardımıyla mı, kurulu sistemden mi?
  • İleti: 19
    • tyeniyayla
« Yanıtla #2 : 11 Mart 2017, 21:21:53 »
Kurulu sistemi bir kere açabildiğimde alıp kayıt etmiştim o zaman ait
MI 5s Plus cihazımdan Tapatalk kullanılarak gönderildi
Buyrun bu da live usb den aldigim cikti:
System:    Host: mint Kernel: 4.4.0-53-generic x86_64 (64 bit gcc: 5.4.0)
           clock speeds: max: 3500 MHz 1: 1012 MHz 2: 799 MHz 3: 803 MHz
           4: 800 MHz 5: 3464 MHz 6: 800 MHz 7: 2027 MHz 8: 825 MHz
           Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa) FAILED: nouveau
           Resolution: 1920x1080@60.00hz
           GLX Renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2)
Drives:    HDD Total Size: 2016.4GB (1.3% used)
           ID-1: /dev/sdb model: HGST_HTS721010A9 size: 1000.2GB temp: 31C
           ID-2: USB /dev/sda model: Expansion size: 1000.2GB temp: 0C
           ID-3: USB /dev/sdc model: Cruzer_Blade size: 16.0GB temp: 0C
Partition: ID-1: / size: 7.8G used: 46M (1%) fs: overlay dev: N/A
           ID-2: swap-1 size: 16.38GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 36.0C mobo: N/A gpu: 42.0
           Fan Speeds (in rpm): cpu: 25500
Info:      Processes: 245 Uptime: 2 min Memory: 739.2/15942.9MB
« Son Düzenleme: 11 Mart 2017, 21:26:51 Gönderen: TYeniyayla »
« Yanıtla #3 : 11 Mart 2017, 21:58:13 »
Sistemi kurtarma kipi ile açamayı dener misiniz? Masaüstüne ulaşabilirseniz aşağıdaki şekilde sistemi güncellemeyi deneyiniz.
Ardından, Güncelleme Yöneticisi => Görünüm menüsü => "Linux çekirdekleri" aracı yardımıyla 4.4.x serisi çekirdeğin son sürümünü kurunuz.
  • İleti: 19
    • tyeniyayla
« Yanıtla #4 : 11 Mart 2017, 22:09:44 »
Recovery modda bunlar çıkıyor:
Enter dediğimde:
Tekrardan enter ile tamam diyorum ve bu ekrana giriyor:
Sonrasını biliyorsunuz zaten yazı yazamıyorum ve hemen sonra fan sesi artıyor.
« Yanıtla #5 : 11 Mart 2017, 22:14:13 »
Kullanıcı adı ve şifrenizi girip oturum açın ve aşağıdaki komutla pencere yöneticisini çalıştırmayı deneyin.
sudo service mdm start
  • İleti: 19
    • tyeniyayla
« Yanıtla #6 : 11 Mart 2017, 22:16:53 »
Söylediğim gibi yazamıyorum dolayısıyla kullanıcı adı ve şifremi de giremiyorum. Hatta yeni farkettim capslock tuşuna bastığımda klavyede yanan ışık yanmıyor(numlock ta öyle). Harici klavye bağladım onunla da aynı sorunu yaşıyorum
  • İleti: 19
    • tyeniyayla
« Yanıtla #7 : 13 Mart 2017, 18:36:45 »
Hala düzgün bir ilerleme kaydedemedim. Dün hiçbir değişiklik yapmadan tty ekranına giriş yapabildim. Her zaman kullanıcı adını yazarken takılıyordu bu sefer olmadı. Dediğiniz "sudo service mdm start" kodunu yazdım bir sonraki satıra indi, imleç 1-2 kez yandı ve yanık bir şekilde bekledi. Açılmayacağını anlayınca yeniden başlattım. Bu sefer yine tty girişini yaptım ve "sudo nano /etc/rc.local" diyerek dosyayı açtım. Sonra exit 0 yazan yazıdan önce "systemctl restart bumblebeed" yazdım ve Ctrl-X yaparak kayıt ettim. Tüm bunlara rağmen yine de Logodan sonra siyah ekranda kalıyordu.
  • İleti: 19
    • tyeniyayla
« Yanıtla #8 : 14 Mart 2017, 01:33:16 »
Şu anda azıcık ilerledim recovery menüsünden root satırına gir dedim. Şifreyi girdim ve starx yazdım. Masaüstü geldi. Ama şöyle bir hata veriyor evet dersem ekran kararıp açılıyor ama aynı uyarı yine geliyor. Hayır dersem gidiyor. :
Normal yollarla hâlâ açanıyorum. Hatta normalde e tuşuna basıp quite splash yazan yere 3 yazarak tty ekranına düşebiliyorum ama orada giriş yaptıktan sonra startx yazdıktan sonra birkaç yazı geliyor sonra orada bekliyor masaüstü gelmiyor.
« Son Düzenleme: 14 Mart 2017, 01:35:28 Gönderen: TYeniyayla »
« Yanıtla #9 : 14 Mart 2017, 17:42:34 »
Sistemi aşağıdaki bağlantıda anlatıldığı gibi farklı değişkenler ile açmayı dener misiniz?
https://forum.linuxmint.net.tr/index.php?topic=7028.msg43919#msg43919
