Gönderen Konu: Pencerelerin ekrandan taşması  (Okunma sayısı 2413 defa)
Çevrimdışı abh1z
  • İleti: 25
  • Dağıtım: Linux Mint 19
  • Grafik Kartı: AMD Radion
  • İşlemci: İntel Core i5
« : 30 Nisan 2018, 17:42:29 »
Bazı uygulamalarda pencere açtığımda ekranın dışına taşıyor ve en alttaki seçeneklere ulaşamıyorum. DPI yı düşürmeme rağmen sorunu çözemedim. Bu sorunu nasıl çözebilirim?
Edit:
Sistem Bilgileri
System:    Host: asnus Kernel: 4.10.0-38-generic i686 (32 bit gcc: 5.4.0)
           Desktop: Xfce 4.12.3 (Gtk 2.24.28) dm: lightdm
Machine:   System: CASPER BILGISAYAR SISTEMLERI A.S (portable) product: CASPER NIRVANA v: Rev 1.0
           Mobo: CASPER BILGISAYAR SISTEMLERI A.S model: CASPER NIRVANA v: Rev 1.0
           Bios: American Megatrends v: 0101 date: 01/22/2010
           Chassis: type: 10
CPU:       Single core Intel Atom N450 (-HT-) cache: 512 KB
           flags: (lm nx pae sse sse2 sse3 ssse3) bmips: 3325
           clock speeds: min/max: 1000/1667 MHz 1: 1333 MHz 2: 1333 MHz
Graphics:  Card: Intel Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller
           bus-ID: 00:02.0 chip-ID: 8086:a011
           Resolution: 1024x600@60.00hz
           GLX Renderer: Mesa DRI Intel Pineview M x86/MMX/SSE2
           GLX Version: 1.4 Mesa 17.2.8 Direct Rendering: Yes
Audio:     Card Intel NM10/ICH7 Family High Definition Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:27d8
           Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic
Network:   Card-1: Qualcomm Atheros AR8132 Fast Ethernet
           driver: atl1c v: 1.0.1.1-NAPI port: ec00
           bus-ID: 01:00.0 chip-ID: 1969:1062
           IF: ens32 state: down mac: <filter>
           Card-2: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express)
           driver: ath9k bus-ID: 03:00.0 chip-ID: 168c:002b
           IF: wls34 state: up mac: <filter>
Drives:    HDD Total Size: 160.0GB (11.1% used)
           ID-1: /dev/sda model: WDC_WD1600BEVT size: 160.0GB serial: WD-WXC409822663
Partition: ID-1: / size: 131G used: 15G (13%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 2.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
           Unused Devices: none
Sensors:   System Temperatures: cpu: 60.0C mobo: N/A
Info:      Processes: 159 Uptime: 2:09 Memory: 792.9/2003.6MB
           Client: Shell (bash 4.3.481 running in xfce4-terminal) inxi: 2.2.35
« Son Düzenleme: 30 Nisan 2018, 17:49:33 Gönderen: abh1z »
Ynt: Pencerelerin ekrandan taşması
« Yanıtla #1 : 01 Mayıs 2018, 02:41:15 »
1024×768 resolution (on lower resolutions, press ALT to drag windows with the mouse if they don’t fit in the screen).
Bazı uygulamalardan kasıt Yazılım Yöneticisi ve Güncelleme Yöneticisi ise şu an yapacak br şey yok. ALT+Sol Fare tuşu ile tutup bunları yukarı taşıyarak istediğiniz düğmelere ulaşabilirsiniz.
Çevrimdışı abh1z
  • İleti: 25
« Yanıtla #2 : 02 Mayıs 2018, 13:00:01 »
Teşekkür Ederim. Kolay Gelsin.
