Gönderen Konu: MATLAB 2014b kurulum Sorunu  (Okunma sayısı 5569 defa)
Çevrimdışı mesut24
  • İleti: 60
  • Dağıtım: Linux Mint 19
  • Grafik Kartı: NVDİA
  • İşlemci: İNTEL
« : 30 Mayıs 2018, 15:48:24 »
Merhabalar. Lİnux Mİnt 18 e Matlab kurulumunu sorunsuz yaptım Açarken şöyle bir hata veriyor.
erdenler@erdenler /usr/local/MATLAB/R2014b/bin/glnxa64 $ ./MATLAB
java.lang.UnsatisfiedLinkError: no nativeservices in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at com.mathworks.services.Prefs.<clinit>(Prefs.java:152)
at com.mathworks.fatalexit.FatalExitFrame.<init>(FatalExitFrame.java:138)
at com.mathworks.fatalexit.FatalExitFrame$13.run(FatalExitFrame.java:775)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Exception in thread "AWT-EventQueue-0" java.lang.UnsatisfiedLinkError: com.mathworks.services.Prefs.nativeGetPreferencesDirectory()Ljava/lang/String;
at com.mathworks.services.Prefs.nativeGetPreferencesDirectory(Native Method)
at com.mathworks.services.Prefs.getPropertyDirectory(Prefs.java:184)
at com.mathworks.services.Prefs.load(Prefs.java:240)
at com.mathworks.services.Prefs.<clinit>(Prefs.java:160)
       Segmentation violation detected at Wed May 30 15:31:30 2018
Configuration:
  Crash Decoding     : Disabled
  Current Visual     : None
  Default Encoding   : UTF-8
  GNU C Library      : 2.23 stable
  MATLAB Architecture: glnxa64
  MATLAB Root        : /usr/local/MATLAB/R2014b
  MATLAB Version     : 8.4.0.150421 (R2014b)
  Operating System   : Linux 4.13.0-39-generic #44~16.04.1-Ubuntu SMP Thu Apr 5 16:43:10 UTC 2018 x86_64
  Processor ID       : x86 Family 6 Model 58 Stepping 9, GenuineIntel
  Software OpenGL    : 0
  Virtual Machine    : Java 1.7.0_11-b21 with Oracle Corporation Java HotSpot(TM) 64-Bit Server VM mixed mode
  Window System      : No active display
Fault Count: 1
Abnormal termination:
Register State (from fault):
  RAX = 0000000000000000  RBX = 00007fcd6a5c00e8
  RCX = 00007fcd9025fb10  RDX = 0000000000000006
  RSP = 00007fcd67c2e6d0  RBP = 00007fcd67c2e7f0
  RSI = 0000000000000000  RDI = 00007fcd6a5968a8
   R8 = 0000000000000030   R9 = 0000000000000004
  R10 = 00007fcd6a916ef0  R11 = 00007fcd6a593000
  R12 = 00007fcd9464e460  R13 = 0000006900000006
  R14 = 0000000000000006  R15 = 00007fcd6a597280
  RIP = 00007fce1d4c373c  EFL = 0000000000010206
   CS = 0033   FS = 0000   GS = 0000
Stack Trace (from fault):
[  0] 0x00007fce1d4c373c                        /lib64/ld-linux-x86-64.so.2+00051004
[  1] 0x00007fce1d4cc851                        /lib64/ld-linux-x86-64.so.2+00088145
[  2] 0x00007fce1d4c7564                        /lib64/ld-linux-x86-64.so.2+00066916
[  3] 0x00007fce1d4cbda9                        /lib64/ld-linux-x86-64.so.2+00085417
[  4] 0x00007fce19d48f09                   /lib/x86_64-linux-gnu/libdl.so.2+00003849
[  5] 0x00007fce1d4c7564                        /lib64/ld-linux-x86-64.so.2+00066916
[  6] 0x00007fce19d49571                   /lib/x86_64-linux-gnu/libdl.so.2+00005489
[  7] 0x00007fce19d48fa1                   /lib/x86_64-linux-gnu/libdl.so.2+00004001 dlopen+00000049
[  8] 0x00007fcd64a58755                     /usr/lib/nvidia-384/libGL.so.1+00718677
If this problem is reproducible, please submit a Service Request via:
    http://www.mathworks.com/support/contact_us/
A technical support engineer might contact you with further information.
