Gönderen Konu: Bumblebee Düzgün Çalışmıyor!  (Okunma sayısı 2423 defa)
Çevrimdışı burk6n
  • İleti: 12
  • printf("Hello World");
  • Grafik Kartı: Nvidia Gtx m860
  • İşlemci: Intel Core i5
« : 09 Nisan 2017, 01:13:36 »
Bumblebee kurdum ancak
optirun glxgears kodu ile hata veriyor.Gerekli çıktıları sırasıyla aşağıya ekliyorum.Yardımınız için şimdiden teşekkürler.
optirun -vvv glxgears
cat /proc/cmdline
[ 1431.723122] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 1431.723333] [INFO]Configured driver: nvidia
[ 1431.723432] [DEBUG]optirun version 3.2.1 starting...
[ 1431.723438] [DEBUG]Active configuration:
[ 1431.723442] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 1431.723446] [DEBUG] X display: :8
[ 1431.723450] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-375:/usr/lib32/nvidia-375
[ 1431.723452] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 1431.723455] [DEBUG] Accel/display bridge: auto
[ 1431.723457] [DEBUG] VGL Compression: proxy
[ 1431.723464] [DEBUG] VGLrun extra options:
[ 1431.723466] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 1431.723495] [DEBUG]Using auto-detected bridge virtualgl
[ 1432.010864] [INFO]Response: No - error: [XORG] (EE) Failed to load module "mouse" (module does not exist, 0)
[ 1432.010880] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) Failed to load module "mouse" (module does not exist, 0)
[ 1432.010885] [DEBUG]Socket closed.
[ 1432.010900] [ERROR]Aborting because fallback start is disabled.
[ 1432.010904] [DEBUG]Killing all remaining processes.
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=nvidia
# Xorg binary to run
XorgBinary=/usr/lib/xorg/Xorg
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
[driver-nvidia]
KernelDriver=nvidia-375
PMMethod=auto
LibraryPath=/usr/lib/nvidia-375:/usr/lib32/nvidia-375
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia-375/xorg,/usr/lib/xorg/modules
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
Section "ServerLayout"
    Identifier  "Layout0"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
    BusID "PCI:0a:00:0"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
ii  bumblebee                                    3.2.1-97~xenialppa1                          amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                             3.2.1-97~xenialppa1                          amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-375                                   375.39-0ubuntu0.16.04.1                      amd64        NVIDIA binary driver - version 375.39
ii  nvidia-settings                              381.09-0ubuntu0~gpu16.04.2                   amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                       20150328-3~xenialppa2                        amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                            20150328-3~xenialppa2                        amd64        Shared libraries for primus
ii  primus-libs:i386                             20150328-3~xenialppa2                        i386         Shared libraries for primus
ii  primus-libs-ia32:i386                        20150328-3~xenialppa2                        i386         Shared libraries for primus (32-bit)
ii  virtualgl                                    2.4.1-1~xenialppa1                           amd64        Toolkit for displaying OpenGL applications to thin clients
ii  virtualgl-libs:amd64                         2.4.1-1~xenialppa1                           amd64        Library files for virtualgl
00:02.0 VGA compatible controller: Intel Corporation Broadwell-U Integrated Graphics (rev 09)
0a:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 830M] (rev a2)
BOOT_IMAGE=/boot/vmlinuz-4.4.0-21-generic root=UUID=2382f831-6319-4342-8bd2-a103273e6764 ro nogpumanager quiet splash vt.handoff=7
EBB
Ynt: Bumblebee Düzgün Çalışmıyor!
« Yanıtla #1 : 10 Nisan 2017, 13:14:05 »
Çevrimdışı burk6n
  • İleti: 12
« Yanıtla #2 : 24 Nisan 2017, 01:53:02 »
Tamamen kaldırdım bumblebee'yi gerek kalmadı.Teşekkürler.
EBB
