Gönderen Konu: [Çözüldü] Manjaro - Lenovo Z500 Ekran Parlaklığı Sorunu  (Okunma sayısı 12253 defa)
Ynt: Manjaro - Lenovo Z500 Ekran Parlaklığı Sorunu
« Yanıtla #15 : 18 Nisan 2018, 16:50:23 »
O şekilde işe yarayacağını sanmıyorum.
Aşağıdaki komutların çıktısına sorunlu çekirdekler altında bakalım.
systemctl --failed
systemctl status systemd-backlight@backlight:acpi_video0.service
Çevrimdışı yukarihisar
  • İleti: 74
« Yanıtla #16 : 18 Nisan 2018, 18:51:41 »
$ systemctl --failed
$ systemctl status systemd-backlight@backlight:acpi_video0.service
● systemd-backlight@backlight:acpi_video0.service - Load/Save Screen Backlight >
   Loaded: loaded (/usr/lib/systemd/system/systemd-backlight@.service; static; >
   Active: inactive (dead)
     Docs: man:systemd-backlight@.service(8)
Şöyle bir çıktı oluştu.
Servisi başlattığımda şöyle hatalar aldım.
$ systemctl start systemd-backlight@backlight:acpi_video0.service
Job for systemd-backlight@backlight:acpi_video0.service failed because the control process exited with error code.
See "systemctl status systemd-backlight@backlight:acpi_video0.service" and "journalctl -xe" for details.
Ardından systemctl status systemd-backlight@backlight:acpi_video0.service çıktısı.
   Active: failed (Result: exit-code) since Wed 2018-04-18 18:52:40 +03; 7s ago
  Process: 1510 ExecStart=/usr/lib/systemd/systemd-backlight load backlight:acp>
 Main PID: 1510 (code=exited, status=1/FAILURE)
Nis 18 18:52:40 lenovo systemd[1]: Starting Load/Save Screen Backlight Brightne>
Nis 18 18:52:40 lenovo systemd-backlight[1510]: Failed to get backlight or LED >
Nis 18 18:52:40 lenovo systemd[1]: systemd-backlight@backlight:acpi_video0.serv>
Nis 18 18:52:40 lenovo systemd[1]: Failed to start Load/Save Screen Backlight B>
Ardından journalctl -xe çıktısı.
$ journalctl -xe
Nis 18 18:52:28 lenovo polkitd[410]: Operator of unix-session:c2 successfully a>
Nis 18 18:52:28 lenovo systemd[1]: Reloading.
Nis 18 18:52:28 lenovo polkitd[410]: Unregistered Authentication Agent for unix>
Nis 18 18:52:38 lenovo polkitd[410]: Registered Authentication Agent for unix-p>
Nis 18 18:52:40 lenovo polkitd[410]: Operator of unix-session:c2 successfully a>
-- Subject: Unit systemd-backlight@backlight:acpi_video0.service has begun star>
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit systemd-backlight@backlight:acpi_video0.service has begun starting up.
-- Subject: Unit systemd-backlight@backlight:acpi_video0.service has failed
-- Unit systemd-backlight@backlight:acpi_video0.service has failed.
-- The result is RESULT.
Nis 18 18:52:40 lenovo polkitd[410]: Unregistered Authentication Agent for unix>
« Son Düzenleme: 18 Nisan 2018, 18:55:54 Gönderen: yukarihisar »
« Yanıtla #17 : 19 Nisan 2018, 09:12:50 »
Sırasıyla aşağıdaki değişkenleri dener misin?
acpi_osi='!Windows 2012'
acpi_osi='!Windows 2015'
Deneysel depolardan systemd güncellemesi yapmak da denenebilir.
« Son Düzenleme: 19 Nisan 2018, 09:15:50 Gönderen: Butterfly »
  • İleti: 74
« Yanıtla #18 : 19 Nisan 2018, 12:13:59 »
GRUB_CMDLINE_LINUX_DEFAULT="quiet acpi_osi='!Windows 2012' resume=UUID=7b
Bu şekilde yaptığımda çalıştı çok teşekkürler. acpi_backlight=video bunu kullandığımdan çok daha stabil çalışıyor. Çok hızlı bir şekilde parlaklığı kısıp açabiliyorum. acpi_backlight=video bunu kullanırken çok yavaş oluyordu. Çok teşekkürler. Bir sorum daha olacak bu sorun acaba çekirdekle mi alakalıydı yoksa bilgisayarla mı alakalı. Herhangi bir linux dağıtımı kurduğumda yine acpi_osi='!Windows 2012' bunu yaptığımda bu parlaklık sorunundan kurtulabilir miyim?
« Yanıtla #19 : 19 Nisan 2018, 13:14:57 »
Rica ederiz.
Tam olarak şudur ya da budur diyemiyorum, bu değişkenle çekirdeğe güç yönetimi ile ilgili nasıl davranması gerektiğini belirtmiş olduk. Yani sorunun temelinde güç yönetimi vardı.
Burada çekirdek değişkenlerinin ve ne işe yaradıklarının bir rehberi mevcut.
Konu başlığını etiketlerseniz, konuyu kilitleyebiliriz.
  • İleti: 74
Ynt: [Çözüldü] Manjaro - Lenovo Z500 Ekran Parlaklığı Sorunu
« Yanıtla #20 : 19 Nisan 2018, 13:25:51 »
Tamamdır çok teşekkürler. Etiketi ekledim konuyu kilitleyebilirsiniz.
