Gönderen Konu: Lmde2 bumblebee  (Okunma sayısı 3842 defa)
Çevrimdışı Kibritt
  • İleti: 28
Lmde2 bumblebee
« : 16 Mart 2017, 01:25:38 »
https://wiki.debian.org/Bumblebee#Installation
bu sitedeki gibi kurulum yaptım doğrumu yaptım bilmiyorum
çıktılar bu şekilde bi bakarmısınız
inxi -SGx
System:    Host: sem Kernel: 3.16.0-4-amd64 x86_64 (64 bit gcc: 4.8.4)
           Desktop: MATE 1.16.1 (Gtk 3.14.5+4) Distro: LinuxMint 2 betsy
           Card-2: NVIDIA GF117M [GeForce 610M/710M/820M / GT 620M/625M/630M/720M]
           bus-ID: 01:00.0
           Display Server: X.Org 1.16.4 drivers: intel (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.00hz
           GLX Version: 3.0 Mesa 10.3.2 Direct Rendering: Yes
01:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/820M / GT 620M/625M/630M/720M] (rev ff)
LVDS1 connected 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
   1366x768      60.00*+
   1360x768      59.80    59.96
   1024x768      60.00
   800x600       60.32    56.25
   640x480       59.94
ii  bumblebee                             3.2.1-7                              amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                      3.2.1-7                              amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  glx-alternative-nvidia                0.5.1                                amd64        allows the selection of NVIDIA as GLX provider
ii  libegl1-nvidia:amd64                  340.101-1                            amd64        NVIDIA binary EGL library
ii  libgl1-nvidia-glx:amd64               340.101-1                            amd64        NVIDIA binary OpenGL/GLX libraries
ii  libnvidia-eglcore:amd64               340.101-1                            amd64        NVIDIA binary EGL core libraries
ii  libnvidia-ml1:amd64                   340.101-1                            amd64        NVIDIA Management Library (NVML) runtime library
ii  nvidia-alternative                    340.101-1                            amd64        allows the selection of NVIDIA as GLX provider
ii  nvidia-driver                         340.101-1                            amd64        NVIDIA metapackage
ii  nvidia-driver-bin                     340.101-1                            amd64        NVIDIA driver support binaries
ii  nvidia-installer-cleanup              20141201+1                           amd64        cleanup after driver installation with the nvidia-installer
ii  nvidia-kernel-common                  20141201+1                           amd64        NVIDIA binary kernel module support files
ii  nvidia-kernel-dkms                    340.101-1                            amd64        NVIDIA binary kernel module DKMS source
ii  nvidia-modprobe                       340.46-1                             amd64        utility to load NVIDIA kernel modules and create device nodes
ii  nvidia-settings                       340.46-2                             amd64        tool for configuring the NVIDIA graphics driver
ii  nvidia-support                        20141201+1                           amd64        NVIDIA binary graphics driver support files
ii  nvidia-vdpau-driver:amd64             340.101-1                            amd64        Video Decode and Presentation API for Unix - NVIDIA driver
ii  primus                                0~20140711-1                         amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                     0~20140711-1                         amd64        Shared libraries for primus
ii  primus-libs:i386                      0~20140711-1                         i386         Shared libraries for primus
ii  xserver-xorg-video-nvidia             340.101-1                            amd64        NVIDIA binary Xorg driver
Ynt: Lmde2 bumblebee
« Yanıtla #1 : 16 Mart 2017, 10:24:09 »
Çevrimdışı Kibritt
  • İleti: 28
« Yanıtla #2 : 16 Mart 2017, 11:31:32 »
sabah açtım masaustu gelmedı bende normal linux mint kurdum bumblebee'yi kurdum sorunsuz calısıyor.
nasıl bu değerler sizce
http://i.hizliresim.com/dP33rL.png
« Yanıtla #3 : 16 Mart 2017, 12:54:47 »
Şu an sorun yok gibi görünüyor, Bumblebee sorunsuz çalışıyor.
LMDE için aşağıdaki bağlantıda bulunan SolydXK'nın DDM aracı yardımıyla kurulum gerçekleştirilebilir. Paketi indirip sağ tık Gdebi ile kurabilirsiniz.
http://repository.solydxk.com/pool/main/d/ddm/
Bu aracın Debian tabanlı sistemlerde Bumblebee'yi otomatik kurma özelliği mevcut, Ubuntu tabanlı Linux mint'de denemeyin.
Çevrimdışı Kibritt
  • İleti: 28
« Yanıtla #4 : 16 Mart 2017, 13:36:36 »
Tamam boza boza öğrenecez artık şuan çok sağlam çalışıyor bir sıkıntım yok teşekkürler..
isterseniz konuyu kilitleyebilirsiniz.
