Gönderen Konu: Wireshark kaynak dosyadan kurulum problemi(./configure)  (Okunma sayısı 3152 defa)
Çevrimdışı HuseyinS
  • İleti: 1
  • <title> Acemi </title>
    • huseyinnsoylu
  • Dağıtım: Linux Mint Sonya 18.2
  • Masaüstü Ortamı: XFCE
  • Grafik Kartı: Gallium 0.4 on NV86
  • İşlemci: Intel Pentium 4 CPU 3.00 GHz @ 3 GHz
Selam arkadaşlar kaynak koddan wireshark kurmaya çalışıyordum.
soylu wireshark-2.4.2 # ./configure
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... x86_64-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether UID '0' is supported by ustar format... yes
checking whether GID '0' is supported by ustar format... yes
checking how to create a ustar tar archive... gnutar
checking whether make supports nested variables... (cached) yes
checking how to print strings... printf
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for a working dd... /bin/dd
checking how to truncate binary pipes... /bin/dd bs=4096 count=1
checking for mt... mt
checking if mt is a manifest tool... no
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... yes
checking whether a statically linked program can dlopen itself... no
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking for gcc option to accept ISO C99... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking whether g++ is a C++ compiler... yes
checking whether g++ supports C++11 features by default... no
checking whether g++ supports C++11 features with -std=c++11... yes
checking whether we are using the GNU C compiler... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether gcc understands -c and -o together... (cached) yes
checking dependency style of gcc... (cached) gcc3
checking for a sed that does not truncate output... (cached) /bin/sed
checking for perl... /usr/bin/perl
checking for python... /usr/bin/python
checking whether /usr/bin/python is Python 2.5 or later... yes
checking for bison... bison -y
checking for flex... flex
checking lex output file root... lex.yy
checking lex library... -lfl
checking whether yytext is a pointer... yes
checking for pod2man... /usr/bin/pod2man
checking for pod2html... /usr/bin/pod2html
checking for doxygen... no
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.7... yes
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking for library containing cos... -lm
checking for floorl... yes
checking for lrint... yes
checking for library containing gethostbyname... none required
checking for library containing socket... none required
checking for LIBGNUTLS... no
GnuTLS >= 3.1.10 not found
GnuTLS >= 2.12.0, < 3.0 not found
GnuTLS with compatible license not found, disabling SSL decryption
checking for libgcrypt-config... /usr/bin/libgcrypt-config
checking for LIBGCRYPT - version >= 1.4.2... yes
checking whether to use libnl for various network interface purposes... yes
checking if nl80211.h is new enough... yes
checking for NL80211_SET_CHANNEL... yes
checking for NL80211_SPLIT_WIPHY_DUMP... yes
checking for NL80211_VHT_CAPABILITY... yes
checking for libsmi >= 2... not found
checking for xsltproc... no
checking for a2x... no
checking for fop... no
checking for an HTML to text processor... no
checking for desktop-file-install... /usr/bin/desktop-file-install
checking for pkgproto... no
checking for pkgmk... no
checking for pkgtrans... no
checking for rpmbuild... no
checking for dpkg-buildpackage... yes
checking for xcodebuild... no
checking for hdiutil... no
checking for bless... no
checking for sw_vers... no
checking for shellcheck... no
checking for C compiler vendor... gnu
checking for C++ compiler vendor... gnu
checking whether the compiler fails when given an unknown warning option... yes
checking whether the compiler fails when given an warning option not supported for C++... no, adding -Werror
checking whether we can add -Wall to CFLAGS... yes
checking whether we can add -Wall to CXXFLAGS... yes
checking whether we can add -Wextra to CFLAGS... yes
checking whether we can add -Wextra to CXXFLAGS... yes
checking whether we can add -Wendif-labels to CFLAGS... yes
checking whether we can add -Wendif-labels to CXXFLAGS... yes
checking whether we can add -Wpointer-arith to CFLAGS... yes
checking whether we can add -Wpointer-arith to CXXFLAGS... yes
checking whether we can add -Wformat-security to CFLAGS... yes
checking whether we can add -Wformat-security to CXXFLAGS... yes
checking whether we can add -fwrapv to CFLAGS... yes
checking whether we can add -fwrapv to CXXFLAGS... yes
checking whether we can add -fno-strict-overflow to CFLAGS... yes
