Gönderen Konu: [Çözüldü] RTL8723BE Kablosuz Ağ Yavaşlık Sorunu  (Okunma sayısı 2401 defa)
Çevrimdışı ramoss13
  • İleti: 3
  • Dağıtım: mint
  • Grafik Kartı: nvidia
  • İşlemci: intel
Aynı ağda win10 a göre hız da problem var . Diğer çözümlere baktım fakat pek bi çözüm bulamadım.Yardımcı olursanız çok sevinirim .
kullandıgım linux :
ramazan@ramazan-X541UJ ~ $ cat /etc/lsb-release
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=18.3
DISTRIB_CODENAME=sylvia
DISTRIB_DESCRIPTION="Linux Mint 18.3 Sylvia"
ramazan@ramazan-X541UJ ~ $ lspci -nnk | grep -iA2 net
02:00.2 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [10ec:8136] (rev 06)
   Subsystem: ASUSTeK Computer Inc. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [1043:200f]
   Kernel driver in use: r8169
   Kernel modules: r8169
03:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter [10ec:b723]
   Subsystem: Lite-On Communications Inc RTL8723BE PCIe Wireless Network Adapter [11ad:1723]
   Kernel driver in use: rtl8723be
   Kernel modules: rtl8723be
ramazan@ramazan-X541UJ ~ $ lsusb
Bus 001 Device 003: ID 0bda:b721 Realtek Semiconductor Corp.
Bus 001 Device 002: ID 04f2:b52b Chicony Electronics Co., Ltd
ramazan@ramazan-X541UJ ~ $ rfkill list
0: hci0: Bluetooth
   Soft blocked: yes
   Hard blocked: no
1: phy0: Wireless LAN
   Soft blocked: no
   Hard blocked: no
ramazan@ramazan-X541UJ ~ $ sudo lshw -C network
[sudo] password for ramazan:
  *-network
       product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
       physical id: 0.2
       bus info: pci@0000:02:00.2
       logical name: enp2s0f2
       version: 06
       serial: 60:45:cb:b4:55:51
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8402-1_0.0.1 10/26/11 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:128 ioport:d000(size=256) memory:ef210000-ef210fff memory:e2100000-e2103fff
  *-network
       product: RTL8723BE PCIe Wireless Network Adapter
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: wlp3s0
       version: 00
       serial: 3c:a0:67:26:8b:3a
       width: 64 bits
       clock: 33MHz
       configuration: broadcast=yes driver=rtl8723be driverversion=4.13.0-41-generic firmware=N/A ip=10.40.5.31 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:17 ioport:c000(size=256) memory:ef100000-ef103fff
ramazan@ramazan-X541UJ ~ $ iwconfig | grep Power
enp2s0f2  no wireless extensions.
          Bit Rate=72.2 Mb/s   Tx-Power=20 dBm
          Power Management:off
ramazan@ramazan-X541UJ ~ $ lsmod
cmac                   16384  0
iwlwifi               249856  0
rfcomm                 77824  14
ccm                    20480  3
bbswitch               16384  0
nvidia_uvm            671744  0
nvidia_drm             45056  3
nvidia_modeset        860160  5 nvidia_drm
nvidia              13139968  358 nvidia_modeset,nvidia_uvm
rtl8723be             102400  0
btcoexist             131072  1 rtl8723be
rtl8723_common         24576  1 rtl8723be
snd_hda_codec_realtek    98304  1
rtl_pci                32768  1 rtl8723be
rtlwifi                77824  4 rtl_pci,btcoexist,rtl8723_common,rtl8723be
mac80211              782336  3 rtl_pci,rtlwifi,rtl8723be
snd_soc_skl            77824  0
snd_soc_skl_ipc        49152  1 snd_soc_skl
snd_soc_sst_ipc        16384  1 snd_soc_skl_ipc
snd_soc_sst_dsp        32768  1 snd_soc_skl_ipc
snd_hda_ext_core       24576  1 snd_soc_skl
snd_soc_sst_match      16384  1 snd_soc_skl
cfg80211              614400  3 iwlwifi,mac80211,rtlwifi
snd_soc_core          229376  1 snd_soc_skl
rtsx_pci_ms            20480  0
memstick               16384  1 rtsx_pci_ms
snd_compress           20480  1 snd_soc_core
ac97_bus               16384  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
hid_multitouch         20480  0
asus_nb_wmi            28672  0
asus_wmi               28672  1 asus_nb_wmi
wmi_bmof               16384  0
sparse_keymap          16384  1 asus_wmi
mxm_wmi                16384  0
snd_hda_intel          40960  5
snd_hda_codec         126976  4 snd_hda_intel,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec_realtek
snd_hda_core           81920  7 snd_hda_intel,snd_hda_codec,snd_hda_ext_core,snd_soc_skl,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec_realtek
snd_pcm                98304  9 snd_hda_intel,snd_hda_codec,snd_pcm_dmaengine,snd_hda_ext_core,snd_hda_core,snd_soc_skl,snd_hda_codec_hdmi,snd_soc_core
kvm_intel             204800  0
