Gönderen Konu: Tenda W311u+ bağlanamama  (Okunma sayısı 2761 defa)
Çevrimdışı hatipoglu
  • İleti: 4
  • Dağıtım: mint 18.1
  • Grafik Kartı: radeon hd5500
  • İşlemci: intel core2 duo
« : 29 Haziran 2017, 19:18:10 »
bilgisayarımda iki tane wifi kartı var ama ben diğerini kullanmak istiyorum. ancak o da kullanılmaz diyor.
aynı cihazla ilgili eski konuya baktım ama malesef daha günlük linux kullanıcısıyım. yardımcı olursanız sevinirim.
System:    Host: hatipoglu-System-Product-Name Kernel: 4.4.0-53-generic i686 (32 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.2.6 (Gtk 3.18.9-1ubuntu3.1) dm: mdm
Network:   Card-1: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet
           driver: ATL1E port: ec00 bus-ID: 02:00.0 chip-ID: 1969:1026
           Card-2: Qualcomm Atheros AR5416 Wireless Network Adapter [AR5008 802.11(a)bgn]
           driver: ath9k bus-ID: 04:01.0 chip-ID: 168c:0023
           IF: wlp4s1 state: up mac: <filter>
           Card-3: Ralink RT2870/RT3070 Wireless Adapter
           driver: rt2800usb v: 2.3.0 usb-ID: 001-010 chip-ID: 148f:3070
           IF: wlxc83a35cbb66d state: N/A mac: N/A
02:00.0 Ethernet controller [0200]: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet [1969:1026] (rev b0)
Subsystem: ASUSTeK Computer Inc. P5KPL-CM Motherboard [1043:8304]
Kernel driver in use: ATL1E
04:01.0 Network controller [0280]: Qualcomm Atheros AR5416 Wireless Network Adapter [AR5008 802.11(a)bgn] [168c:0023] (rev 01)
Subsystem: Qualcomm Atheros AR5416 Wireless Network Adapter [AR5008 802.11(a)bgn] [168c:3071]
Kernel driver in use: ath9k
Kernel modules: ath9k
Bus 001 Device 008: ID 058f:6362 Alcor Micro Corp. Flash Card Reader/Writer
Bus 001 Device 010: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Bus 002 Device 003: ID 04d9:1702 Holtek Semiconductor, Inc. Keyboard LKS02
Bus 002 Device 002: ID 1b80:b412 Afatech
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: phy1: Wireless LAN
Soft blocked: no
Hard blocked: no
SCSI
  *-network
       açıklama: Eternet interface
       ürün: AR8121/AR8113/AR8114 Gigabit or Fast Ethernet
       üretici: Qualcomm Atheros
       physical id: 0
       bus info: pci@0000:02:00.0
       mantıksal ad: enp2s0
       sürüm: b0
       serial: 00:24:8c:9d:bc:18
       kapasite: 1Gbit/s
       genişlik: 64 bits
       saat: 33MHz
       kapasiteler: pm msi pciexpress bus_master cap_list eternet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       yapılandırma: autonegotiation=on broadcast=yes driver=ATL1E driverversion=1.0.0.7-NAPI firmware=L1e latency=0 link=no multicast=yes port=twisted pair
       kaynaklar: irq:17 bellek:feac0000-feafffff ioport:ec00(boyut=128)
  *-network
       açıklama: Kablosuz arayüz
       ürün: AR5416 Wireless Network Adapter [AR5008 802.11(a)bgn]
       physical id: 1
       bus info: pci@0000:04:01.0
       mantıksal ad: wlp4s1
       sürüm: 01
       serial: 74:ea:3a:ca:9c:97
       genişlik: 32 bits
       saat: 66MHz
       kapasiteler: bus_master cap_list eternet physical wireless
       yapılandırma: broadcast=yes driver=ath9k driverversion=4.4.0-53-generic firmware=N/A ip=192.168.0.18 latency=168 link=yes multicast=yes wireless=IEEE 802.11bgn
       kaynaklar: irq:16 bellek:febf0000-febfffff
  *-network ETKİSİZLEŞTİRİLDİ
       physical id: 1
       bus info: usb[member=3516]1[/member]:6
       mantıksal ad: wlxc83a35cbb66d
       serial: c8:3a:35:cb:b6:6d
       yapılandırma: broadcast=yes driver=rt2800usb driverversion=4.4.0-53-generic firmware=0.29 link=no multicast=yes wireless=IEEE 802.11bg
o        no wireless extensions.
enp2s0    no wireless extensions.
