Gönderen Konu: Bumblebee kurulumu sonrasında fan çok hızlı dönuyor  (Okunma sayısı 3375 defa)
Çevrimdışı Melqart
  • İleti: 9
  • Dağıtım: Mint 18.3 64-bit
  • Masaüstü Ortamı: Cinnamon 3.4.6
  • Grafik Kartı: GTX 950M - İntel HD530
  • İşlemci: İntel Core İ7 6700HQ
Bumblebee kurdum ve  kurulum esnasında fan hızlandı. Leptop ta bir isınma olmamasına ragmen fan yuksek hızda çalısıyor hep.
inxi -SMGxx
System:    Host: noname Kernel: 4.10.0-42-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.6.7 (Gtk 3.18.9-1ubuntu3.3) dm: lightdm
Machine:   System: ASUSTeK (portable) product: X550VX v: 1.0
           Mobo: ASUSTeK model: X550VX v: 1.0
           Bios: American Megatrends v: X550VX.302 date: 05/04/2017
Graphics:  Card-1: Intel Skylake Integrated Graphics
           bus-ID: 00:02.0 chip-ID: 8086:191b
           Card-2: NVIDIA GM107M [GeForce GTX 950M]
           bus-ID: 01:00.0 chip-ID: 10de:139a
           Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa) FAILED: nouveau
           Resolution: 1920x1080@60.00hz
           GLX Renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2)
           GLX Version: 3.0 Mesa 17.2.4 Direct Rendering: Yes
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 530 (Skylake GT2)
00:02.0 VGA compatible controller: Intel Corporation Skylake Integrated Graphics (rev 06)
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 950M] (rev a2)
eDP1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1920x1080     60.00*+  59.93
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1600x900      60.00
   1280x1024     60.02
   1440x900      59.89
   1280x960      60.00
   1368x768      60.00
   1360x768      59.80    59.96
   1152x864      60.00
   1280x720      60.00
   1024x768      60.00
   1024x576      60.00
   960x540       60.00
   800x600       60.32    56.25
   864x486       60.00
   640x480       59.94
   720x405       60.00
   640x360       60.00
ii  bumblebee                                   3.2.1-100~xenialppa1                         amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                            3.2.1-100~xenialppa1                         amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-384                                  384.90-0ubuntu0.16.04.2                      amd64        NVIDIA binary driver - version 384.90
ii  nvidia-prime-applet                         1.0.6                                        all          An applet for NVIDIA Prime
ii  nvidia-settings                             361.42-0ubuntu1                              amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                      20150328-3~xenialppa2                        amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                           20150328-3~xenialppa2                        amd64        Shared libraries for primus
ii  primus-libs:i386                            20150328-3~xenialppa2                        i386         Shared libraries for primus
ii  primus-libs-ia32:i386                       20150328-3~xenialppa2                        i386         Shared libraries for primus (32-bit)
ii  virtualgl                                   2.4.1-1~xenialppa1                           amd64        Toolkit for displaying OpenGL applications to thin clients
ii  virtualgl-libs:amd64                        2.4.1-1~xenialppa1                           amd64        Library files for virtualgl
Ynt: Bumblebee kurulumu sonrasında fan çok hızlı dönuyor
« Yanıtla #1 : 03 Ocak 2018, 17:28:57 »
[warning]Sorunlar Hakkında[/warning]
Çevrimdışı Melqart
  • İleti: 9
« Yanıtla #2 : 03 Ocak 2018, 17:42:08 »
optirun -vvv glxgears
[ 3245.852523] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 3245.852946] [INFO]Configured driver: nvidia
[ 3245.853281] [DEBUG]optirun version 3.2.1 starting...
