Gönderen Konu: ubuntu 16.04 yavaş açılma ve programların geç açılması  (Okunma sayısı 5729 defa)
Çevrimdışı dolor
  • İleti: 75
  • mermer kafa
  • Dağıtım: linux mint
  • Masaüstü Ortamı: cinnamon sarah
  • Grafik Kartı: ati radeon 4500/5100 m
  • İşlemci: intel core i3 cpu 2.53 ghz
Masaüstü bilgisayarımda sadece ubuntu kullanıyorum. Garip bir şekilde yavaş açılıyor ayrıca programlar geç açılıp kapanıyor. Bazen programın kapatma menüleri bile görünmüyor. Yardımcı olur musunuz
systemd-analyze
Startup finished in 11.141s (firmware) + 4.341s (loader) + 2.457s (kernel) + 14.821s (userspace) = 32.761s
systemd-analyze blame
          9.880s apt-daily.service
          5.423s grub-common.service
          5.143s dev-sda2.device
          4.268s networking.service
          3.732s ModemManager.service
          3.322s accounts-daemon.service
          2.980s NetworkManager.service
          2.759s apparmor.service
          2.153s gpu-manager.service
          2.082s irqbalance.service
          2.035s ondemand.service
          1.929s speech-dispatcher.service
          1.841s thermald.service
          1.841s systemd-logind.service
          1.827s alsa-restore.service
          1.825s systemd-user-sessions.service
          1.822s pppd-dns.service
          1.821s rsyslog.service
          1.643s console-setup.service
          1.621s lightdm.service
          1.565s avahi-daemon.service
          1.243s dns-clean.service
          1.131s apport.service
lines 1-23...skipping...
          1.047s plymouth-start.service
lines 1-24...skipping...
           951ms colord.service
           899ms systemd-modules-load.service
           866ms rtkit-daemon.service
           857ms systemd-tmpfiles-setup-dev.service
           834ms systemd-journald.service
           719ms keyboard-setup.service
           674ms systemd-tmpfiles-setup.service
           670ms plymouth-quit-wait.service
           571ms ufw.service
           536ms udisks2.service
           505ms polkitd.service
           405ms upower.service
           310ms systemd-udevd.service
           300ms dev-mqueue.mount
           300ms sys-kernel-debug.mount
           299ms dev-hugepages.mount
           278ms systemd-journal-flush.service
           278ms systemd-random-seed.service
           260ms kmod-static-nodes.service
           210ms systemd-timesyncd.service
           207ms systemd-fsck[member=2665]Dev[/member]-disk-by\x2duuid-B4F4\x2d362F.service
           182ms setvtrgb.service
           147ms systemd-update-utmp.service
           141ms rc-local.service
           115ms dev-sda3.swap
           114ms user@1000.service
           112ms nvidia-persistenced.service
           105ms systemd-tmpfiles-clean.service
            82ms systemd-sysctl.service
            73ms systemd-udev-trigger.service
            49ms plymouth-read-write.service
            41ms systemd-remount-fs.service
            27ms boot-efi.mount
            14ms snapd.socket
             6ms snapd.autoimport.service
             2ms sys-fs-fuse-connections.mount
             2ms ureadahead-stop.service
             2ms resolvconf.service
             2ms systemd-update-utmp-runlevel.service
             1ms sys-kernel-config.mount
systemctl --state=failed
  UNIT               LOAD   ACTIVE SUB    DESCRIPTION
● ureadahead.service loaded failed failed Read required files in advance
LOAD   = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB    = The low-level unit activation state, values depend on unit type.
