Gönderen Konu: [Nasıl] Linux Mint 17.x - Intel + Nvidia Hibrit GPU İçin Bumblebee Kurulumu  (Okunma sayısı 194629 defa)
Çevrimdışı tux5
  • İleti: 41
  • Dağıtım: Linux Mint 18 Cinnamon 64 Bit
Sistemi yeniden başlattınız mı?  Konunun sonunda, sorun yaşanması durumunda çıktılarının paylaşılması gerekli komutların listesi mevcut.
Evet yeniden başlattım.
optirun -vvv glxgears
[ 1261.333710] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 1261.334245] [INFO]Configured driver: nvidia
[ 1261.334473] [DEBUG]optirun version 3.2.1 starting...
[ 1261.334515] [DEBUG]Active configuration:
[ 1261.334536] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 1261.334558] [DEBUG] X display: :8
[ 1261.334579] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-346:/usr/lib32/nvidia-346
[ 1261.334600] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 1261.334623] [DEBUG] Accel/display bridge: auto
[ 1261.334644] [DEBUG] VGL Compression: proxy
[ 1261.334665] [DEBUG] VGLrun extra options:
[ 1261.334685] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 1261.334838] [DEBUG]Using auto-detected bridge virtualgl
[ 1263.385060] [INFO]Response: Yes. X is active.
[ 1263.385083] [INFO]Running application using virtualgl.
[ 1263.385216] [DEBUG]Process vglrun started, PID 4246.
4367 frames in 5.0 seconds = 873.306 FPS
4296 frames in 5.0 seconds = 859.086 FPS
4298 frames in 5.0 seconds = 859.580 FPS
[VGL] ERROR: in readback--
[VGL]    247: Window has been deleted by window manager
[ 1281.040999] [DEBUG]SIGCHILD received, but wait failed with No child processes
[ 1281.041046] [DEBUG]Socket closed.
[ 1281.041062] [DEBUG]Killing all remaining processes.
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
[driver-nvidia]
KernelDriver=nvidia-346
PMMethod=auto
LibraryPath=/usr/lib/nvidia-346:/usr/lib32/nvidia-346
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia-346/xorg,/usr/lib/xorg/modules
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
Section "ServerLayout"
    Identifier  "Layout0"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
    BusID "PCI:03:00:0"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
ii  bumblebee                                   3.2.1-90~trustyppa1                                 amd64        NVIDIA Optimus support
ii  bumblebee-nvidia                            3.2.1-90~trustyppa1                                 amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-346                                  346.72-0ubuntu1                                     amd64        NVIDIA binary driver - version 346.72
ii  nvidia-prime-applet                         1.0.2                                               all          An applet for NVIDIA Prime
ii  nvidia-settings                             346.72-0ubuntu1                                     amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                      20131127-1~trustyppa1                               amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                           20131127-1~trustyppa1                               amd64        Shared libraries for primus
ii  primus-libs:i386                            20131127-1~trustyppa1                               i386         Shared libraries for primus
ii  primus-libs-ia32                            20131127-1~trustyppa1                               i386         Shared libraries for primus (32-bit)
ii  virtualgl                                   2.3.3-1~trustyppa1                                  amd64        Toolkit for displaying OpenGL applications to thin clients
ii  virtualgl-libs:amd64                        2.3.3-1~trustyppa1                                  amd64        Library files for virtualgl
03:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 840M] (rev ff)
« Son Düzenleme: 12 Temmuz 2015, 03:14:47 Gönderen: tux5 »
Bumblebee'nin çalışmasında bir sıkıntı yok.
Aşağıdaki komutla bumblebee.conf dosyasını açınız,
sudo gedit /etc/modprobe.d/bumblebee.conf
aşağıdaki satırları dosyanın en altına ekleyip dosyayı kaydederek, nvidia-346 ve nouveau (açık kaynak sürücü) modüllerinin başlangıçta pasifleşmenisini sağlayınız.
