Gönderen Konu: [Çözüldü] PIP3 INSTALL HATASI  (Okunma sayısı 3278 defa)
Çevrimdışı Salvoton
  • İleti: 70
« : 06 Aralık 2017, 20:00:00 »
pip3 install komutunu kullanırken bu hatayı alıyorum. İnternette epey bir aradım ama sorunumu çözmedim.
sudo pip3 install pyautoguiÇıktı:
The directory '/home/asdas/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/asdas/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Collecting pyautogui
  Downloading PyAutoGUI-0.9.36.tar.gz (46kB)
    100% |████████████████████████████████| 51kB 295kB/s
    Complete output from command python setup.py egg_info:
      File "<string>", line 1, in <module>
      File "/tmp/pip-build-qfe6htfj/pyautogui/setup.py", line 6, in <module>
        version=__import__('pyautogui').__version__,
      File "/tmp/pip-build-qfe6htfj/pyautogui/pyautogui/__init__.py", line 115, in <module>
        from . import _pyautogui_x11 as platformModule
      File "/tmp/pip-build-qfe6htfj/pyautogui/pyautogui/_pyautogui_x11.py", line 7, in <module>
        from Xlib.display import Display
    ImportError: No module named 'Xlib'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-qfe6htfj/pyautogui/
« Son Düzenleme: 07 Aralık 2017, 17:22:23 Gönderen: Salvoton »
Ynt: PIP3 INSTALL HATASI
« Yanıtla #1 : 06 Aralık 2017, 20:28:32 »
Aşağıdaki komutla xlib paketini yükledikten sonra tekrar dener misiniz?
sudo apt-get install python-xlib
Çevrimdışı Salvoton
  • İleti: 70
« Yanıtla #2 : 06 Aralık 2017, 20:57:17 »
sorun devam ediyor.
    100% |████████████████████████████████| 51kB 323kB/s
      File "/tmp/pip-build-b3sy8aal/pyautogui/setup.py", line 6, in <module>
      File "/tmp/pip-build-b3sy8aal/pyautogui/pyautogui/__init__.py", line 115, in <module>
      File "/tmp/pip-build-b3sy8aal/pyautogui/pyautogui/_pyautogui_x11.py", line 7, in <module>
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-b3sy8aal/pyautogui/
« Yanıtla #3 : 06 Aralık 2017, 23:36:46 »
Yukarıda paket adını eksik yazmışım. python3-xlib paketini yüklemek gerekiyor. Doğrusu şöyle olacak:
sudo apt-get install python3-xlib
Çevrimdışı Salvoton
  • İleti: 70
« Yanıtla #4 : 07 Aralık 2017, 17:21:53 »
Sorun çözüldü. Çok teşekkür ederim  :)
