Gönderen Konu: [Nasıl] Linux Mint 17.x - Intel + Nvidia Hibrit GPU İçin Bumblebee Kurulumu  (Okunma sayısı 193632 defa)
Çevrimdışı zoomTR
  • İleti: 17
  • Grafik Kartı: nvidia g840m
  • İşlemci: intel i 7
Bir sorun olduğunu düşünüyorum
optirun -vvv glxgears çıktısı
[ 1346.598408] Reading file: /etc/bumblebee/bumblebee.conf
[ 1346.598855] Could not open configuration file: /etc/bumblebee/bumblebee.conf
[ 1346.598903] Using default configuration
[ 1346.599257] optirun version 3.2.1 starting...
[ 1346.599314] Active configuration:
[ 1346.599345]  bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 1346.599378]  X display: :8
[ 1346.599410]  LD_LIBRARY_PATH:
[ 1346.599442]  Socket path: /var/run/bumblebee.socket
[ 1346.599474]  Accel/display bridge: auto
[ 1346.599505]  VGL Compression: proxy
[ 1346.599536]  VGLrun extra options:
[ 1346.599568]  Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 1346.599659] Using auto-detected bridge virtualgl
[ 1346.796873] Response: No - error:  (EE)  KMS not enabled
[ 1346.796884] Cannot access secondary GPU - error:  (EE)  KMS not enabled
[ 1346.796888] Socket closed.
[ 1346.796902] Aborting because fallback start is disabled.
[ 1346.796906] Killing all remaining processes.
cat /etc/bumblebee/bumblebee.conf çıktısı
# to take effect.
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=nvidia=
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
# parsed if the Driver setting in  is set to NAME (or if auto-
[driver-nvidia]
KernelDriver=nvidia-304
PMMethod=auto
LibraryPath=/usr/lib/nvidia-304:/usr/lib32/nvidia-304
 default Xorg modules path
XorgModulePath=/usr/lib/nvidia-304/xorg,/usr/lib/xorg/modules
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
cat /etc/bumblebee/xorg.conf.nvidia  çıktısı
Section "ServerLayout"
    Identifier  "Layout0"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
    BusID "PCI:03:00:0"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
  cat /etc/X11/xorg.conf çıktısı
dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl' çıktısı
ii  bumblebee                                   3.2.1-93~trustyppa1                                 amd64        NVIDIA Optimus support
ii  bumblebee-nvidia                            3.2.1-93~trustyppa1                                 amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-352                                  352.79-0ubuntu0~gpu14.04.1                          amd64        NVIDIA binary driver - version 352.79
rc  nvidia-364                                  364.19-0ubuntu0~gpu14.04.1                          amd64        NVIDIA binary driver - version 364.19
rc  nvidia-opencl-icd-352                       352.63-0ubuntu0.14.04.1                             amd64        NVIDIA OpenCL ICD
ii  nvidia-opencl-icd-364                       364.19-0ubuntu0~gpu14.04.1                          amd64        NVIDIA OpenCL ICD
ii  nvidia-prime-applet                         1.0.3                                               all          An applet for NVIDIA Prime
ii  nvidia-settings                             364.15-0ubuntu0~gpu14.04.1                          amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                      20150328-1~trustyppa1                               amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                           20150328-1~trustyppa1                               amd64        Shared libraries for primus
ii  primus-libs:i386                            20150328-1~trustyppa1                               i386         Shared libraries for primus
ii  primus-libs-ia32:i386                       20150328-1~trustyppa1                               i386         Shared libraries for primus (32-bit)
ii  virtualgl                                   2.4.1-1~trustyppa1                                  amd64        Toolkit for displaying OpenGL applications to thin clients
ii  virtualgl-libs:amd64                        2.4.1-1~trustyppa1                                  amd64        Library files for virtualgl
lspci | egrep 'VGA|3D|Display' çıktısı
03:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 840M] (rev a2)
Şimdiden teşekkürler.