# nvidia-346 &  nouveau karaliste
blacklist nvidia-346
blacklist nouveau
Çevrimdışı tux5
  • İleti: 41
blacklist nouveau
Bilgisayarı yeniden başlattım, inxi -Gx komutunu verdiğimde artık o Failed yazısı çıkmadı.
inxi -Gx
Graphics:  Card: Intel Haswell-ULT Integrated Graphics Controller bus-ID: 00:02.0
           X.Org: 1.15.1 drivers: intel (unloaded: fbdev,vesa) Resolution: 1920x1080@60.0hz
           GLX Renderer: Mesa DRI Intel Haswell Mobile GLX Version: 3.0 Mesa 10.1.3 Direct Rendering: Yes
birde inxi -Gx komutunda sadece intel ekran kartı gözüküyor. lspci | egrep 'VGA|3D|Display' komutuyla Nvidia ekran kartıda gözüküyor.Bazı mesajlarda inxi -Gx komutu çıktısında Card:1 ve Card2: diye bir çıktı geliyor.Benimkimde sadece intel gözüküyor.Bu normal mi?
« Son Düzenleme: 12 Temmuz 2015, 12:26:21 Gönderen: tux5 »
Normal bir durum, aşağıdaki komutu deneyebilirsiniz.
inxi -G
Inxi komutunun çıktısı şu an için bir şey ifade etmez.
Çevrimdışı tux5
  • İleti: 41
Sağolun,çok teşekkürler.
Inxi betiğinin depodaki sürümü (1.9.17-1) sadece "VGA controller" olarak tanımlı ekran bağdaştırıcılarını listeliyor.
/vga compatible controller/
Daha güncel yeni (2.x ve üstü) sürümlerinde  ise "3D Controller" ya da "Display controller" olarak tanımlı direk görüntü çıkışı olmayan sadece görüntü işleme fonksiyonu bulunan ekran bağdaştırıcıları da listelenebiliyor.
/vga compatible controller|3D controller|Display controller/
İstenirse aşağıdaki komutlar ile yeni sürüm kurulumu denenebilir.
wget -c --no-check-certificate archive.ubuntu.com/ubuntu/pool/universe/i/inxi/inxi_2.2.16-0ubuntu1_all.deb
sudo dpkg -i inxi*
Eski sistemlerde hibrid harici GPU'lar direk görüntü çıkışını kullanıyordu. Bu şekildeki harici GPU'lar da "VGA controller" olarak tanımlanıyordu. Yeni nesil hibrid GPU sistemlerde ise artık harici GPU'lar sadece görüntü işliyor, işlenen görüntü dahili VGA controller üzerinden aktarılıyor. Bunlar ise VGA yerine  "3D ya da Display controller" olarak tanımlanıyor. Sizin sisteminizde inxi betiğinin 2 GPU'yu listelememesi bu sebepten kaynaklı. Güncel inxi betiği ile bu destek sağlanmış.
« Son Düzenleme: 12 Temmuz 2015, 17:57:03 Gönderen: Butterfly »
Çevrimdışı tux5
  • İleti: 41
Anladım,yardımlarınız için çok teşekkürler.
Çevrimdışı NorthWonder
  • İleti: 2
  • Masaüstü Ortamı: Laptop
  • Grafik Kartı: 610m + hd 4000
  • İşlemci: 3230m
Merhabalar öncelikle çok teşekkür ederim başarılı bir şekilde kurulum gerçekleşti fakat bumblebee ayarlarını apply desem bile kaydetmiyor ancak belirttiğiniz gibi komut satırı ile yapınca aktif hale geliyor bir çözümü varmı ne kadar uğraşsamda ayarları kaydettiremedim
Edit=Sistemi sıfırladım şuan sizin prime konunuza da baktım fakat onda güncelleme olmadığı için ilgimi çekmedi açıkcası yardımınızı rica ediyorum
Edit2=Prime kurdum suanlık :)
« Son Düzenleme: 15 Temmuz 2015, 16:54:04 Gönderen: NorthWonder »
Bumblebee ayarlarını kaydetmekten Bumblebee-ui uygulamasını mı kastediyorsunuz? Öyle ise bununla ilgili yeni bir konu açınız.