kvm                   593920  1 kvm_intel
pcbc                   16384  0
aesni_intel           188416  2
intel_rapl_perf        16384  0
videodev              176128  3 uvcvideo,videobuf2_core,videobuf2_v4l2
snd                    81920  22 snd_compress,snd_hda_intel,snd_hwdep,snd_seq,snd_hda_codec,snd_timer,snd_rawmidi,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_seq_device,snd_hda_codec_realtek,snd_soc_core,snd_pcm
media                  40960  2 uvcvideo,videodev
idma64                 20480  0
virt_dma               16384  1 idma64
mei_me                 40960  0
processor_thermal_device    16384  0
intel_lpss_pci         20480  0
mei                   102400  1 mei_me
intel_soc_dts_iosf     16384  1 processor_thermal_device
intel_pch_thermal      16384  0
hci_uart              106496  0
btbcm                  16384  2 hci_uart,btusb
serdev                 20480  1 hci_uart
btqca                  16384  1 hci_uart
int3403_thermal        16384  0
int340x_thermal_zone    16384  2 int3403_thermal,processor_thermal_device
btintel                16384  2 hci_uart,btusb
wmi                    24576  3 asus_wmi,wmi_bmof,mxm_wmi
bluetooth             548864  43 btrtl,hci_uart,btintel,btqca,bnep,btbcm,rfcomm,btusb
ecdh_generic           24576  1 bluetooth
intel_lpss_acpi        16384  0
intel_lpss             16384  2 intel_lpss_pci,intel_lpss_acpi
tpm_crb                16384  0
int3400_thermal        16384  0
acpi_thermal_rel       16384  1 int3400_thermal
acpi_pad              180224  0
acpi_als               16384  0
kfifo_buf              16384  1 acpi_als
asus_wireless          16384  0
industrialio           69632  2 acpi_als,kfifo_buf
ip6t_REJECT            16384  1
nf_log_ipv6            16384  5
xt_hl                  16384  22
nf_conntrack_ipv6      20480  8
nf_defrag_ipv6         36864  1 nf_conntrack_ipv6
ipt_REJECT             16384  1
nf_log_ipv4            16384  5
nf_log_common          16384  2 nf_log_ipv6,nf_log_ipv4
xt_LOG                 16384  10
xt_limit               16384  13
xt_tcpudp              16384  18
nf_conntrack_ipv4      16384  8
xt_conntrack           16384  16
ip6_tables             28672  1 ip6table_filter
nf_nat                 28672  1 nf_nat_ftp
nf_conntrack_ftp       20480  1 nf_nat_ftp
nf_conntrack          131072  8 nf_conntrack_ipv6,nf_conntrack_ftp,nf_conntrack_ipv4,nf_conntrack_broadcast,nf_nat_ftp,nf_conntrack_netbios_ns,xt_conntrack,nf_nat
libcrc32c              16384  2 nf_conntrack,nf_nat
ip_tables              24576  1 iptable_filter
x_tables               40960  13 xt_LOG,ipt_REJECT,ip_tables,iptable_filter,xt_tcpudp,xt_limit,ip6t_REJECT,ip6table_filter,xt_addrtype,ip6t_rt,xt_conntrack,ip6_tables,xt_hl
btrfs                1101824  0
raid6_pq              118784  1 btrfs
i915                 1830912  3
rtsx_pci_sdmmc         24576  0
drm_kms_helper        167936  2 i915,nvidia_drm
r8169                  86016  0
rtsx_pci               57344  2 rtsx_pci_sdmmc,rtsx_pci_ms
ahci                   36864  3
i2c_hid                20480  0
drm                   360448  6 i915,nvidia_drm,drm_kms_helper
hid                   118784  2 i2c_hid,hid_multitouch
video                  40960  2 asus_wmi,i915
pinctrl_sunrisepoint    28672  0
pinctrl_intel          20480  1 pinctrl_sunrisepoint
Düzenleme: Konu başlığı
Bakınız =>
« Son Düzenleme: 07 Haziran 2018, 21:38:35 Gönderen: Butterfly »
Ynt: RTL8723BE Kablosuz Ağ Yavaşlık Sorunu
« Yanıtla #1 : 16 Mayıs 2018, 14:08:01 »
Çekirdek sürümünü güncelleyip,
[info] [Nasıl] Linux Mint 18.x Linux Çekirdeği 4.15.x HWE Destekli Sürüm Kurulumu[/info]
aşağıdaki komutla linux-firmware paketini de yeniden kurunuz/güncelleyiniz.
sudo apt install --reinstall linux-firmware
Ardından aşağıdaki komutla yapılandırma dosyası oluşturup sistemi yeniden başlatınız.
echo "options rtl8723be swenc=1 ips=0 fwlps=0 ant_sel=1" | sudo tee /etc/modprobe.d/rtl8723be.conf
Eğer sorun çözülmezse, ağıdaki komutla anten seçimini 2 yapacak yapılandırma dosyası oluşturup sistemi yeniden başlatınız.
echo "options rtl8723be swenc=1 ips=0 fwlps=0 ant_sel=2" | sudo tee /etc/modprobe.d/rtl8723be.conf
Çevrimdışı ramoss13
  • İleti: 3
  • Dağıtım: mint
  • İşlemci: intel
« Yanıtla #2 : 16 Mayıs 2018, 18:11:12 »
Çok teşekkür ederim. işe yaradı  :)
« Yanıtla #3 : 17 Mayıs 2018, 08:50:11 »
Rica ederiz.
Başlığı etiketlerseniz konuyu kilitleyebiliriz.
[okay] Çözülen başlıkların etiketlenmesi hakkında.[/okay]