Düzenleme : Kod etiketi
« Son Düzenleme: 03 Mayıs 2016, 21:57:13 Gönderen: Butterfly »
Siz sadece kurulum yapmışsınız, konudaki "2 - Kurulum Sonrası Düzenleme" adımlarını uygulayınız.
Çevrimdışı mycrosoft
  • İleti: 9
  • Dağıtım: Linux Mint 18
  • Grafik Kartı: NVIDIA GeForce GTX 960M
  • İşlemci: Intel Core i5 5700HQ
Bütün çıktılar bunlar:
emircan@emircan ~/Masaüstü $ optirun -vvv glxgears
[  103.621462] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[  103.621654] [INFO]Configured driver: nvidia
[  103.621843] [DEBUG]optirun version 3.2.1 starting...
[  103.621864] [DEBUG]Active configuration:
[  103.621867] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[  103.621869] [DEBUG] X display: :8
[  103.621871] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-367:/usr/lib32/nvidia-current
[  103.621874] [DEBUG] Socket path: /var/run/bumblebee.socket
[  103.621876] [DEBUG] Accel/display bridge: auto
[  103.621880] [DEBUG] VGL Compression: proxy
[  103.621882] [DEBUG] VGLrun extra options:
[  103.621884] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[  103.630683] [DEBUG]Using auto-detected bridge primus
[  104.875723] [INFO]Response: Yes. X is active.
[  104.875742] [INFO]Running application using primus.
[  104.875871] [DEBUG]Process glxgears started, PID 2133.
Error: couldn't get an RGB, Double-buffered visual
[  104.995617] [DEBUG]SIGCHILD received, but wait failed with No child processes
[  104.995645] [DEBUG]Socket closed.
[  104.995663] [DEBUG]Killing all remaining processes.
emircan@emircan ~/Masaüstü $ cat /etc/bumblebee/bumblebee.conf
# to take effect.
[bumblebeed]
VirtualDisplay=:8
# server exits.
# be ignored.
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
[driver-nvidia]
KernelDriver=nvidia-367
PMMethod=auto
LibraryPath=/usr/lib/nvidia-367:/usr/lib32/nvidia-current
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia-367/xorg,/usr/lib/xorg/modules
[driver-nouveau]
PMMethod=auto
emircan@emircan ~/Masaüstü $ cat /etc/bumblebee/xorg.conf.nvidia
    Driver      "nvidia"
    BusID "PCI:01:00:0"
emircan@emircan ~/Masaüstü $ cat /etc/X11/xorg.conf
emircan@emircan ~/Masaüstü $ dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl'
ii  bumblebee                                    3.2.1-10                                   amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                             3.2.1-10                                   amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-367                                   367.27-0ubuntu0~gpu16.04.1                 amd64        NVIDIA binary driver - version 367.27
ii  nvidia-settings                              367.18-0ubuntu0~gpu16.04.1                 amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                       0~20150328-1                               amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                            0~20150328-1                               amd64        Shared libraries for primus
ii  primus-libs:i386                             0~20150328-1                               i386         Shared libraries for primus
ii  primus-libs-ia32:i386                        0~20150328-1                               i386         Shared libraries for primus (32-bit)
emircan@emircan ~/Masaüstü $ lspci | egrep 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation Broadwell-U Integrated Graphics (rev 0a)
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 960M] (rev a2)
/etc/bumblebee/bumblebee.conf dosyasındaki yukarıdaki satırı aşağıdaki şekilde değiştirip,
LibraryPath=/usr/lib/nvidia-367:/usr/lib32/nvidia-367
dosyayı kaydetmeyi ve ardından aşağıdaki komutla Bumbelbee servisini yeniden başlatmayı denetiniz.
Çevrimdışı tux5
  • İleti: 41
  • Dağıtım: Linux Mint 18 Cinnamon 64 Bit
Linux Mint 18'de bumblebee PPA'yı eklerken şu hata geliyor.
