Gönderen Konu: [Nasıl] Linux Mint 17.x - Intel + Nvidia Hibrit GPU İçin Bumblebee Kurulumu  (Okunma sayısı 194454 defa)
Çevrimdışı Mert
  • İleti: 22
  • Atheist
  • Masaüstü Ortamı: Cinnamon 3.2.7
  • Grafik Kartı: Nvidia GT540M 2GB
  • İşlemci: Intel Core i7-2630QM 2GHz ~ 2.9GHz
mert@Aspire-5742G ~/bumblebee-ui $ optirun -vvv glxgears
[  638.564917] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[  638.565383] [INFO]Configured driver: nvidia
[  638.565640] [DEBUG]optirun version 3.2.1 starting...
[  638.565658] [DEBUG]Active configuration:
[  638.565665] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[  638.565671] [DEBUG] X display: :8
[  638.565676] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-331:/usr/lib32/nvidia-331
[  638.565682] [DEBUG] Socket path: /var/run/bumblebee.socket
[  638.565688] [DEBUG] Accel/display bridge: auto
[  638.565693] [DEBUG] VGL Compression: proxy
[  638.565699] [DEBUG] VGLrun extra options:
[  638.565705] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[  638.565763] [DEBUG]Using auto-detected bridge primus
[  640.843102] [INFO]Response: Yes. X is active.
[  640.843121] [INFO]Running application using primus.
[  640.843276] [DEBUG]Process glxgears started, PID 2651.
295 frames in 5.0 seconds = 58.814 FPS
301 frames in 5.0 seconds = 60.029 FPS
301 frames in 5.0 seconds = 60.028 FPS
301 frames in 5.0 seconds = 60.032 FPS
primus: warning: dropping a frame to avoid deadlock
XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
      after 37 requests (37 known processed) with 0 events remaining.
primus: warning: timeout waiting for display worker
[  672.021423] [DEBUG]SIGCHILD received, but wait failed with No child processes
[  672.021465] [DEBUG]Socket closed.
[  672.021490] [DEBUG]Killing all remaining processes.
mert@Aspire-5742G ~/bumblebee-ui $ cat /etc/bumblebee/bumblebee.conf
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
[driver-nvidia]
KernelDriver=nvidia-331
PMMethod=auto
# default Xorg modules path
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
mert@Aspire-5742G ~/bumblebee-ui $ cat /etc/bumblebee/xorg.conf.nvidia
Section "ServerLayout"
    Identifier  "Layout0"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
    BusID "PCI:01:00:0"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
mert@Aspire-5742G ~/bumblebee-ui $ cat /etc/X11/xorg.conf
mert@Aspire-5742G ~/bumblebee-ui $ dpkg -l | egrep 'nvidia|bumblebee|primus|prime'
ii  bumblebee                                   3.2.1-5                                             amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                            3.2.1-5                                             amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-331                                  331.113-0ubuntu0.0.4                                amd64        NVIDIA binary driver - version 331.113
ii  nvidia-settings                             331.20-0ubuntu8                                     amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                      0~20131127-2                                        amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                           0~20131127-2                                        amd64        Shared libraries for primus
mert@Aspire-5742G ~/bumblebee-ui $ lspci | egrep 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02)
01:00.0 VGA compatible controller: NVIDIA Corporation GF119M [GeForce GT 520M] (rev ff)
Acaba nerde hata yaptım :/
Hata yapmamışsınız, Bumblebee etkinleşmiş görünüyor.
Çevrimdışı Mert
  • İleti: 22
  • Atheist
bumblebee ile csgo çalıştırdığımda intel graphics kullanıyor.  oyunda haliyle grafik sorunları görünüyor.
bu işlemleri yapmadan önce sıkıntı yaşamıyordum :/
mesela steam i bumblebee ile açtığımda bu hatayı alıyorum:
OpenGL GLX context is not using direct rendering, which may cause performance problems.
For more information visit https://support.steampowered.com/kb_article.php?ref=9938-EYZB-7457.
Çevrimdışı Mert
  • İleti: 22
  • Atheist
bir arkadaşımda şunu yazdı bana :
conf dosyasındaki bütün tırnakları sil Configuration file for Bumblebee. Values should **not** be put between quotes yazıyor
Arkadaşınızın önerisinin uygun olmayacağını düşünüyorum, yapılandırma dosyasında bu tip bir düzenleme ile sorun çözülmez. Sorun sisteminizin 64 bit, kurduğunuz uygulamanın ise 32 bit olmasından kaynaklanıyor. İşin özü 32 bit uygulama sistemdeki OpenGL desteğini sorgulamak için yine 32 bit paketlerdeki dosyaları arıyor. buna göre çalışan bir komutdan uygun çıktı gelemeyince de mesaj olarak EpenGl ile ilgili yeterli desteğin olamdığını basıyor. Bunların etrafından dolaşmak biraz sıkıntı olabilir, en kısa yoldan 32 bit sistem kurmayı deneyin derim.
Çevrimdışı Mert
  • İleti: 22
  • Atheist
Öneriniz için teşşekkür ederim fakat 32bit sistemde 8gb ram'in tamamını kullanamayacağım. Bu sistemde kesin bir çözüm arıyorum.
