Gönderen Konu: [Çözüldü] Görüntü donma kırılma sorunu  (Okunma sayısı 6175 defa)
Çevrimdışı HLLZDMR
  • İleti: 110
    • halilc.ozdmr
  • Dağıtım: 19.3 Tricia
  • Grafik Kartı: GeForce 950M
  • İşlemci: İntel core i7-6700HQ
« : 26 Mayıs 2017, 21:53:46 »
Herkese hayırlı ramazanlar hayırlı akşamlar,benim linuxu kurduğumdan beri kırılma donma sorunu var özellikle en çok youtube tarayıcı üzerinde oluyor.Normalde hdd'ten film izlerkende oluyor takılma donma kırılma gibi.Hemen çıktıları paylaşıyorum..
inxi -SGx
System:    Host: root Kernel: 4.4.0-78-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Linux Mint 18.1 Serena
Graphics:  Card-1: Intel Skylake Integrated Graphics bus-ID: 00:02.0
           Card-2: NVIDIA GM107M [GeForce GTX 950M] bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 driver: nvidia
           Resolution: 1920x1080@60.05hz
           GLX Renderer: GeForce GTX 950M/PCIe/SSE2
           GLX Version: 4.5.0 NVIDIA 381.22 Direct Rendering: Yes
OpenGL renderer string: GeForce GTX 950M/PCIe/SSE2
    GL_KHR_robustness, GL_KTX_buffer_region, GL_NVX_conditional_render,
    GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB,
    GL_NV_conditional_render, GL_NV_copy_buffer, GL_NV_copy_image,
00:02.0 VGA compatible controller: Intel Corporation Skylake Integrated Graphics (rev 06)
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 950M] (rev a2)
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
eDP-1-1 connected 1920x1080+0+0 344mm x 193mm
   1920x1080     60.05*+  59.93
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1280x1024     60.02
   1440x900      59.89
   1280x960      60.00
   1360x768      59.80    59.96
   1152x864      60.00
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       60.00
   960x540       59.99
   840x525       60.01    59.88
   800x512       60.17
   700x525       59.98
   640x512       60.02
   720x450       59.89
   640x480       60.00    59.94
   680x384       59.80    59.96
   576x432       60.06
   512x384       60.00
   400x300       60.32    56.34
   320x240       60.05
HDMI-1-1 disconnected
DP-1-1 disconnected
Section "ServerLayout"
    Identifier "layout"
    Screen 0 "nvidia"
    Inactive "intel"
    Identifier "intel"
    Driver "modesetting"
    BusID "PCI:0@0:2:0"
    Option "AccelMethod" "None"
Section "Screen"
    Identifier "intel"
    Device "intel"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:1@0:0:0"
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
ii  bumblebee                                                   3.2.1-98~xenialppa1                          amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                                            3.2.1-98~xenialppa1                          amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
rc  nvidia-375                                                  375.39-0ubuntu0.16.04.1                      amd64        NVIDIA binary driver - version 375.39
ii  nvidia-381                                                  381.22-0ubuntu0~gpu16.04.2                   amd64        NVIDIA binary driver - version 381.22
rc  nvidia-opencl-icd-375                                       375.39-0ubuntu0.16.04.1                      amd64        NVIDIA OpenCL ICD
ii  nvidia-prime                                                0.8.2linuxmint1                              amd64        Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                                         1.0.6                                        all          An applet for NVIDIA Prime
ii  nvidia-settings                                             381.22-0ubuntu0~gpu16.04.1                   amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                                      20150328-3~xenialppa2                        amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                                           20150328-3~xenialppa2                        amd64        Shared libraries for primus
ii  primus-libs:i386                                            20150328-3~xenialppa2                        i386         Shared libraries for primus
ii  primus-libs-ia32:i386                                       20150328-3~xenialppa2                        i386         Shared libraries for primus (32-bit)
ii  virtualgl                                                   2.4.1-1~xenialppa1                           amd64        Toolkit for displaying OpenGL applications to thin clients
ii  virtualgl-libs:amd64                                        2.4.1-1~xenialppa1                           amd64        Library files for virtualgl
« Son Düzenleme: 31 Mayıs 2017, 21:39:10 Gönderen: HLLZDMR »
Ynt: Görüntü donma kırılma sorunu
« Yanıtla #1 : 27 Mayıs 2017, 14:11:59 »
Forumda Nvidia Prime ile Nvidia GPU'yu kullandığınızda neden yırtılma sorunu yaşayacağınız ile ilgili konular mevcut.
Örneğin:
https://forum.linuxmint.net.tr/index.php?topic=8064.0
https://forum.linuxmint.net.tr/index.php?topic=250.msg45754#msg45754
https://forum.linuxmint.net.tr/index.php?topic=7890.msg48546#msg48546
https://forum.linuxmint.net.tr/index.php?topic=7737.msg47733#msg47733
https://forum.linuxmint.net.tr/index.php?topic=6891.msg42968#msg42968
Lütfen forum içi aramayı ihmal etmeyelim.
