Gönderen Konu: SD kart girişi tanımıyor  (Okunma sayısı 2711 defa)
Çevrimdışı üçüncü
  • İleti: 24
« : 18 Temmuz 2017, 13:00:40 »
Merhabalar
Bilgisayarımın sd kart girişini nasıl tanıtabilirim.
0:00.0 Host bridge: Intel Corporation Atom Processor Z36xxx/Z37xxx Series SoC Transaction Register (rev 0e)
   Subsystem: Acer Incorporated [ALI] Device 0933
   Flags: bus master, fast devsel, latency 0
   Kernel driver in use: iosf_mbi_pci
00:02.0 VGA compatible controller: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Graphics & Display (rev 0e) (prog-if 00 [VGA controller])
   Flags: bus master, fast devsel, latency 0, IRQ 262
   Memory at 90000000 (32-bit, non-prefetchable) [size=4M]
   Memory at 80000000 (32-bit, prefetchable) [size=256M]
   I/O ports at 2050 [size=8]
   Expansion ROM at <unassigned> [disabled]
   Capabilities: <access denied>
   Kernel driver in use: i915
00:14.0 USB controller: Intel Corporation Atom Processor Z36xxx/Z37xxx Series USB xHCI (rev 0e) (prog-if 30 [XHCI])
   Flags: bus master, medium devsel, latency 0, IRQ 261
   Memory at 90900000 (64-bit, non-prefetchable) [size=64K]
   Kernel driver in use: xhci_hcd
00:1a.0 Encryption controller: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Trusted Execution Engine (rev 0e)
   Flags: bus master, fast devsel, latency 0, IRQ 264
   Memory at 90800000 (32-bit, non-prefetchable) [size=1M]
   Memory at 90700000 (32-bit, non-prefetchable) [size=1M]
   Kernel driver in use: mei_txe
00:1b.0 Audio device: Intel Corporation Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller (rev 0e)
   Flags: bus master, fast devsel, latency 0, IRQ 265
   Memory at 90910000 (64-bit, non-prefetchable) [size=16K]
   Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation Atom Processor E3800 Series PCI Express Root Port 1 (rev 0e) (prog-if 00 [Normal decode])
   Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
   I/O behind bridge: 00003000-00003fff
   Kernel driver in use: pcieport
00:1c.1 PCI bridge: Intel Corporation Atom Processor E3800 Series PCI Express Root Port 2 (rev 0e) (prog-if 00 [Normal decode])
   Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
   I/O behind bridge: 00004000-00004fff
   Memory behind bridge: 90600000-906fffff
00:1c.2 PCI bridge: Intel Corporation Atom Processor E3800 Series PCI Express Root Port 3 (rev 0e) (prog-if 00 [Normal decode])
   Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
   I/O behind bridge: 00001000-00001fff
   Memory behind bridge: 90500000-905fffff
   Prefetchable memory behind bridge: 0000000090400000-00000000904fffff
00:1f.0 ISA bridge: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Power Control Unit (rev 0e)
   Kernel driver in use: lpc_ich
00:1f.3 SMBus: Intel Corporation Atom Processor E3800 Series SMBus Controller (rev 0e)
   Flags: medium devsel, IRQ 255
   Memory at 90918000 (32-bit, non-prefetchable) [size=32]
   I/O ports at 2000 [size=32]
02:00.0 Network controller: Broadcom Corporation BCM43142 802.11b/g/n (rev 01)
   Subsystem: Foxconn International, Inc. Device e07e
   Flags: bus master, fast devsel, latency 0, IRQ 17
   Memory at 90600000 (64-bit, non-prefetchable) [size=32K]
   Kernel driver in use: wl
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
   Flags: bus master, fast devsel, latency 0, IRQ 263
   I/O ports at 1000 [size=256]
   Memory at 90500000 (64-bit, non-prefetchable) [size=4K]
   Memory at 90400000 (64-bit, prefetchable) [size=16K]
   Kernel driver in use: r8169
System:    Host: ozgur81-NC-ES1-111M-C064 Kernel: 3.19.0-32-generic x86_64 (64 bit gcc: 4.8.2)
           Distro: Linux Mint 17.3 Rosa
Machine:   System: Acer product: NC-ES1-111M-C064 v: V1.16
           Mobo: Acer model: R2 v: Type2 - A01 Board Version
           Bios: Insyde v: V1.16 date: 10/20/2015
CPU:       Dual core Intel Celeron N2840 (-MCP-) cache: 1024 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 8652
           clock speeds: max: 2582 MHz 1: 499 MHz 2: 499 MHz
Graphics:  Card: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
           Resolution: 1366x768@60.1hz
           GLX Renderer: Mesa DRI Intel Bay Trail
Audio:     Card Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller
