Gönderen Konu: [Çözüldü] LMDE2 video ve ısınma problemi  (Okunma sayısı 3510 defa)
Çevrimdışı zapata1247
  • İleti: 12
« : 13 Nisan 2017, 11:48:02 »
2017 sürümünü kurdum.windowsta 40-45 arası olan sıcaklık bunda 70 dereceye kadar cıkıyor sadece tarayıcı açıkken.Bir de filmleri akıcı bir şekilde oynatmıyor kare kare oynatıyor vlc playerda.bumblebee yükledim değişen bişey olmadı.
inxi -SGx
System:    Host: tuco Kernel: 3.16.0-4-amd64 x86_64 (64 bit gcc: 4.8.4)
           Desktop: Cinnamon 3.2.7 (Gtk 3.14.5+4) Distro: LinuxMint 2 betsy
           Card-2: NVIDIA GF108M [GeForce GT 630M] bus-ID: 01:00.0
           Display Server: X.Org 1.16.4 drivers: intel (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.01hz
           GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.5, 256 bits)
           GLX Version: 3.0 Mesa 10.3.2 Direct Rendering: Yes
OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 3.5, 256 bits)
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 630M] (rev ff)
   1366x768      60.01*+
   1360x768      59.80    59.96
   1024x768      60.00
   800x600       60.32    56.25
   640x480       59.94
ii  bumblebee                             3.2.1-7                              amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                      3.2.1-7                              amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  glx-alternative-nvidia                0.5.1                                amd64        allows the selection of NVIDIA as GLX provider
ii  libegl1-nvidia:amd64                  340.101-1                            amd64        NVIDIA binary EGL library
ii  libgl1-nvidia-glx:amd64               340.101-1                            amd64        NVIDIA binary OpenGL/GLX libraries
ii  libnvidia-eglcore:amd64               340.101-1                            amd64        NVIDIA binary EGL core libraries
ii  libnvidia-ml1:amd64                   340.101-1                            amd64        NVIDIA Management Library (NVML) runtime library
ii  nvidia-alternative                    340.101-1                            amd64        allows the selection of NVIDIA as GLX provider
ii  nvidia-detect                         340.101-1                            amd64        NVIDIA GPU detection utility
ii  nvidia-driver                         340.101-1                            amd64        NVIDIA metapackage
ii  nvidia-driver-bin                     340.101-1                            amd64        NVIDIA driver support binaries
ii  nvidia-installer-cleanup              20141201+1                           amd64        cleanup after driver installation with the nvidia-installer
ii  nvidia-kernel-common                  20141201+1                           amd64        NVIDIA binary kernel module support files
ii  nvidia-kernel-dkms                    340.101-1                            amd64        NVIDIA binary kernel module DKMS source
ii  nvidia-modprobe                       340.46-1                             amd64        utility to load NVIDIA kernel modules and create device nodes
ii  nvidia-support                        20141201+1                           amd64        NVIDIA binary graphics driver support files
ii  nvidia-vdpau-driver:amd64             340.101-1                            amd64        Video Decode and Presentation API for Unix - NVIDIA driver
ii  primus                                0~20140711-1                         amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                     0~20140711-1                         amd64        Shared libraries for primus
ii  primus-libs:i386                      0~20140711-1                         i386         Shared libraries for primus
ii  xserver-xorg-video-nvidia             340.101-1                            amd64        NVIDIA binary Xorg driver
« Son Düzenleme: 13 Nisan 2017, 16:03:12 Gönderen: zapata1247 »
Ynt: LMDE2 video ve ısınma problemi
« Yanıtla #1 : 13 Nisan 2017, 15:02:10 »
Öncelikle buradaki öneriyi uygulamayı deneyiniz ve ardından aşağıdaki komutun çıktısına bakalım.
inxi -Gx
  • İleti: 12
« Yanıtla #2 : 13 Nisan 2017, 16:02:16 »
Sorun çözüldü çok sağolun  :)
inxi -Gx
Ynt: [Çözüldü] LMDE2 video ve ısınma problemi
« Yanıtla #3 : 13 Nisan 2017, 16:25:02 »
Önceden 2D kipinde oturum açılıyormuş ve donanımsal hızlandırma yerine yazılımsal hızlandırma etkin olmuş.
Oturum düzeltilince donanımsal hızlandırma etkin olduğu için sorun kendiliğinden çözülmüş oldu.