Nvidia Prime'da güncelleme olmuyordan kastınız nedir?
« Son Düzenleme: 17 Temmuz 2015, 02:55:05 Gönderen: Butterfly »
Çevrimdışı tux5
  • İleti: 41
Bende bumblebee-ui'yi yükledim.Ayarlarından bazı programların Nvidia'yla çalışması için gerekli ayarları yaptım.Yalnız gerçekten o söylediğim programın Nvidia'yla çalışıp çalışmadığını nasıl anlarım.
Ayrıca bumblebee-ui uygulama ayarlarında seçtiğim programların yanında bir 32bits Driver seçeneği var.Bunu etkinleştirsek,bu ne işe yarar?
Birde oyunların dışında hangi uygulamaların Nvidia'yla çalışması daha mantıklıdır?Ben örneğin VLC,OpenShot,Avidemux,Cheese gibi programları seçtim Nvidia'yla çalışması için.Acaba doğru mu yapmışım?
Nvidia GPU ile ilişkilendirdiğiniz uygulama çalıştığı esnada aşağıdaki komutun çıktısına bakabilirsiniz.
32 bit uygulamalar ile uyumluluk için olabilir.
Bence Intel GPU VLC, Cheese, web tarayıcıları gibi uygulamaları çalıştırmak için oldukça yeterli. Openshot ve Avidemux ile basit video düzenlemeleri yapıyorsanız, bunlar içinde Nvidia GPU'yu kullanmak gerekmeyebilir. Ama Blender gibi GPU'yu daha verimli kullanabilecek uygulamalar için Nvidia GPU tercih edilebilir.
Çevrimdışı tux5
  • İleti: 41
Çok teşekkürler.
Bumblebee-ui'de Nvidia GPU'yu için seçtiğim programları  menüden açtığımda "Bumblebee:On" bildirimi gelmiyor.Ama bumblebee-ui uygulamasını açtığımda ve preferred apps seçeneğinden seçtiğim uygulamaya tıkladığımda 'Bumblebee:On Bumblebee is in use' bildirimi geliyor.Galiba bu şekilde Nvidia GPU'yu kullanıyor.Bu şekilde açtığım bir program açıkken glxinfo | grep render çıktısı şöyle oluyor:
Bunun dışında bumblebee-ui'de o seçtiğim programı açmadan yani normal günlük kullanımda  glxinfo | grep render çıktısı yine yukardaki gibi oluyor.Acaba bir sıkıntı mı var bu çıktıda?
Bu arada bumblebee-ui uygulamasını başlangıçta başlatma ayarını yapmadım.
Çevrimdışı tux5
  • İleti: 41
[member=8]Butterfly[/member] yukarda paylaştığım glxinfo | grep render çıktısında bir sıkıntı yok mu?Eğer söylediğim uygulama şayet Nvidia ile çalışsaydı yukardaki çıktıda OpenGL renderer string: Mesa DRI Intel(R) Haswell Mobile  kısmı Intel yerine Nvidia'yı göstermesi gerekmezmiydi?Yoksa yanlış mı anladım?
Bir de aşağıdaki komut çalışırken çıktıyı kontrol eder misiniz?
optirun glxgears
Optirun komutu ile uygulamaları ilişkilendirmek için menü düzenleme aracını da kullanabilirsiniz. Cinnamon için aşağıdaki komutla açabilirsiniz.
cinnamon-menu-editor
Nvidia kart ile çalışmasını istediğiniz uygulamayı bulup, başlatıcı komutunun başına optirun eklemek yeterli olacaktır.
« Son Düzenleme: 27 Temmuz 2015, 15:37:32 Gönderen: Butterfly »
Çevrimdışı abdyek
  • İleti: 437
  • Masaüstü Ortamı: i3wm
  • İşlemci: i5 - 2. nesil
Bizim sistem eski, kuran arkadaşlara hayırlı olsun.  : ' )