Network:   Card-1: Broadcom BCM43142 802.11b/g/n driver: wl bus-ID: 02:00.0
           IF: wlan0 state: up mac: 3c:77:e6:f4:b4:2b
           driver: r8169 v: 2.3LK-NAPI port: 1000 bus-ID: 03:00.0
           IF: eth1 state: down mac: 00:e0:b8:6d:d5:76
Partition: ID-1: / size: 25G used: 6.0G (26%) fs: ext4 dev: /dev/mmcblk0p2
           ID-2: swap-1 size: 4.17GB used: 0.00GB (0%) fs: swap dev: /dev/mmcblk0p3
Sensors:   System Temperatures: cpu: 45.0C mobo: N/A
Info:      Processes: 153 Uptime: 8 min Memory: 580.8/3834.5MB
ozgur81-nc-es1-111m-c064
    description: Notebook
    product: NC-ES1-111M-C064 (NC-ES1-111M-C064_0843_1_16)
    vendor: Acer
    version: V1.16
    serial: NXMRSEY00143519F1F7600
    width: 64 bits
    capabilities: smbios-2.7 dmi-2.7 vsyscall32
    configuration: chassis=notebook family=BTM sku=NC-ES1-111M-C064_0843_1_16 uuid=FFFFFFFF-FFFF-FFFF-0000-000000000000
  *-core
       description: Motherboard
       product: R2
       vendor: Acer
       physical id: 0
       version: Type2 - A01 Board Version
       serial: ����������������������
       slot: Type2 - Board Chassis Location
     *-firmware
          description: BIOS
          vendor: Insyde Corp.
          physical id: 0
          version: V1.16
          date: 10/20/2015
          capacity: 4032KiB
          capabilities: pc_ upgrade shadowing cdboot bootselect edd int9keyboard int14serial int17printer int10video acp_ usb z_pboot biosbootspecification netboot
     *-cpu
          description: CPU
          product: Intel(R) Celeron(R) CPU  N2840  @ 2.16GHz
          vendor: Intel Corp.
          physical id: 4
          bus info: cpu@0
          version: Intel(R) Celeron(R) CPU  N2840  @ 2.16GHz
          slot: CPU 1
          capacity: 2582MHz
          width: 64 bits
          clock: 83MHz
          capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 movbe popcnt tsc_deadline_timer rdrand lahf_lm 3dnowprefetch ida arat epb dtherm tpr_shadow vnmi flexpriority ept vpid tsc_adjust smep erms cpufreq
          configuration: cores=2 enabledcores=2 threads=1
        *-cache:0
             description: L1 cache
             physical id: 7
             slot: Unknown
             capacity: 32KiB
             capabilities: synchronous internal write-back instruction
        *-cache:1
             description: L2 cache
             physical id: 8
             slot: Unknown
             capacity: 1MiB
             capabilities: synchronous internal write-back unified
     *-cache
          physical id: 6
          slot: Unknown
          capacity: 24KiB
          capabilities: synchronous internal write-back data
     *-memory
          description: System Memory
          physical id: e
          slot: System board or motherboard
        *-bank
             description: SODIMM DDR3 Synchronous 1333 MHz (0,8 ns)
             product: HP16D3LS1KFG/4G
             vendor: Kingston
             physical id: 0
             serial: 15595612
             slot: DIMM0
             width: 64 bits
             clock: 1333MHz (0.8ns)
     *-pci
          description: Host bridge
          product: Atom Processor Z36xxx/Z37xxx Series SoC Transaction Register
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 0e
          width: 32 bits
          clock: 33MHz
          configuration: driver=iosf_mbi_pci
          resources: irq:0
        *-display
             description: VGA compatible controller
             product: Atom Processor Z36xxx/Z37xxx Series Graphics & Display
             physical id: 2
             bus info: pci@0000:00:02.0
             version: 0e
             width: 32 bits
             clock: 33MHz
             capabilities: pm msi vga_controller bus_master cap_list rom
             configuration: driver=i915 latency=0
             resources: irq:262 memory:90000000-903fffff memory:80000000-8fffffff ioport:2050(size=8)
        *-usb
             description: USB controller
             product: Atom Processor Z36xxx/Z37xxx Series USB xHCI
             physical id: 14
             bus info: pci@0000:00:14.0
             version: 0e
