Gönderen Konu: [Çözüldü] Linux Mint 19'a yükseltme sonrası cinnamon çöktü uyarısı (Nvidia Prime Sürücü Sorunu)  (Okunma sayısı 17088 defa)
Aşağıdaki komutların çıktılarına da bakalım.
cat /var/log/gpu-manager.log
systemctl status nvidia-fallback.service
Çevrimdışı Serdar Sert
  • İleti: 70
  • Dağıtım: Mint 19
  • Masaüstü Ortamı: Cinnamon 4.4
log_file: /var/log/gpu-manager.log
last_boot_file: /var/lib/ubuntu-drivers-common/last_gfx_boot
new_boot_file: /var/lib/ubuntu-drivers-common/last_gfx_boot
can't access /run/u-d-c-nvidia-was-loaded file
can't access /opt/amdgpu-pro/bin/amdgpu-pro-px
Looking for nvidia modules in /lib/modules/4.15.0-24-generic/updates/dkms
Looking for amdgpu modules in /lib/modules/4.15.0-24-generic/updates/dkms
Is nvidia loaded? no
Was nvidia unloaded? no
Is nvidia blacklisted? yes
Is intel loaded? yes
Is radeon loaded? no
Is radeon blacklisted? no
Is amdgpu loaded? no
Is amdgpu blacklisted? no
Is amdgpu versioned? no
Is amdgpu pro stack? no
Is nouveau loaded? no
Is nouveau blacklisted? yes
Is nvidia kernel module available? no
Is amdgpu kernel module available? no
Vendor/Device Id: 8086:166
BusID "PCI:0@0:2:0"
Is boot vga? yes
Vendor/Device Id: 10de:1140
BusID "PCI:1@0:0:0"
Is boot vga? no
Error: can't access /sys/bus/pci/devices/0000:01:00.0/driver
The device is not bound to any driver. Skipping...
Skipping "/dev/dri/card0", driven by "i915"
Found "/dev/dri/card0", driven by "i915"
output 0:
card0-LVDS-1
Number of connected outputs for /dev/dri/card0: 1
Does it require offloading? yes
last cards number = 2
Has amd? no
Has intel? yes
Has nvidia? no
How many cards? 1
The number of cards has changed!
Has the system changed? Yes
System configuration has changed
Single card detected
Nothing to do
● nvidia-fallback.service - Fall back on nouveau if nvidia is not loaded
   Loaded: loaded (/lib/systemd/system/nvidia-fallback.service; disabled; vendor
   Active: inactive (dead)
Intel GPU'yu seçtikten sonra, sistemi yeniden başlatmayı dener misiniz?
  • İleti: 70
  • Dağıtım: Mint 19
Başlattım hocam. Yazılımsal görsel işleme kipi hatasını verdi.
Şunları geri alalım bakalım.
sudo systemctl enable nvidia-fallback.service
sudo rm -f /etc/default/grub.d/nouveau.blacklist.cfg
sudo update-grub
sudo rm -f /etc/modules-load.d/bbswitch.conf
sudo update-initramfs -u
Ardından sistemi yeniden başlatın.
  • İleti: 70
  • Dağıtım: Mint 19
Komutlardan sonra tekrar başlattım. Intel GPU ve hata verdi yine.
sudo prime-select query
cat /proc/cmdline
  • İleti: 70
  • Dağıtım: Mint 19
intel
cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-4.15.0-24-generic root=UUID=16fea333-25b0-41cb-8d87-36e71b84b030 ro quiet splash nouveau.runpm=-1 vt.handoff=7
İlk komut çıktı vermedi mi?
  • İleti: 70
  • Dağıtım: Mint 19
Hocam intel çıktısını verdi.
Şimdi bir yazı gördüm;
https://blog.linuxmint.com/?p=3615#comment-144157
Bu Linux Mint 18.3/Ubuntu 16.04 deposuna eklenen Mesa 18.0.5 sürümle ilgili. Mesa'nın güncel sürümü 18.3 deposuna, Linux Mint 19/Ubuntu 18.04 deposundan önce eklendiği için sorun yaşanıyor. Bu sebeple bu sürüme (18.0.5) güncelleme yaptıysanız, Linux Mint 19/Ubuntu 18.04 deposuna Mesa 18.0.5 sürüm paketleri eklenmeden, Linux Mint 18.3'ten güncelleme yapılmaması gerekiyor. Bu sebeple mintupgrade aracı güncellendi ve bu durumu algıladığında yükseltmeyi engelliyor.