$ sudo add-apt-repository ppa:bumblebee/stable
'This PPA does not support xenial'
Cannot add PPA: ''This PPA does not support xenial''.
Konu Linux Mint 18 için güncellenmiştir.
Çevrimdışı serenler
  • İleti: 9
  • Masaüstü Ortamı: Cinnamon 4.6.7
  • İşlemci: Intel Dual Core i5-2410M 64-bit
kurulumu yapamadım bi türlü arkadaşlar yardım eder misiniz?
inxi -SGx
,System:    Host: uiea-Inspiron-N5110 Kernel: 3.2.0-23-generic x86_64 (64 bit, gcc: 4.6.3)
           Desktop: KDE 4.8.5 (Qt 4.8.1) Distro: Linux Mint 13 Maya
           Card-2: NVIDIA GF108M [GeForce GT 525M] bus-ID: 01:00.0
           X.Org: 1.11.3 drivers: intel (unloaded: vesa,fbdev) Resolution: 1366x768@60.0hz
X Error of failed request:  BadRequest (invalid request code or no such operation)
  Major opcode of failed request:  136 (GLX)
  Minor opcode of failed request:  19 (X_GLXQueryServerString)
  Serial number of failed request:  12
  Current serial number in output stream:  12
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 525M] (rev a1)
LVDS1 connected 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
   1366x768       60.0*+   40.1
   1360x768       59.8     60.0
   1024x768       60.0
   800x600        60.3     56.2
   640x480        59.9
[sudo] password for uiea:
You are about to add the following PPA to your system:
 Fresh drivers from upstream, currently shipping Nvidia.
## Current Status
We currently recommend: `nvidia-361`, Nvidia's current long lived branch.
For GeForce 8 and 9 series GPUs use `nvidia-340`
For GeForce 6 and 7 series GPUs use `nvidia-304`
## What we're working on right now:
- Normal driver updates
- Investigating how to bring this goodness to distro on a cadence.
## WARNINGS:
This PPA is currently in testing, you should be experienced with packaging before you dive in here. Give us a few days to sort out the kinks.
Volunteers welcome! See also: https://github.com/mamarley/nvidia-graphics-drivers/
### How you can help:
## Install PTS and benchmark your gear:
    sudo apt-get install phoronix-test-suite
Run the benchmark:
    phoronix-test-suite default-benchmark openarena xonotic tesseract gputest unigine-valley
and then say yes when it asks you to submit your results to openbechmarking.org. Then grab a cup of coffee, it takes a bit for the benchmarks to run. Depending on the version of Ubuntu you're using it might preferable for you to grabs PTS from upstream directly: http://www.phoronix-test-suite.com/?k=downloads
## Share your results with the community:
Post a link to your results (or any other feedback to): https://launchpad.net/~graphics-drivers-testers
Remember to rerun and resubmit the benchmarks after driver upgrades, this will allow us to gather a bunch of data on performance that we can share with everybody.
If you run into old documentation referring to other PPAs, you can help us by consolidating references to this PPA.
If someone wants to go ahead and start prototyping on `software-properties-gtk` on what the GUI should look like, please start hacking!
## Help us Help You!
We use the donation funds to get the developers hardware to test and upload these drivers, please consider donating to the "community" slider on the donation page if you're loving this PPA:
http://www.ubuntu.com/download/desktop/contribute
 More info: https://launchpad.net/~graphics-drivers/+archive/ubuntu/ppa
Press [ENTER] to continue or ctrl-c to cancel adding it
Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --secret-keyring /tmp/tmp.MzaMJjoHhK --trustdb-name /etc/apt/trustdb.gpg --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyserver hkp://keyserver.ubuntu.com:80/ --recv 2388FF3BE10A76F638F80723FCAE110B1118213C
gpg: requesting key 1118213C from hkp server keyserver.ubuntu.com
gpg: key 1118213C: "Launchpad PPA for Graphics Drivers Team" not changed
gpg: Total number processed: 1
gpg:              unchanged: 1
 Bumblebee Stable PPA
Installation instructions: https://wiki.ubuntu.com/Bumblebee
To report issues, please read http://wiki.Bumblebee-Project.org/Reporting-Issues
You may use any nvidia driver flavor, like -updates, -experimental or -nnn ones.