Thank you for your help.** This crash report has been saved to disk as /home/erdenler/matlab_crash_dump.2486-1 **
MATLAB is exiting because of fatal error
Killed
Çözümünü bulursanız sevinirim . İyi günler..
Ynt: MATLAB 2014b kurulum Sorunu
« Yanıtla #1 : 30 Mayıs 2018, 15:52:32 »
Oracle Java kurmayı deneyebilirsiniz. https://forum.linuxmint.net.tr/index.php?topic=2466.msg15604#msg15604
Eğer sorun bu şekilde çözülmezse, aşağıdaki komutla matlab-support paketini kurmayı denersiniz.
sudo apt install matlab-support
« Son Düzenleme: 30 Mayıs 2018, 16:10:46 Gönderen: Butterfly »
Çevrimdışı mesut24
  • İleti: 60
  • İşlemci: İNTEL
« Yanıtla #2 : 30 Mayıs 2018, 17:28:15 »
java 8 kurulu zaten bende
« Yanıtla #3 : 31 Mayıs 2018, 02:48:23 »
verilen diğer komutu uygulayınız.
Çevrimdışı mesut24
  • İleti: 60
  • İşlemci: İNTEL
« Yanıtla #4 : 31 Mayıs 2018, 03:08:48 »
Şimdi MATLAB açılıyor, yalnız simulink kısmına girdiğim zaman atıyor yine.
Birde açılışta şu hataları veriyor.
javax.media.opengl.GLException: X11GLXDrawableFactory - Could not initialize shared resources for :0
at jogamp.opengl.x11.glx.X11GLXDrawableFactory$SharedResourceImplementation.createSharedResource(X11GLXDrawableFactory.java:316)
at jogamp.opengl.SharedResourceRunner.run(SharedResourceRunner.java:295)
at java.lang.Thread.run(Unknown Source)
Caused by: javax.media.opengl.GLException: Startup Class Loader-SharedResourceRunner: Error making temp context(1) current: display 0x7f86f4097780, context 0x7f86f40f10d0, drawable X11OnscreenGLXDrawable[Realized true,
Factory   jogamp.opengl.x11.glx.X11GLXDrawableFactory@51d8cca8,
Handle    0x6200002,
Surface   WrappedSurface[ displayHandle 0x7f86f4097780
, surfaceHandle 0x6200002
, size 64x64
, UOB[ OWNS_SURFACE | WINDOW_INVISIBLE ]
, X11GLXGraphicsConfiguration[X11GraphicsScreen[X11GraphicsDevice[type .x11, connection :0, unitID 0, handle 0x7f86f4097780, owner true, ResourceToolkitLock[obj 0x70645392, isOwner true, <4aaacfe3, 14366661>[count 2, qsz 0, owner <Startup Class Loader-SharedResourceRunner>]]], idx 0], visualID 0x31f, fbConfigID 0xc9,
requested GLCaps[rgba 8/8/8/0, opaque, accum-rgba 0/0/0/0, dp/st/ms 16/0/0, dbl, mono  , hw, GLProfile[GL2/GL2.sw], on-scr[.]],
chosen    GLCaps[glx vid 0x31f, fbc 0xc9: rgba 8/8/8/0, opaque, accum-rgba 0/0/0/0, dp/st/ms 24/0/0, dbl, mono  , hw, GLProfile[GL2/GL2.sw], on-scr[.]]]
, surfaceLock <7f7b74a4, 226fc5f>[count 1, qsz 0, owner <Startup Class Loader-SharedResourceRunner>]
, X11DummyUpstreamSurfaceHook[ 64x64]
, upstreamSurface false ]]
at jogamp.opengl.x11.glx.X11GLXContext.createImpl(X11GLXContext.java:346)
at jogamp.opengl.GLContextImpl.makeCurrentWithinLock(GLContextImpl.java:662)
at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:561)
at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:518)
at jogamp.opengl.x11.glx.X11GLXDrawableFactory$SharedResourceImplementation.createSharedResource(X11GLXDrawableFactory.java:292)
... 2 more
Düzenleme: Kod etiketi ve yazım kuralları.