Bununla birlikte siz, önceki mesajınızda paylaştığınız üzere, Mesa ile ilgili paketleri yeniden kurarak sorunun etrafından dolaşarak geçici çözüm sağlamıştınız.
Nvidia Prime ilgili sorunun bunun ötesinde bir şey olduğunu düşünüyorum, büyük ihtimalle buradaki hata bildirimine istinaden yayınlanacak bir güncelleme ile çözülebilir diye umuyorum.
Şu an alternatif önerileri inceledim, ama tutarlı bir sonuç bulamadım. Eğer bir sonuç bulursam buradan paylaşabilirim.
Nvidia Prime yerine buradaki Bumblebee çözümü denenebilir, dilerseniz bunu uygulamayı deneyelim.
Nvidia Prime alternatifi olarak buradaki Nvidia-socket uygulaması denenebilir.
« Son Düzenleme: 09 Temmuz 2018, 11:45:02 Gönderen: Butterfly »
  • İleti: 70
  • Dağıtım: Mint 19
Hocam nasıl isterseniz öyle yapalım. Hem sonuçları görmüş oluruz.
Birde güncelleme sorunu var. Şimdi gelen güncellemeleri yüklersem, mesa paketlerini tekrar yükseltecek sanırım. İsterseniz onu da deneyebiliriz.
« Son Düzenleme: 09 Temmuz 2018, 15:06:43 Gönderen: Serdar Sert »
[member=394]Serdar Sert[/member] , Linux Mint 19 deposundan gelen Mesa 18.0.05 sürümünü kurmanızda bir sorun yok.
[error]Linux Mint 19.x serisi için, artık bu mesajdaki önerileri uygulamaya gerek yok. Nvidia-prime ile GPU geçişi sonrası oturumu yeniden başlatmak yeterli oluyor.[/error]
Aşağıdaki şekilde Nvidia-socket projesini kurmayı deneyelim.
Önce aşağıdaki komutlarla yönlendirdiğimiz işlemlerin iptal ettiğimizden emin olalım.
sudo rm -f /etc/modprobe.d/blacklist-nvidia.conf
sudo rm -f /etc/modprobe.d/blacklist-nouveau.conf
sudo update-grub
Şimdi aşağıdaki komutlarla uyglamayı kurmayı deneyebiliriz.
sudo apt install git build-essential rustc cargo
git clone https://github.com/timrichardson/Prime-Ubuntu-18.04.git
cd ~/Prime-Ubuntu-18.04/prime_socket/src
sudo make install
Not: İşlemler bir miktar uzun olabilir.
Uygulamayı kurduysanız, aşağıdaki komutlarla bbswitch-dkms ile ilgili işlemleri yeniden yapınız.
sudo apt install --reinstall bbswitch-dkms
echo 'bbswitch' | sudo tee  /etc/modules-load.d/bbswitch.conf
Değişiklik işlemini Nvidia Ayar Yöneticisi üstünden yapmak için, aşağıdaki komutlarla asıl prime-select dosyasını yedekleyip, deneysel olanına sembolik bağlantı oluşturunuz.
sudo mv /usr/bin/prime-select /usr/bin/prime-select_asil
sudo ln -s /usr/local/bin/prime-select /usr/bin/prime-select
Şimdi sistemi yeniden başlatmayı ve aşağıdaki komutlarla geçiş yapmayı deneyebilirsiniz.
sudo prime-select nvidia
sudo prime-select intel
Değişiklik sonrası oturumu kapatıp açmanız gerekecek.
« Son Düzenleme: 12 Mart 2019, 22:57:28 Gönderen: Butterfly »
  • İleti: 70
  • Dağıtım: Mint 19
Hocam iki GPU arasında da sorunsuz bir şekilde geçişler tamamlandı. Geçişler sırasında sadece oturumu kapatıp açıyor.
Güncellemeler tamamlandı. Herhangi bir sorun yok.
Hocam  18.3'ten 19'a yükseltme şu an itibarı ile sorunsuz bir şekilde tamamlandı.
« Son Düzenleme: 09 Temmuz 2018, 18:09:13 Gönderen: Serdar Sert »
Bu durumda konu başlığını etiketlerseniz, konuyu kilitleyebiliriz.