After installation, reboot to let changes apply.
To see if it works, run during around 30s: glxspheres
Then, run it with optirun, and compare: optirun glxspheres
If you want to use primus, you need to install it and set Bridge=primus in bumblebee.conf or use optirun -b primus. You also need to install primus-libs-ia32 if you want to run 32-bit apps.
Be aware that as Bumblebee is using low-level hardware informations, it is impossible to run it in a VM.
 More info: https://launchpad.net/~bumblebee/+archive/ubuntu/stable
Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --secret-keyring /tmp/tmp.pA8vIuxVd4 --trustdb-name /etc/apt/trustdb.gpg --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyserver hkp://keyserver.ubuntu.com:80/ --recv 46C0364A882F14F899448FFCB22A95F88110A93A
gpg: requesting key 8110A93A from hkp server keyserver.ubuntu.com
gpg: key 8110A93A: "Launchpad PPA for Bumlebee Project" not changed
gpg:              unchanged: 1
Hit http://archive.ubuntu.com precise Release.gpg
Hit http://archive.ubuntu.com precise-updates Release.gpg
Hit http://ppa.launchpad.net precise Release.gpg
Get:1 http://packages.medibuntu.org precise Release.gpg
Hit http://security.ubuntu.com precise-security Release.gpg
Hit http://packages.linuxmint.com maya Release.gpg
Hit http://archive.canonical.com precise Release.gpg
Hit http://archive.canonical.com precise/partner amd64 Packages
Hit http://ppa.launchpad.net precise/main Sources
Hit http://ppa.launchpad.net precise/main amd64 Packages
Hit http://ppa.launchpad.net precise/main i386 Packages
Hit http://ppa.launchpad.net precise/main TranslationIndex
Get:2 http://archive.ubuntu.com precise/universe amd64 Packages [4.786 kB]
Get:3 http://security.ubuntu.com precise-security/main amd64 Packages [616 kB]
Get:4 http://packages.medibuntu.org precise Release
Hit http://archive.canonical.com precise/partner TranslationIndex
Ign http://packages.medibuntu.org precise Release
N: Ignoring file 'medibuntu.list.save' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
N: Ignoring file 'bumblebee-stable-precise.list.save' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
N: Ignoring file 'local-repository.list.save' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
N: Ignoring file 'graphics-drivers-ppa-precise.list.save' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
N: Ignoring file 'ubuntu.list.save' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
N: Ignoring file 'mint.list.save' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
E: GPG error: http://packages.medibuntu.org precise Release: The following signatures were invalid: NODATA 1 NODATA 2
sudo apt-get install bumblebee nvidia-364 nvidia-settings bumblebee-nvidia primus virtualgl linux-headers-$(uname -r)
Reading package lists... Done
Building dependency tree
linux-headers-3.2.0-23-generic is already the newest version.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 nvidia-364 : Depends: libwayland0 but it is not installable
              Recommends: libcuda1-364 but it is not going to be installed
              Recommends: nvidia-opencl-icd-364 but it is not going to be installed
 nvidia-settings : Depends: pkg-config but it is not installable
                   Depends: libjansson4 (>= 2.0.1) but it is not installable
 primus : Depends: socat but it is not installable
          Recommends: primus-libs-ia32
E: Unable to correct problems, you have held broken packages.