[ 3245.853306] [DEBUG]Active configuration:
[ 3245.853313] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 3245.853319] [DEBUG] X display: :8
[ 3245.853325] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-384:/usr/lib32/nvidia-384
[ 3245.853331] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 3245.853338] [DEBUG] Accel/display bridge: auto
[ 3245.853349] [DEBUG] VGL Compression: proxy
[ 3245.853354] [DEBUG] VGLrun extra options:
[ 3245.853365] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 3245.853456] [DEBUG]Using auto-detected bridge virtualgl
[ 3245.926489] [INFO]Response: No - error: Could not load GPU driver
[ 3245.926521] [ERROR]Cannot access secondary GPU - error: Could not load GPU driver
[ 3245.926529] [DEBUG]Socket closed.
[ 3245.926566] [ERROR]Aborting because fallback start is disabled.
[ 3245.926577] [DEBUG]Killing all remaining processes.
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=nvidia
# Xorg binary to run
XorgBinary=/usr/lib/xorg/Xorg
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
[driver-nvidia]
KernelDriver=nvidia-384
PMMethod=auto
LibraryPath=/usr/lib/nvidia-384:/usr/lib32/nvidia-384
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia-384/xorg,/usr/lib/xorg/modules
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
Section "ServerLayout"
    Identifier  "Layout0"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
    BusID "PCI:01:00:0"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
cat /etc/modprobe.d/bumblebee.conf
# This file is installed by bumblebee, do NOT edit!
# to be used by kmod / module-init-tools, and installed in /etc/modprobe.d/
# or equivalent
# do not automatically load nouveau as it may prevent nvidia from loading
blacklist nouveau
# do not automatically load nvidia as it's unloaded anyway when bumblebeed
# starts and may fail bumblebeed to disable the card in a race condition.
# Debian
blacklist nvidia
blacklist nvidia-current
blacklist nvidia-legacy-304xx
blacklist nvidia-legacy-340xx
# Ubuntu
blacklist nvidia
blacklist nvidia-current-updates
# 304
blacklist nvidia-304
blacklist nvidia-304-updates
blacklist nvidia-experimental-304
# 310
blacklist nvidia-310
blacklist nvidia-310-updates
blacklist nvidia-experimental-310
# 313
blacklist nvidia-313
blacklist nvidia-313-updates
blacklist nvidia-experimental-313
# 319
blacklist nvidia-319
blacklist nvidia-319-updates
blacklist nvidia-experimental-319
# 325
blacklist nvidia-325
blacklist nvidia-325-updates
blacklist nvidia-experimental-325
# 331
blacklist nvidia-331
blacklist nvidia-331-updates
blacklist nvidia-experimental-331
# 334
blacklist nvidia-334
blacklist nvidia-334-updates
blacklist nvidia-experimental-334
# 337
blacklist nvidia-337
blacklist nvidia-337-updates
blacklist nvidia-experimental-337
# 340
blacklist nvidia-340
blacklist nvidia-340-updates
blacklist nvidia-experimental-340
# 343
blacklist nvidia-343
blacklist nvidia-343-updates
blacklist nvidia-experimental-343
# 346
blacklist nvidia-346
blacklist nvidia-346-updates
blacklist nvidia-experimental-346
# 349
blacklist nvidia-349
blacklist nvidia-349-updates
blacklist nvidia-experimental-349
# 352
blacklist nvidia-352
blacklist nvidia-352-updates
blacklist nvidia-experimental-352
# 355
blacklist nvidia-355
blacklist nvidia-355-updates
blacklist nvidia-experimental-355
# 358
blacklist nvidia-358
blacklist nvidia-358-updates
blacklist nvidia-experimental-358
# 361
blacklist nvidia-361
blacklist nvidia-361-updates
blacklist nvidia-experimental-361
# 364
blacklist nvidia-364
blacklist nvidia-364-updates
blacklist nvidia-experimental-364
# 367
blacklist nvidia-367
blacklist nvidia-367-updates
blacklist nvidia-experimental-367
# 375
blacklist nvidia-375
blacklist nvidia-375-updates
blacklist nvidia-experimental-375
# 378
blacklist nvidia-378
blacklist nvidia-378-updates
blacklist nvidia-experimental-378
# 381
blacklist nvidia-381
blacklist nvidia-381-updates
blacklist nvidia-experimental-381
# 384
blacklist nvidia-384
blacklist nvidia-384-updates
blacklist nvidia-experimental-384
# 384
cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-4.10.0-42-generic root=UUID=eed11060-87c4-4d8c-b44c-d84bafe34216 ro nogpumanager acpi_enforce_resources=lax quiet splash acpi_osi=Linux vt.handoff=7
« Yanıtla #3 : 03 Ocak 2018, 17:59:03 »
Fan sorununun Bumblebee kurulumu sonrasında ortaya çıktığına emin misiniz? Algılayıcılar ile ilgili bir işlem sonrasında bu durum yaşanmış olmasın?
