Gönderen Konu: Kurulum Sonrası Diğer HDDye ulaşamıyorum.  (Okunma sayısı 2487 defa)
Çevrimdışı Pitfall
  • İleti: 8
  • Dağıtım: Mint 18.1
  • Grafik Kartı: AMD RX 470
  • İşlemci: İntel G4560
« : 11 Haziran 2017, 15:11:46 »
Arkadaşlar bilgisayarda disk görünmesine rağmen tıkladığım zaman hata ile karşılaşıyorum
konum bağlanamadı Error mounting /dev/sdb2 at /media/vernian/Yerel Disk: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000" "/dev/sdb2" "/media/vernian/Yerel Disk"' exited with non-zero exit status 14: The disk contains an unclean file system (0, 0).
Failed to mount '/dev/sdb2': İşleme izin verilmedi
vernian@vernian-Z270X-Ultra-Gaming ~ $ inxi -Fxz
System:    Host: vernian-Z270X-Ultra-Gaming Kernel: 4.10.0-22-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.2.7 (Gtk 3.18.9-1ubuntu3.3)
Machine:   System: Gigabyte product: Z270X-Ultra Gaming v: Default string
           Mobo: Gigabyte model: Z270X-Ultra Gaming-CF v: x.x
           Bios: American Megatrends v: F5 date: 04/07/2017
CPU:       Dual core Intel Pentium G4560 (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 14016
           clock speeds: max: 3500 MHz 1: 800 MHz 2: 799 MHz 3: 800 MHz
           4: 799 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Device 67df bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 drivers: ati,amdgpu (unloaded: fbdev,vesa,radeon)
           Resolution: 1920x1080@60.00hz
           GLX Renderer: Gallium 0.4 on AMD POLARIS10 (DRM 3.9.0 / 4.10.0-22-generic, LLVM 4.0.0)
           GLX Version: 3.0 Mesa 17.1.2 - padoka PPA Direct Rendering: Yes
Audio:     Card-1 Intel Device a2f0 driver: snd_hda_intel bus-ID: 00:1f.3
           Card-2 Advanced Micro Devices [AMD/ATI] Device aaf0
           Card-3 Kingston driver: USB Audio usb-ID: 003-002
           Sound: Advanced Linux Sound Architecture v: k4.10.0-22-generic
Network:   Card: Intel Ethernet Connection (2) I219-V
           driver: e1000e v: 3.2.6-k bus-ID: 00:1f.6
           IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 1250.3GB (1.0% used)
           ID-1: /dev/sda model: Samsung_SSD_850 size: 250.1GB
           ID-2: /dev/sdb model: ST1000DM010 size: 1000.2GB
Partition: ID-1: / size: 41G used: 8.4G (22%) fs: ext4 dev: /dev/sda5
           ID-2: swap-1 size: 3.19GB used: 0.00GB (0%) fs: swap dev: /dev/sda6
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C gpu: 30.0
Info:      Processes: 182 Uptime: 11 min Memory: 1049.7/7936.0MB
« Son Düzenleme: 11 Haziran 2017, 15:16:42 Gönderen: Pitfall »
Ynt: Kurulum Sonrası Diğer HDDye ulaşamıyorum.
« Yanıtla #1 : 11 Haziran 2017, 15:25:11 »
Yukarıdaki ifade ile forum içi arama yapmayı deneyiniz, bununla ilgili forumda konu mevcut.
Lütfen konu açmadan önce forum içi arama özelliğini kullanmayı ihmal etmeyelim.