Linux Mint 13 kurmanız için özel bir sebebiniz yoksa daha güncel bir sürüm kurmayı deneyiniz. Linux Mint 13 için önce buradaki düzenlemeyi yapınız ve yeniden kurulum deneyiniz.
Çevrimdışı serenler
  • İleti: 9
Linux Mint 13 daha kararlı olabilir diye düşünmüştüm o zaman 17 kurayım teşekkürler
Çevrimdışı tux5
  • İleti: 41
glxgears komutunu verdiğimde şu hatayı alıyorum:
$ glxgears
Diğer çıktılar:
[ 1178.154609] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 1178.155096] [INFO]Configured driver: nvidia
[ 1178.155186] [ERROR]You've no permission to communicate with the Bumblebee daemon. Try adding yourself to the 'bumblebee' group
[ 1178.155206] [DEBUG]Socket closed.
[ 1178.155237] [ERROR]Could not connect to bumblebee daemon - is it running?
 $ sudo optirun -vvv glxgears
[ 1184.480232] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 1184.480591] [INFO]Configured driver: nvidia
[ 1184.480753] [DEBUG]optirun version 3.2.1 starting...
[ 1184.480767] [DEBUG]Active configuration:
[ 1184.480772] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 1184.480776] [DEBUG] X display: :8
[ 1184.480780] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-361:/usr/lib32/nvidia-361
[ 1184.480785] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 1184.480790] [DEBUG] Accel/display bridge: auto
[ 1184.480798] [DEBUG] VGL Compression: proxy
[ 1184.480810] [DEBUG] VGLrun extra options:
[ 1184.480817] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 1184.480865] [DEBUG]Using auto-detected bridge virtualgl
[ 1184.902756] [INFO]Response: Yes. X is active.
[ 1184.902770] [INFO]Running application using virtualgl.
[ 1184.902870] [DEBUG]Process vglrun started, PID 24857.
modprobe: FATAL: Module nvidia-modeset not found in directory /lib/modules/4.4.0-21-generic
4188 frames in 5.0 seconds = 837.412 FPS
4185 frames in 5.0 seconds = 836.862 FPS
4207 frames in 5.0 seconds = 841.170 FPS
4013 frames in 5.0 seconds = 802.413 FPS
4177 frames in 5.0 seconds = 835.190 FPS
[VGL] ERROR: in readback--
[ 1210.420978] [DEBUG]SIGCHILD received, but wait failed with No child processes
[ 1210.421124] [DEBUG]Socket closed.
[ 1210.421206] [DEBUG]Killing all remaining processes.
# to take effect.
[bumblebeed]
VirtualDisplay=:8
# server exits.
# be ignored.
Driver=nvidia
# Xorg binary to run
XorgBinary=/usr/lib/xorg/Xorg
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
[driver-nvidia]
KernelDriver=nvidia-361
PMMethod=auto
LibraryPath=/usr/lib/nvidia-361:/usr/lib32/nvidia-361
XorgModulePath=/usr/lib/nvidia-361/xorg,/usr/lib/xorg/modules
[driver-nouveau]
PMMethod=auto
    Driver      "nvidia"
    BusID "PCI:03:00:0"
ii  bumblebee                                    3.2.1-96~xenialppa1                        amd64        NVIDIA Optimus support for Linux
ii  nvidia-361                                   361.45.18-0ubuntu0~gpu16.04.1              amd64        NVIDIA binary driver - version 361.45.18
ii  nvidia-prime-applet                          1.0.4                                      all          An applet for NVIDIA Prime
ii  primus                                       20150328-1~xenialppa1                      amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                            20150328-1~xenialppa1                      amd64        Shared libraries for primus
ii  primus-libs:i386                             20150328-1~xenialppa1                      i386         Shared libraries for primus
ii  primus-libs-ia32:i386                        20150328-1~xenialppa1                      i386         Shared libraries for primus (32-bit)
03:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 840M] (rev ff)
Aşağıdaki komutla kullanıcıyı bumblebee grubuna ekleyip sistemi yeniden başlatmayı deneyiniz.
sudo adduser $USER bumblebee
Bu sorun için libgl1-mesa-dri paketini yeniden kurmayı deneyiniz.
sudo apt-get install --reinstall libgl1-mesa-dri
Çevrimdışı tux5
  • İleti: 41
Yine aynı hata geliyor.