1 loaded units listed. Pass --all to see loaded but inactive units, too.
blkid
/dev/sdd1: UUID="895E-5F2C" TYPE="vfat" PARTLABEL="Microsoft Basic Data" PARTUUID="3d78f971-9b76-438f-87ba-c11915a17876"
cat /etc/fstab
# / was on /dev/sda2 during installation
UUID=6f231cc3-f28a-4dac-9193-d1c0aa9e5301 /               ext4    errors=remount-ro 0       1
# /boot/efi was on /dev/sda1 during installation
UUID=B4F4-362F  /boot/efi       vfat    umask=0077      0       1
# swap was on /dev/sda3 during installation
UUID=3a6d03c8-580f-4ec4-a9e1-db83ebc5f14e none            swap    sw              0       0
# /boot/grub/grub.cfg.
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_TIMEOUT=10
GRUB_CMDLINE_LINUX=""
#GRUB_TERMINAL=console
#GRUB_GFXMODE=640x480
#GRUB_DISABLE_LINUX_UUID=true
#GRUB_DISABLE_RECOVERY="true"
#GRUB_INIT_TUNE="480 440 1"
System:    Host: friday13-MS-7817 Kernel: 4.12.0-041200-generic x86_64 (64 bit gcc: 6.3.0)
           Desktop: Unity 7.4.0 (Gtk 3.18.9-1ubuntu3.3)
           Distro: Ubuntu 16.04 xenial
Machine:   Mobo: MSI model: H81M-P33 (MS-7817) v: 1.0
           Bios: American Megatrends v: V1.9 date: 03/30/2015
CPU:       Quad core Intel Core i5-4460 (-MCP-) cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 25599
           clock speeds: max: 3400 MHz 1: 800 MHz 2: 1098 MHz 3: 800 MHz
           4: 990 MHz
Graphics:  Card: NVIDIA GM206 [GeForce GTX 950] bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 drivers: nvidia (unloaded: fbdev,vesa,nouveau)
           Resolution: 1280x1024@60.02hz
           GLX Renderer: GeForce GTX 950/PCIe/SSE2
           GLX Version: 4.5.0 NVIDIA 375.66 Direct Rendering: Yes
           Card-2 NVIDIA Device 0fba driver: snd_hda_intel bus-ID: 01:00.1
           Sound: Advanced Linux Sound Architecture v: k4.12.0-041200-generic
           driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 03:00.0
           IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 1466.3GB (6.3% used)
           ID-1: /dev/sda model: WDC_WD10EZEX size: 1000.2GB temp: 41C
           ID-2: /dev/sdb model: SAMSUNG_HD250HJ size: 250.1GB temp: 38C
           ID-3: /dev/sdc model: SAMSUNG_HD200HJ size: 200.0GB temp: 37C
           ID-4: /dev/sdd model: Name n/a size: 15.9GB temp: 0C
Partition: ID-1: / size: 909G used: 7.5G (1%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 8.53GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 54.0C mobo: 27.8C gpu: 0.0:44C
Info:      Processes: 245 Uptime: 7:36 Memory: 1892.0/7922.7MB
Ynt: ubuntu 16.04 yavaş açılma ve programların geç açılması
« Yanıtla #1 : 09 Temmuz 2017, 16:53:17 »
apt-daily.service  ile ilgili buradaki öneri denenebilir.
3G/4G usb modem kullanmıyorsanız ModemManager.service pasifleştirilebilir.
Ayrıca Nvidia Ayar Yöneticisinden "sync to vblank" seçeneğini etkinleştirmeyi deneyebilirsiniz.
Çevrimdışı dolor
  • İleti: 75
  • mermer kafa
« Yanıtla #2 : 09 Temmuz 2017, 21:39:43 »
normal ttnet modemi kullanıyorum. Nasıl pasifleştireceğim
nvdiada sync to vblank tikli
diğer öneriyi yaptım bakalım  :'(
« Yanıtla #3 : 09 Temmuz 2017, 21:58:38 »
ModemManager servisini aşağıdaki komutla pasifleştirebilirsiniz.
sudo systemctl disable ModemManager.service
Aşağıdaki komutla Nvidia sürücüsü için otomatik olarak xorg.conf dosyası oluşturmayı dener misiniz?
sudo nvidia-xconfig
Ardından sistemi yeniden başlatın.