« Son Düzenleme: 31 Mayıs 2018, 09:00:33 Gönderen: Butterfly »
« Yanıtla #5 : 31 Mayıs 2018, 09:03:23 »
Lütfen çıktıları kod etiketi içinde paylaşalım ve yazım kurallarına özen gösterelim.
Sürücü Yöneticisinden Nvidia sürücüsünü kurmayı deneyiniz ve Oracle Java 8'in etkin oladuğundan emin olunuz.
Çevrimdışı mesut24
  • İleti: 60
  • İşlemci: İNTEL
« Yanıtla #6 : 01 Haziran 2018, 01:01:47 »
NVDİA olduğu zaman ise açılıp kapanıyor hemen. Anlaşılan o ki ben OCTAVE Kullanayım. MATLAB için Linux 'u terkedemem. :)
« Yanıtla #7 : 01 Haziran 2018, 08:47:45 »
Çıktıları paylaşırsanız sorunu araştırabiliriz.
Eğer Matlab kullanımında GPU gücüne çok ihityacınız yoksa, bu uygulamayı yazılımsal işleme kipinde (yani CPU ile) çalıştırmayı deneyebilirsiniz.
Ayrıca yazılımın güncel sürümlerinde bu sorun çözülmüş olabilir, bunu da değerlendirmek fayda var.
Çevrimdışı zboraon
  • İleti: 130
« Yanıtla #8 : 01 Haziran 2018, 12:15:19 »
Selamlar,
Matlab'ı
matlab -nosoftwareopengl
ile çalıştırmayı dener misiniz?
Kendi çapında bir jeolog.
Çevrimdışı mesut24
  • İleti: 60
  • İşlemci: İNTEL
« Yanıtla #9 : 02 Haziran 2018, 15:32:08 »
Selamlar,
Matlab'ı
Dediğiniz kod ile matlab çalışıyor yalnız yine açılışta şu uyarıyı veriyor.
MATLAB crash file:/root/matlab_crash_dump.8382-1:
       Segmentation violation detected at Sat Jun  2 15:31:14 2018
Configuration:
  Operating System   : Linux 4.15.0-22-generic #24~16.04.1-Ubuntu SMP Fri May 18 09:46:31 UTC 2018 x86_64
  Software OpenGL    : 0
Fault Count: 1
  RAX = 0000000000000000  RBX = 00007fd2b5b200e8
  RCX = 00007fd2d426dd90  RDX = 0000000000000006
  RSP = 00007fd2b7bf7650  RBP = 00007fd2b7bf7770
  RSI = 0000000000000000  RDI = 00007fd2b5af68a8
  R10 = 00007fd2b5e76ef0  R11 = 00007fd2b5af3000
  R12 = 00007fd2d859d300  R13 = 0000006900000006
  R14 = 0000000000000006  R15 = 00007fd2b5af7280
  RIP = 00007fd36060373c  EFL = 0000000000010206
[  0] 0x00007fd36060373c                        /lib64/ld-linux-x86-64.so.2+00051004
[  1] 0x00007fd36060c851                        /lib64/ld-linux-x86-64.so.2+00088145
[  2] 0x00007fd360607564                        /lib64/ld-linux-x86-64.so.2+00066916
[  3] 0x00007fd36060bda9                        /lib64/ld-linux-x86-64.so.2+00085417
[  4] 0x00007fd35ce88f09                   /lib/x86_64-linux-gnu/libdl.so.2+00003849
[  5] 0x00007fd360607564                        /lib64/ld-linux-x86-64.so.2+00066916
[  6] 0x00007fd35ce89571                   /lib/x86_64-linux-gnu/libdl.so.2+00005489
[  7] 0x00007fd35ce88fa1                   /lib/x86_64-linux-gnu/libdl.so.2+00004001 dlopen+00000049
[  8] 0x00007fd2aa14f405                     /usr/lib/nvidia-396/libGL.so.1+00701445
Bu seferde bu çıktıyı veriyor. İlgilendiğiniz için teşekkürler