Örneğin Steam'i bumblebee kullanmadan açtığımda OpenGL hatasını almıyorum ve Steam içinden CSGO çalıştırdığımda oyun açılıyor grafiklerde sorun olmuyor. Lakin oyunun en düşük ayarlarıyla bile FPS çok düşüyor. Daha önce bu sistemde bu şekilde bir sorun yaşamamıştım. Ben güncel Nvidia sürücüsünün linux için olan "run" uzantılı versiyonunu indirdim. Bu durumda Nvidia sürücüsünün güncel versiyonunu nasıl kurabilirim?
[member=1268]Mert[/member], bu durum kısıtlayıcı başka sistemler için geçerli, Linux dağıtımlarının çoğunda (PAE kernel ile gelen sürümlerde) 32 bit sistemleri kullansanız dahi, 8 gb. RAM'ın tamamını kullanabilirsiniz.
Optimus destekli sistemlere Nvidia sürücüler direk kurulmazlar. Bunun için Bumblebee projesi kullanılıyor.
İsterseniz bir de aşağıdaki öneriyi deneyerek oyunu direk optirun değişkeni ile başlatın.
http://forum.linuxmint.net.tr/index.php?topic=78.msg15298#msg15298
Çevrimdışı Mert
  • İleti: 22
  • Atheist
optirun eklediğimde malesef oyunu çalıştıramıyorum bumblebee indicator on konumuna geliyor oyun açılmadan tekrar off konumuna geliyor. optirun ve bumblebee kullanmadan oyunu açtığımda açılıyor. Acaba bumblebee kullandığımda intel hd graphics mi kullanıyor?
Çevrimdışı Mert
  • İleti: 22
  • Atheist
https://wiki.debian.org/Steam
şuan burdaki işlemleri yapıyorum bakalım.
Çevrimdışı timur-75
  • İleti: 93
Aynı sorun ile ben karşılaşmıştım, 16. sayfadaki gönderileri takip ederek çözmeyi deneyin düzelebilir.
Çevrimdışı Mert
  • İleti: 22
  • Atheist
http://forum.linuxmint.net.tr/index.php?topic=2528.0
Çevrimdışı soloces
  • İleti: 2
Merhabalar döküman için teşekkürler
optirun glxgears  çalıştırıdığımda 60 küsür fps
glxgears çalıştırıdğımda yine 60 küsür fps çıkıyor.
optirun glxgears çalıştırıdğımda çok daha yüksek fps vermesi lazım değil mi
[  626.059053] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[  626.059676] [INFO]Configured driver: nvidia
[  626.059898] [DEBUG]optirun version 3.2.1 starting...
[  626.059945] [DEBUG]Active configuration:
[  626.059966] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[  626.059989] [DEBUG] X display: :8
[  626.060033] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-331:/usr/lib32/nvidia-331
[  626.060052] [DEBUG] Socket path: /var/run/bumblebee.socket
[  626.060073] [DEBUG] Accel/display bridge: auto
[  626.060094] [DEBUG] VGL Compression: proxy
[  626.060114] [DEBUG] VGLrun extra options:
[  626.060135] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[  626.060224] [DEBUG]Using auto-detected bridge primus
[  627.702077] [INFO]Response: Yes. X is active.
[  627.702089] [INFO]Running application using primus.
[  627.702177] [DEBUG]Process glxgears started, PID 2924.
294 frames in 5.0 seconds = 58.699 FPS
301 frames in 5.0 seconds = 60.036 FPS
301 frames in 5.0 seconds = 60.034 FPS
^C[  646.679226] [WARN]Received Interrupt signal.
[  646.679416] [DEBUG]Socket closed.
[  646.714858] [DEBUG]SIGCHILD received, but wait failed with No child processes
[  646.714891] [DEBUG]Socket closed.
[  646.714899] [DEBUG]Killing all remaining processes.
# to take effect.
[bumblebeed]
VirtualDisplay=:8
# server exits.
# be ignored.
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
[driver-nvidia]
PMMethod=auto
[driver-nouveau]
PMMethod=auto
    Driver      "nvidia"
    BusID "PCI:01:00:0"
ii  bumblebee                                                   3.2.1-5+xedgers14.04.1                              amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                                            3.2.1-5+xedgers14.04.1                              amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
rc  nvidia-304                                                  304.125-0ubuntu1~xedgers14.04.1                     amd64        NVIDIA legacy binary driver - version 304.125
ii  nvidia-331                                                  331.113-0ubuntu1~xedgers14.04.1                     amd64        NVIDIA binary driver - version 331.113
ii  nvidia-settings                                             346.35-0ubuntu1~xedgers14.04.1                      amd64        Tool for configuring the NVIDIA graphics driver
ii  primus-libs:i386                                            0~20131127-2                                        i386         Shared libraries for primus
ii  primus-libs-ia32                                            0~20131127-2                                        i386         Shared libraries for primus (32-bit)
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 860M] (rev ff)
« Son Düzenleme: 11 Şubat 2015, 16:16:17 Gönderen: soloces »
[member=1338]soloces[/member], size de merhaba,
Dikey senkronizasyon (vsync) etkin olduğu böyle bir sonuçla karşılaşıyorsunuz. Böylece görüntü bozulmaları önlenmiş oluyor.
Çevrimdışı soloces
  • İleti: 2
cevabınız için teşekkür ederim.
vsync i kapatıp nasıl test edebilirim
Aşağıdaki komutu deneyebilirsiniz.
vblank_mode=0 optirun -b primus glxgears
