Gönderen Konu: bundle install yükleme sorunu  (Okunma sayısı 3678 defa)
Çevrimdışı 1m4m
  • İleti: 1
  • Dağıtım: kali
  • Masaüstü Ortamı: evet
  • Grafik Kartı: intel ve nvdıa 630
  • İşlemci: inrel core i5
« : 13 Ağustos 2017, 11:40:18 »
arkadaşlar bundle install dediğimde
root[member=5064]1m4m[/member]:~# bundle install
Don't run Bundler as root. Bundler can ask for sudo if it is needed, and installing your bundle as root will
break this application for all non-root users on this machine.
The latest bundler is 1.15.3, but you are currently running 1.15.1.
To update, run `gem install bundler`
Could not locate Gemfile
root[member=5064]1m4m[/member]:~# cd /usr/share/beef-xss
root[member=5064]1m4m[/member]:/usr/share/beef-xss# bundle install
Fetching gem metadata from https://rubygems.org/.........
Fetching version metadata from https://rubygems.org/..
Fetching dependency metadata from https://rubygems.org/.
Resolving dependencies...
Using eventmachine 1.0.7
Using daemons 1.1.9
Using rack 1.5.2
Using tilt 1.4.1
Using addressable 2.3.6
Using execjs 2.0.2
Using multi_json 1.9.3
Using mime-types 2.99
Using libv8 3.16.14.19 (x86_64-linux)
Using ref 2.0.0
Using ansi 1.4.3
Using term-ansicolor 1.1.5
Fetching json 1.8.1
Installing json 1.8.1 with native extensions
Using parseconfig 1.0.4
Using erubis 2.7.0
Using librex 0.0.68
Using msgpack 0.5.8
Using rubyzip 1.1.3
Using rainbow 2.0.0
Using geoip 1.4.0
Using fastercsv 1.5.5
Using json_pure 1.8.3
Using mojo_magick 0.5.6
Using chunky_png 1.3.5
Using bundler 1.15.1
Fetching thin 1.6.2
Installing thin 1.6.2 with native extensions
Fetching rack-protection 1.5.3
Installing rack-protection 1.5.3
Fetching em-websocket 0.3.8
Installing em-websocket 0.3.8
Using dm-core 1.2.1
Using data_objects 0.10.14
Fetching uglifier 2.2.1
Installing uglifier 2.2.1
Fetching therubyracer 0.12.3
Installing therubyracer 0.12.3 with native extensions
Gem::Ext::BuildError: ERROR: Failed to build gem native extension.
    current directory: /usr/share/beef-xss/debian/gems/ruby/2.3.0/gems/json-1.8.1/ext/json/ext/generator
/usr/bin/ruby2.3 -r ./siteconf20170813-1847-1i3z9fx.rb extconf.rb
creating Makefile
make "DESTDIR=" clean
make "DESTDIR="
compiling generator.c
In file included from generator.c:1:0:
../fbuffer/fbuffer.h: In function ‘fbuffer_to_s’:
../fbuffer/fbuffer.h:175:47: error: macro "rb_str_new" requires 2 arguments, but only 1 given
     VALUE result = rb_str_new(FBUFFER_PAIR(fb));
../fbuffer/fbuffer.h:175:20: warning: initialization makes integer from pointer without a cast
[-Wint-conversion]
Makefile:239: recipe for target 'generator.o' failed
make: *** [generator.o] Error 1
make failed, exit code 2
Gem files will remain installed in /usr/share/beef-xss/debian/gems/ruby/2.3.0/gems/json-1.8.1 for inspection.
Results logged to
/usr/share/beef-xss/debian/gems/ruby/2.3.0/extensions/x86_64-linux/2.3.0/json-1.8.1/gem_make.out
An error occurred while installing json (1.8.1), and Bundler cannot continue.
Make sure that `gem install json -v '1.8.1'` succeeds before bundling.
In Gemfile:
  dm-serializer was resolved to 1.2.2, which depends on
    json
böyle bi hata alıyorum yardımcı olursanız sevinirim
Ynt: bundle install yükleme sorunu
« Yanıtla #1 : 13 Ağustos 2017, 12:48:21 »
12- Forumda penetrasyon (sızma) testi ile ilgili dağıtım ve yazılımlara destek verilmemektedir. Böyle içereğe sahip konu ve mesajlar tespit edilmesi veya bildirilmesi durumunda bildirimde bulunulmaksızın kaldırılacaktır.