$ glxgears
$ sudo adduser $USER bumblebee
The user `mh' is already a member of `bumblebee'
Not:Sistemi yeniden başlattıktan sonra 'Cinnamon just crashed.You are currently runnig in Fallback mode.Do you want to restart Cinnamon.Yes/No' hatası geldi.Bende No'ya bastım.
« Son Düzenleme: 02 Temmuz 2016, 23:09:48 Gönderen: tux5 »
cat /etc/modprobe.d/bumblebee.conf
Çevrimdışı tux5
  • İleti: 41
$ cat /etc/modprobe.d/bumblebee.conf
# This file is installed by bumblebee, do NOT edit!
# to be used by kmod / module-init-tools, and installed in /etc/modprobe.d/
# or equivalent
# do not automatically load nouveau as it may prevent nvidia from loading
blacklist nouveau
# do not automatically load nvidia as it's unloaded anyway when bumblebeed
# starts and may fail bumblebeed to disable the card in a race condition.
# Debian
blacklist nvidia
blacklist nvidia-current
blacklist nvidia-legacy-304xx
blacklist nvidia-legacy-340xx
# Ubuntu
blacklist nvidia
blacklist nvidia-current-updates
# 304
blacklist nvidia-304
blacklist nvidia-304-updates
blacklist nvidia-experimental-304
# 310
blacklist nvidia-310
blacklist nvidia-310-updates
blacklist nvidia-experimental-310
# 313
blacklist nvidia-313
blacklist nvidia-313-updates
blacklist nvidia-experimental-313
# 319
blacklist nvidia-319
blacklist nvidia-319-updates
blacklist nvidia-experimental-319
# 325
blacklist nvidia-325
blacklist nvidia-325-updates
blacklist nvidia-experimental-325
# 331
blacklist nvidia-331
blacklist nvidia-331-updates
blacklist nvidia-experimental-331
# 334
blacklist nvidia-334
blacklist nvidia-334-updates
blacklist nvidia-experimental-334
# 337
blacklist nvidia-337
blacklist nvidia-337-updates
blacklist nvidia-experimental-337
# 340
blacklist nvidia-340
blacklist nvidia-340-updates
blacklist nvidia-experimental-340
# 343
blacklist nvidia-343
blacklist nvidia-343-updates
blacklist nvidia-experimental-343
# 346
blacklist nvidia-346
blacklist nvidia-346-updates
blacklist nvidia-experimental-346
# 349
blacklist nvidia-349
blacklist nvidia-349-updates
blacklist nvidia-experimental-349
# 352
blacklist nvidia-352
blacklist nvidia-352-updates
blacklist nvidia-experimental-352
# 355
blacklist nvidia-355
blacklist nvidia-355-updates
blacklist nvidia-experimental-355
# 358
blacklist nvidia-358
blacklist nvidia-358-updates
blacklist nvidia-experimental-358
# 361
blacklist nvidia-361
blacklist nvidia-361-updates
blacklist nvidia-experimental-361
# 364
blacklist nvidia-364
blacklist nvidia-364-updates
blacklist nvidia-experimental-364
Çevrimdışı serenler
  • İleti: 9
1-son kullanıcı için kararlı ve güncel bir dağıtım olarak hangisini önerirsiniz?
2-Linux Mint 13'ü kaldırmadan yani yükleyici cd ya da usb kullanmadan dağıtımımı nasıl yükseltebilirim? Eminim forumda var ama bulamadım. Bağlantısını paylaşabilir misiniz?