          Bit Rate=39 Mb/s   Tx-Power=20 dBm
          Power Management:off
          Mode:Managed  Access Point: Not-Associated   Tx-Power=0 dBm
cpuid                  16384  0
rt2800usb              28672  0
rt2x00usb              20480  1 rt2800usb
rt2800lib              90112  1 rt2800usb
rt2x00lib              49152  3 rt2x00usb,rt2800lib,rt2800usb
crc_ccitt              16384  1 rt2800lib
drbg                   28672  1
ctr                    16384  2
ccm                    20480  2
arc4                   16384  4
snd_hda_codec_via      20480  1
snd_hda_codec_generic    69632  1 snd_hda_codec_via
ath9k                 135168  0
ath9k_common           36864  1 ath9k
snd_hda_intel          36864  5
ath9k_hw              458752  2 ath9k_common,ath9k
snd_hda_codec         118784  4 snd_hda_codec_hdmi,snd_hda_codec_via,snd_hda_codec_generic,snd_hda_intel
snd_hda_core           61440  5 snd_hda_codec_hdmi,snd_hda_codec_via,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel
ath                    24576  3 ath9k_common,ath9k,ath9k_hw
mac80211              659456  4 ath9k,rt2x00lib,rt2x00usb,rt2800lib
snd_pcm                94208  4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_core
cfg80211              499712  5 ath,ath9k_common,ath9k,mac80211,rt2x00lib
snd                    69632  21 snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_hda_codec_via,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
lpc_ich                20480  0
asus_atk0110           20480  0
btrfs                1003520  0
xor                    28672  1 btrfs
uas                    20480  0
usb_storage            57344  1 uas
hid                    98304  2 hid_generic,usbhid
radeon               1466368  5
i2c_algo_bit           16384  1 radeon
ttm                    90112  1 radeon
drm_kms_helper        139264  1 radeon
psmouse               118784  0
floppy                 61440  0
drm                   311296  8 ttm,drm_kms_helper,radeon
atl1e                  40960  0
« Son Düzenleme: 29 Haziran 2017, 19:25:19 Gönderen: hatipoglu »
Ynt: Tenda W311u+ bağlanamama
« Yanıtla #1 : 29 Haziran 2017, 22:19:08 »
Öncelikle sisteminizi aşağıdaki şekilde sistemi güncellemeyi dener misiniz?
Aşağıdaki komutla linux-firmware paketinin güncellendiğinden emin olunuz.
sudo apt-get install --reinstall linux-firmware
Ardından, Güncelleme Yöneticisi => Görünüm menüsü => "Linux çekirdekleri" aracı yardımıyla 4.10.x serisi çekirdeğin son sürümünü kurunuz.
  • İleti: 4
« Yanıtla #2 : 30 Haziran 2017, 15:36:07 »
hocam öncelikkle teşekkürler ama olmadı başka yapabileceğim bişey
« Yanıtla #3 : 30 Haziran 2017, 16:01:22 »
Lütfen forum içi yazışmalarda, forum kurallarımız arasında bulunan yazım kurallarına özen gösterelim. İmla ve Yazım Kuralları
Aslında aygıt tanınmasıyla ilgili bir sorun yok, sadece aygıt pasifleştirilmiş görünüyor, ama çıktılara göre donanımsal ve yazılımsal bir pasifleştirme de yok. Aygıtı ağ yöneticisinden pasifleştirmiş olabilir misiniz?
Ayrıca ağ ile ilgili komutların çıktılarını bir daha rica edelim.