Aşağıdaki komutla algılayıcıları yeniden taratmayı deneyip, ardından sistemi yeniden başlatınız.
sudo sensors-detect
Şunun için aşağıdaki komutların çıktılarına bakalım.
modinfo nvidia
modinfo nvidia-384
modprobe --resolve-alias nvidia
Çevrimdışı Melqart
  • İleti: 9
« Yanıtla #4 : 03 Ocak 2018, 18:14:14 »
Yeniden başlattım duzelmedi. Sonra tamamen kapatıp açtım masaustu gelene kadar normaldı gelınce hızlandı.
modinfo nvidia
modinfo: ERROR: Module nvidia not found.
modinfo nvidia-384
filename:       /lib/modules/4.10.0-42-generic/kernel/drivers/char/drm/nvidia_384.ko
alias:          char-major-195-*
version:        384.90
supported:      external
license:        NVIDIA
srcversion:     9D546A76FA9D9523F03995D
alias:          pci:v000010DEd00000E00sv*sd*bc04sc80i00*
alias:          pci:v000010DEd*sv*sd*bc03sc02i00*
alias:          pci:v000010DEd*sv*sd*bc03sc00i00*
depends:
vermagic:       4.10.0-42-generic SMP mod_unload
parm:           NVreg_Mobile:int
parm:           NVreg_ResmanDebugLevel:int
parm:           NVreg_RmLogonRC:int
parm:           NVreg_ModifyDeviceFiles:int
parm:           NVreg_DeviceFileUID:int
parm:           NVreg_DeviceFileGID:int
parm:           NVreg_DeviceFileMode:int
parm:           NVreg_UpdateMemoryTypes:int
parm:           NVreg_InitializeSystemMemoryAllocations:int
parm:           NVreg_UsePageAttributeTable:int
parm:           NVreg_MapRegistersEarly:int
parm:           NVreg_RegisterForACPIEvents:int
parm:           NVreg_CheckPCIConfigSpace:int
parm:           NVreg_EnablePCIeGen3:int
parm:           NVreg_EnableMSI:int
parm:           NVreg_TCEBypassMode:int
parm:           NVreg_UseThreadedInterrupts:int
parm:           NVreg_EnableStreamMemOPs:int
parm:           NVreg_MemoryPoolSize:int
parm:           NVreg_RegistryDwords:charp
parm:           NVreg_RegistryDwordsPerDevice:charp
parm:           NVreg_RmMsg:charp
parm:           NVreg_AssignGpus:charp
modprobe: FATAL: Module nvidia not found in directory /lib/modules/4.10.0-42-generic
« Yanıtla #5 : 03 Ocak 2018, 20:57:39 »
Aşağıdaki komutlarla Bumblebee ve lm-sensor ile ilgili paketleri kaldırıp sistemi yeniden başlatmayı deneyiniz.
sudo apt-get purge bumblebee* nvidia* bbswitch* primus* virtualgl* lm-sensor
Sistemi yeniden başlatıp fan durumunu kontrol ediniz.
Sistemi yeniden başlattıktan sonra forumdaki konuda anlatıldığı biçimde Bumblebee'yi yeniden kurmayı deneyebilrisiniz.
[info][Nasıl] Linux Mint 18 - Intel + Nvidia Hibrit GPU İçin Bumblebee Kurulumu[/info]