Donma sorunu ile ilgili olarak 4. seviye güncellemeleri ve çekirdek güncellemelerini öneriyoruz genellikle.
« Son Düzenleme: 27 Mayıs 2017, 14:17:20 Gönderen: Butterfly »
Çevrimdışı HLLZDMR
  • İleti: 110
    • halilc.ozdmr
« Yanıtla #2 : 27 Mayıs 2017, 19:39:51 »
sudo mkdir -p /etc/X11/xorg.conf.d/ && echo -e 'Section "Device"\n Identifier "Intel Graphics"\n Driver "Intel"\n Option "AccelMethod" "sna"\n Option "TearFree" "true"\nEndSection' | sudo tee /etc/X11/xorg.conf.d/20-intel.confAslında ben intel cpu kullanmıyorum yani intel cpu seçili konumda değil , intel seçili iken daha fazla performans harcıyor ,nvidia 'da kullanıyorum benim nvidia'ya göre ayar yapmam lazım ekran görüntü ayarlarını.Ayrıca şunuda belirteyim linux minte ek olarak birşey yüklemedim ekran görüntü driver  yada onlara yakın birşey.Sade kurduğum halde,bumblebee kurdum ancak aktif değil yani aslında tam anlamıyla kurulmuşta sayılmaz.Ben bu sorunu çözemedim hiç .
« Yanıtla #3 : 28 Mayıs 2017, 13:49:38 »
[member=4793]HLLZDMR[/member] , Nvidia Prime ve Bumblebee seçeneklerini bir arada kullanmamanız gerekiyor. Eğer Nvidia Prime ile Ayar Yöneticisi yardımıyla GPU geçişi yapmayı tercih ediyorsanız, Bumblebee'yi kaldırmalısınız, tersi durumda Nvidia Prime kaldırılmalı.
Nvidia Prime ile Nvidia GPU'ya geçiş yaptığınızda yırtılma sorunlarının şu an çözümü olmadığını yukarıdaki bağlantılardan görebilirsiniz.
Çevrimdışı HLLZDMR
  • İleti: 110
    • halilc.ozdmr
« Yanıtla #4 : 28 Mayıs 2017, 14:29:59 »
Yani bumblebee ve prime'yi kaldırırsam sorun çözülecek o zaman
« Yanıtla #5 : 28 Mayıs 2017, 14:43:42 »
Nvidia sürücüsü Nvidia Prime ile etkinleştiğinde yırtılma sorununun çözümü yok. Yırtılma sorunu yaşamak istemiyorsanız Nvidia Prime seçeneğini kaldırınız. Şu an sistemde neler yaptığınızı bilmediğim için ayrıntılı bilgi vermedikçe yönlendirme yapamam. Şu an sistemde Bumblebee ve Nvidia Prime bir arada kurulu görnüyor ve Nvidia Prime ile Nvidia GPU etkin. Sistemi bu şekilde kullanmamanız gerekir.
Öncelikle hangi yöntemi tercih edeceğinizi belirtiniz.
« Son Düzenleme: 28 Mayıs 2017, 14:46:42 Gönderen: Butterfly »
Çevrimdışı HLLZDMR
  • İleti: 110
    • halilc.ozdmr
« Yanıtla #6 : 29 Mayıs 2017, 18:53:43 »
Prime ve bumblebee kaldırdım şimdi ne yapmam gerekiyor?
« Son Düzenleme: 30 Mayıs 2017, 00:09:45 Gönderen: HLLZDMR »
« Yanıtla #7 : 30 Mayıs 2017, 09:00:20 »
Bumblebee'yi tercih ediyorsanız buradaki konuda anlatıldığı biçimde kurulum yapabilirsiniz.
Eğer Cinnamon masaüstünü kullanıyorsanız, Nvidia PPU ile çalıştırmak istediğiniz uygulamanın başlatıcısını menüden bulup sağ tıklayın ve "Nvidia GPU ile çalıştır" seçeneği ile başlatın.
Nvidia Prime ve Bumblebee arasındaki temel farkları burada anlatmıştık.
Çevrimdışı HLLZDMR
  • İleti: 110
    • halilc.ozdmr
« Yanıtla #8 : 31 Mayıs 2017, 02:11:47 »
XFCE masaüstü kullanıyorum bunun için farklı bir yol var mı ? Yoksa direk kurayım mı bumblebee yi ?
« Son Düzenleme: 31 Mayıs 2017, 02:46:31 Gönderen: HLLZDMR »
« Yanıtla #9 : 31 Mayıs 2017, 08:37:43 »
Xfce'de önce aşağıdaki komutla compton paketini kurun,
sudo apt-get install compton
sonra burada anlatıldığı biçimde Xfwm+Compton seçeneğini seçmeyi deneyin.
Buna ek olarak Bumblebee kurulum konusunda anlatıldığı gibi Bumblebee'yi kurabilirsiniz.
Çevrimdışı HLLZDMR
  • İleti: 110
    • halilc.ozdmr
« Yanıtla #10 : 31 Mayıs 2017, 21:38:54 »
Peki hocam teşekkürler herşey için.