checking whether we can add -fno-strict-overflow to CXXFLAGS... yes
checking whether we can add -fno-delete-null-pointer-checks to CFLAGS... yes
checking whether we can add -fno-delete-null-pointer-checks to CXXFLAGS... yes
checking whether we can add -Wvla to CFLAGS... yes
checking whether we can add -Wvla to CXXFLAGS... yes
checking whether we can add -Waddress to CFLAGS... yes
checking whether we can add -Waddress to CXXFLAGS... yes
checking whether we can add -Wattributes to CFLAGS... yes
checking whether we can add -Wattributes to CXXFLAGS... yes
checking whether we can add -Wdiv-by-zero to CFLAGS... yes
checking whether we can add -Wdiv-by-zero to CXXFLAGS... yes
checking whether we can add -Wignored-qualifiers to CFLAGS... yes
checking whether we can add -Wignored-qualifiers to CXXFLAGS... yes
checking whether we can add -Wpragmas to CFLAGS... yes
checking whether we can add -Wpragmas to CXXFLAGS... yes
checking whether we can add -Wno-overlength-strings to CFLAGS... yes
checking whether we can add -Wno-overlength-strings to CXXFLAGS... yes
checking whether we can add -Wno-long-long to CFLAGS... yes
checking whether we can add -Wno-long-long to CXXFLAGS... yes
checking whether we can add -Wheader-guard to CFLAGS... no
checking whether we can add -Wheader-guard to CXXFLAGS... no
checking whether we can add -Wc++-compat to CFLAGS... yes
checking whether we can add -Wunused-const-variable to CFLAGS... no
checking whether we can add -Wshadow to CFLAGS... yes
checking whether -Wshadow warns about variables in function declarations shadowing other variables... no
checking whether we can add -Wno-pointer-sign to CFLAGS... yes
checking whether we can add -Wold-style-definition to CFLAGS... yes
checking whether we can add -Wstrict-prototypes to CFLAGS... yes
checking whether we can add -Wlogical-op to CFLAGS... yes
checking whether -Wlogical-op generates warnings from strchr()... no
checking whether we can add -Wjump-misses-init to CFLAGS... yes
checking whether we can add -Wshorten-64-to-32 to CFLAGS... no
checking whether we can add -Werror=implicit to CFLAGS... yes
checking whether we can add -fexcess-precision=fast to CFLAGS... yes
checking whether we can add -fexcess-precision=fast to CXXFLAGS... yes
checking whether we can add -fvisibility=hidden to CFLAGS... yes
checking whether we can add -fvisibility=hidden to CXXFLAGS... yes
checking whether we can add -Wl,--as-needed to LDFLAGS... yes
checking whether we can add -fPIE to CFLAGS... yes
checking whether we can add -fPIE -pie to LDFLAGS... yes
checking whether we can add -msse4.2 to CFLAGS... yes
checking whether there is emmintrin.h header and we can use it... yes
checking whether there is nmmintrin.h header and we can use it... yes
checking whether -D_FORTIFY_SOURCE=2 can be used (without generating a warning)... yes
checking whether we should treat compiler warnings as errors... no
checking for platform-specific compiler flags... none needed
checking for platform-specific linker flags... none needed
checking if profile builds must be generated... no
checking for GLIB... yes
checking for Qt5Core - version >= 5.0.0... yes (version 5.5.1)
checking for Qt5Gui - version >= 5.0.0... yes (version 5.5.1)
checking for Qt5Widgets - version >= 5.0.0... yes (version 5.5.1)
checking for Qt5PrintSupport - version >= 5.0.0... yes (version 5.5.1)
checking for Qt5Multimedia - version >= 5.0.0... no
checking for Qt5MacExtras - version >= 5.0.0... no
checking whether Qt works without -fPIC... no
checking whether Qt works with -fPIC... yes
checking for qtchooser... /usr/bin/qtchooser
checking for uic... /usr/bin/uic
checking for qtchooser... (cached) /usr/bin/qtchooser
checking for moc... /usr/bin/moc
checking for rcc... /usr/bin/rcc
checking for lrelease... /usr/bin/lrelease
checking whether lrelease -version works... no
configure: error: /usr/bin/lrelease -qt=5 -version returned non-zero exit status
hata kısmı burası;
hangi paketi krumam gerek onu da anlamadım.
Bu arada hack için yüklemiyorum. Ağ trafiğimi izlemem gerek. Wps açık bırakmıştı galiba hacklendi de.
Ynt: Wireshark kaynak dosyadan kurulum problemi(./configure)
« Yanıtla #1 : 20 Ekim 2017, 22:45:17 »
Depoda 2.2.6 sürümü mevcut kolayca kurabilirsiniz.
Daha güncel sürümü kullanmak istiyorsanız, aşağıdaki komutlarla PPA deposundan 2.4.1-1 sürümü kurabilirsiniz. 2.4.2 sürüm bir süre sonra bu PPA deposuna eklendiğinde güncelleme ile yükseltebilirsiniz.
sudo add-apt-repository ppa:wireshark-dev/stable
sudo apt-get install wireshark