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi xhc_ bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             resources: irq:261 memory:90900000-9090ffff
        *-generic
             description: Encryption controller
             product: Atom Processor Z36xxx/Z37xxx Series Trusted Execution Engine
             physical id: 1a
             bus info: pci@0000:00:1a.0
             version: 0e
             width: 32 bits
             clock: 33MHz
             capabilities: pm msi bus_master cap_list
             configuration: driver=mei_txe latency=0
             resources: irq:264 memory:90800000-908fffff memory:90700000-907fffff
        *-multimedia
             description: Audio device
             product: Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller
             physical id: 1b
             bus info: pci@0000:00:1b.0
             version: 0e
             width: 64 bits
             clock: 33MHz
             configuration: driver=snd_hda_intel latency=0
             resources: irq:265 memory:90910000-90913fff
        *-pci:0
             description: PCI bridge
             product: Atom Processor E3800 Series PCI Express Root Port 1
             physical id: 1c
             bus info: pci@0000:00:1c.0
             version: 0e
             width: 32 bits
             clock: 33MHz
             capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:16 ioport:3000(size=4096)
        *-pci:1
             product: Atom Processor E3800 Series PCI Express Root Port 2
             physical id: 1c.1
             bus info: pci@0000:00:1c.1
             version: 0e
             width: 32 bits
             clock: 33MHz
             resources: irq:17 ioport:4000(size=4096) memory:90600000-906fffff
           *-network
                product: BCM43142 802.11b/g/n
                vendor: Broadcom Corporation
                physical id: 0
                bus info: pci@0000:02:00.0
                logical name: wlan0
                version: 01
                serial: 3c:77:e6:f4:b4:2b
                width: 64 bits
                clock: 33MHz
                configuration: broadcast=yes driver=wl0 driverversion=6.30.223.248 (r487574) ip=192.168.1.6 latency=0 multicast=yes wireless=IEEE 802.11abg
                resources: irq:17 memory:90600000-90607fff
        *-pci:2
             product: Atom Processor E3800 Series PCI Express Root Port 3
             physical id: 1c.2
             bus info: pci@0000:00:1c.2
             version: 0e
             width: 32 bits
             clock: 33MHz
             resources: irq:18 ioport:1000(size=4096) memory:90500000-905fffff ioport:90400000(size=1048576)
           *-network
                physical id: 0
                bus info: pci@0000:03:00.0
                logical name: eth1
                version: 0c
                serial: 00:e0:b8:6d:d5:76
                capacity: 1Gbit/s
                width: 64 bits
                clock: 33MHz
                configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168g-2_0.0.1 02/06/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
                resources: irq:263 ioport:1000(size=256) memory:90500000-90500fff memory:90400000-90403fff
        *-isa
             description: ISA bridge
             product: Atom Processor Z36xxx/Z37xxx Series Power Control Unit
             physical id: 1f
             bus info: pci@0000:00:1f.0
             version: 0e
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master cap_list
             configuration: driver=lpc_ich latency=0
             resources: irq:0
        *-serial UNCLAIMED
             description: SMBus
             product: Atom Processor E3800 Series SMBus Controller
             physical id: 1f.3
             bus info: pci@0000:00:1f.3
             version: 0e
             width: 32 bits
             clock: 33MHz
             capabilities: pm cap_list
             configuration: latency=0
             resources: memory:90918000-9091801f ioport:2000(size=32)
İlgilendiğiniz ve zaman ayırdığınız için teşekkürler
Ynt: SD kart girişi tanımıyor
« Yanıtla #1 : 18 Temmuz 2017, 14:41:13 »
Mesajınızı aşağıdaki biçime uygun olacak şekilde tekrar düzenleyebilir misiniz ?