  • İleti: 4
« Yanıtla #4 : 30 Haziran 2017, 16:16:32 »
çıktılardan önce şey sorayım diğerini çıkarsam olma ihtimali varmı
System:    Host: hatipoglu-System-Product-Name Kernel: 4.10.0-26-generic i686 (32 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.2.7 (Gtk 3.18.9-1ubuntu3.3) dm: mdm
           IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
           driver: rt2800usb v: 2.3.0 usb-ID: 001-012 chip-ID: 148f:3070
Bus 001 Device 012: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Bus 002 Device 006: ID 1b80:b412 Afatech
Soft blocked: no
Hard blocked: no
4: phy4: Wireless LAN
Soft blocked: no
Hard blocked: no
*-network
       physical id: 0
       sürüm: b0
       boyut: 100Mbit/s
       kapasite: 1Gbit/s
       genişlik: 64 bits
       saat: 33MHz
       yapılandırma: autonegotiation=on broadcast=yes driver=ATL1E driverversion=1.0.0.7-NAPI duplex=full firmware=L1e ip=192.168.0.20 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
  *-network
       physical id: 1
       sürüm: 01
       genişlik: 32 bits
       saat: 66MHz
       yapılandırma: broadcast=yes driver=ath9k driverversion=4.10.0-26-generic firmware=N/A ip=192.168.0.18 latency=168 link=yes multicast=yes wireless=IEEE 802.11
       physical id: 1
       bus info: usb[member=3516]1[/member]:4
       yapılandırma: broadcast=yes driver=rt2800usb driverversion=4.10.0-26-generic firmware=0.29 link=no multicast=yes wireless=IEEE 802.11
          Bit Rate=1 Mb/s   Tx-Power=20 dBm
rt2800usb              28672  0
rt2800lib              81920  1 rt2800usb
rt2x00lib              53248  3 rt2800lib,rt2800usb,rt2x00usb
ccm                    20480  2
arc4                   16384  4
ath9k                 139264  0
ath9k_hw              454656  2 ath9k,ath9k_common
ath                    24576  3 ath9k_hw,ath9k,ath9k_common
mac80211              700416  4 rt2800lib,rt2x00lib,rt2x00usb,ath9k
cfg80211              532480  5 rt2x00lib,mac80211,ath9k,ath,ath9k_common
snd_hda_codec_hdmi     45056  1
lpc_ich                20480  0
snd_hda_codec         114688  4 snd_hda_intel,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec_via
snd_hda_core           69632  5 snd_hda_intel,snd_hda_codec,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec_via
snd_pcm                94208  4 snd_hda_intel,snd_hda_codec,snd_hda_core,snd_hda_codec_hdmi
snd_timer              28672  2 snd_seq,snd_pcm
snd                    65536  21 snd_hda_intel,snd_hwdep,snd_seq,snd_hda_codec,snd_timer,snd_rawmidi,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_seq_device,snd_pcm,snd_hda_codec_via
parport                45056  3 lp,parport_pc,ppdev
btrfs                1105920  0
xor                    28672  1 btrfs
raid6_pq              106496  1 btrfs
uas                    20480  0
radeon               1478656  5
psmouse               122880  0
ttm                    90112  1 radeon
atl1e                  36864  0
drm                   303104  8 radeon,ttm,drm_kms_helper
floppy                 61440  0
fjes                   61440  0
bu arada ethernet bağladım
« Son Düzenleme: 30 Haziran 2017, 16:20:40 Gönderen: hatipoglu »
« Yanıtla #5 : 30 Haziran 2017, 16:53:53 »
Aşağıdaki komutları sırasıyla uçbirimde çalıştırıamyı dener misiniz?
sudo rmmod ath9k
sudo rmmod rt2800usb
sudo modprobe rt2800usb
sudo service network-manager restart
sudo rfkill unblock all
Bunu tam olarak anlayamadım, dahili aygıtı pasifleştirme imkanı olup olmadığını mı soruyorsunuz?
  • İleti: 4
« Yanıtla #6 : 30 Haziran 2017, 17:01:06 »
hocam dediğim gibi dahili aygıtı çıkardım ve diğeri aktifleşti sizi boşuna yordum biraz ama iyi günler tekrar teşekkürler
« Yanıtla #7 : 30 Haziran 2017, 17:14:50 »
Bu durumda konuyu etiketlemeden kilitleyelim.
