Gönderen Konu: intel 300 hd grafik karti sorunu  (Okunma sayısı 4455 defa)
Çevrimdışı gokmen
  • İleti: 2
  • Dağıtım: linux mint 18.3
  • Grafik Kartı: intel hd 300
  • İşlemci: intel i5
« : 20 Mart 2018, 12:55:52 »
herkese merhabalar araniza yeni  katildim ama linuxmint ile eski bir dostlugumuz var...
dell marka laptop da ki intel grafik kartini tanidi sistem ama sayfalarda kesilme oluyor bir turlu bu sorunu cozemedim yardim edebilirmisiniz.
System:    Host: digitalsat-Latitude-E6320 Kernel: 4.13.0-37-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.6.7 (Gtk 3.18.9-1ubuntu3.3) dm: lightdm Distro: Linux Mint 18.3 Sylvia
Machine:   System: Dell (portable) product: Latitude E6320 v: 01 Chassis: type: 9
           Mobo: Dell model: 0GJF11 v: A00 Bios: Dell v: A20 date: 05/12/2017
CPU:       Dual core Intel Core i5-2520M (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9978
           clock speeds: min/max: 800/3200 MHz 1: 2494 MHz 2: 2494 MHz 3: 2494 MHz 4: 2494 MHz
Graphics:  Card: Intel 2nd Generation Core Processor Family Integrated Graphics Controller
           bus-ID: 00:02.0 chip-ID: 8086:0126
           Resolution: 1366x768@60.02hz, 1680x1050@59.88hz
           GLX Version: 3.0 Mesa 17.2.8 Direct Rendering: Yes
           driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:1c20
           Sound: Advanced Linux Sound Architecture v: k4.13.0-37-generic
Network:   Card-1: Intel 82579LM Gigabit Network Connection
           driver: e1000e v: 3.2.6-k port: 4080 bus-ID: 00:19.0 chip-ID: 8086:1502
           IF: eno1 state: down mac: <filter>
           Card-2: Broadcom BCM4313 802.11bgn Wireless Network Adapter
           driver: bcma-pci-bridge bus-ID: 02:00.0 chip-ID: 14e4:4727
           IF: wlp2s0b1 state: up mac: <filter>
Drives:    HDD Total Size: 500.1GB (2.5% used)
           ID-1: /dev/sda model: TOSHIBA_MK5055GS size: 500.1GB serial: 306ASCAFS
Partition: ID-1: / size: 87G used: 6.1G (8%) fs: ext4 dev: /dev/sda5
           ID-2: swap-1 size: 6.32GB used: 0.00GB (0%) fs: swap dev: /dev/sda6
           Unused Devices: none
Sensors:   System Temperatures: cpu: 57.0C mobo: N/A
Repos:     Active apt sources in file: /etc/apt/sources.list.d/official-package-repositories.list
           deb http: //mirror6.layerjet.com/linuxmint/packages sylvia main upstream import backport
           deb http: //mirror.plusserver.com/ubuntu/ubuntu xenial main restricted universe multiverse
           deb http: //mirror.plusserver.com/ubuntu/ubuntu xenial-updates main restricted universe multiverse
           deb http: //mirror.plusserver.com/ubuntu/ubuntu xenial-backports main restricted universe multiverse
           deb http: //security.ubuntu.com/ubuntu/ xenial-security main restricted universe multiverse
           deb http: //archive.canonical.com/ubuntu/ xenial partner
Info:      Processes: 183 Uptime: 5 min Memory: 567.7/5840.1MB
           Client: Unknown python2.7 client inxi: 2.2.35
Ynt: intel 300 hd grafik karti sorunu
« Yanıtla #1 : 20 Mart 2018, 13:35:20 »
Çevrimdışı gokmen
  • İleti: 2
  • İşlemci: intel i5
« Yanıtla #2 : 20 Mart 2018, 15:23:17 »
tesekkurler dediklerinizi boyle bir hata veriyor
xed:5126): Gtk-WARNING **: Calling Inhibit failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.SessionManager was not provided by any .service files
** (xed:5126): WARNING **: Set document metadata failed: Öznitelik metadata::xed-spell-language ataması desteklenmiyor
** (xed:5126): WARNING **: Set document metadata failed: Öznitelik metadata::xed-encoding ataması desteklenmiyor
** (xed:5126): WARNING **: Set document metadata failed: Öznitelik metadata::xed-position ataması desteklenmiyor
« Yanıtla #3 : 20 Mart 2018, 16:46:49 »
Eğer sizden hata çıktılarını paylaşmanız istenmediyse, sadece öneriyi uygulayınız.
Ayrıca aşağıdaki komutla UXA hızlandırma metodunu etkinleştirmekte sorunu çözebilir. Sonrasında sistemi yeniden başlatmanız gerekiyor.
« Son Düzenleme: 20 Mart 2018, 16:50:20 Gönderen: Butterfly »
