Gönderen Konu: [Çözüldü] Linux Mint 19'da Bumblebee optirun hatası  (Okunma sayısı 3536 defa)
Çevrimdışı tnhnclskn
  • İleti: 13
    • tnhnclskn
  • Dağıtım: Linux Mint 19
  • Grafik Kartı: Nvidia GTX960M
  • İşlemci: Intel i7 6700HQ
Linux Mint 19'da Bumblebee Kurulumunu Nasıl Yapabilirim? bağlantısındaki anlatımı takip ederek kurduğumda 'optirun glxgears' sonucunu aşağıda paylaşıyorum.
Linux Mint 19 Cinnamon 64 Bit
tnhnclskn[member=3683]tnhnclskn[/member]-N551VW:~$ optirun glxgears
X Error of failed request:  BadMatch (invalid parameter attributes)
  Major opcode of failed request:  155 (GLX)
  Minor opcode of failed request:  11 (X_GLXSwapBuffers)
  Serial number of failed request:  37
  Current serial number in output stream:  38
primus: warning: dropping a frame to avoid deadlock
primus: warning: timeout waiting for display worker
terminate called without an active exception
tnhnclskn[member=3683]tnhnclskn[/member]-N551VW:~$ inxi -SMGxx
System:    Host: tnhnclskn-N551VW Kernel: 4.15.0-29-generic x86_64 bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1) dm: lightdm Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: ASUSTeK product: N551VW v: 1.0 serial: N/A
           Mobo: ASUSTeK model: N551VW v: 1.0 serial: N/A
           UEFI: American Megatrends v: N551VW.205 date: 11/13/2015
Graphics:  Card-1: Intel HD Graphics 530 bus-ID: 00:02.0 chip-ID: 8086:191b
           Card-2: NVIDIA GM107M [GeForce GTX 960M] bus-ID: 01:00.0 chip-ID: 10de:139b
           Display Server: x11 (X.Org 1.19.6 ) drivers: modesetting (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.00hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2)
           version: 4.5 Mesa 18.0.5 (compat-v: 3.0) Direct Render: Yes
tnhnclskn[member=3683]tnhnclskn[/member]-N551VW:~$ glxinfo | grep render
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 530 (Skylake GT2)
tnhnclskn[member=3683]tnhnclskn[/member]-N551VW:~$ lspci | egrep 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 530 (rev 06)
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 960M] (rev ff)
tnhnclskn[member=3683]tnhnclskn[/member]-N551VW:~$ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
eDP-1 connected (normal left inverted right x axis y axis)
   1920x1080     60.02 +  60.01    59.97    59.96    59.93
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1280x1024     60.02
   1440x900      59.89
   1400x900      59.96    59.88
   1280x960      60.00
   1440x810      60.00    59.97
   1368x768      59.88    59.85
   1360x768      59.80    59.96
   1152x864      60.00
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       59.93    60.00
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
HDMI-2 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 480mm x 270mm
   1920x1080     60.00*+  50.00    59.94
   1920x1080i    60.00    50.00    59.94
   1680x1050     59.88
   1400x1050     59.95
   1600x900      60.00
   1280x1024     75.02    60.02
   1440x900      59.90
   1280x800      59.91
   1152x864      75.00
   1280x720      60.00    50.00    59.94
   1024x768      75.03    60.00
   800x600       75.00    60.32
   720x576       50.00
   720x480       60.00    59.94
   640x480       75.00    60.00    59.94
   720x400       70.08
DP-2 disconnected (normal left inverted right x axis y axis)
HDMI-3 disconnected (normal left inverted right x axis y axis)
tnhnclskn[member=3683]tnhnclskn[/member]-N551VW:~$ cat /etc/X11/xorg.conf
tnhnclskn[member=3683]tnhnclskn[/member]-N551VW:~$ dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl|fglrx'
ii  bumblebee                                  3.2.1-17                            amd64        NVIDIA Optimus support for Linux
ii  libnvidia-cfg1-390:amd64                   390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-390                       390.77-0ubuntu0~gpu18.04.1          all          Shared files used by the NVIDIA libraries
ii  libnvidia-compute-390:amd64                390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA libcompute package
ii  libnvidia-decode-390:amd64                 390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-390:amd64                 390.77-0ubuntu0~gpu18.04.1          amd64        NVENC Video Encoding runtime library
ii  libnvidia-fbc1-390:amd64                   390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-390:amd64                     390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ifr1-390:amd64                   390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  nvidia-390                                 390.77-0ubuntu0~gpu18.04.1          amd64        Transitional package for nvidia-driver-390
ii  nvidia-compute-utils-390                   390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA compute utilities
ii  nvidia-dkms-390                            390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA DKMS package
ii  nvidia-driver-390                          390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA driver metapackage
ii  nvidia-kernel-common-390                   390.77-0ubuntu0~gpu18.04.1          amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-390                   390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA kernel source package
ii  nvidia-prime-applet                        1.0.7                               all          An applet for NVIDIA Prime
ii  nvidia-utils-390                           390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA driver support binaries
ii  primus                                     0~20150328-6                        amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                          0~20150328-6                        amd64        Shared libraries for primus
ii  xserver-xorg-video-nvidia-390              390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA binary Xorg driver
« Son Düzenleme: 25 Temmuz 2018, 20:50:21 Gönderen: tnhnclskn »
Ynt: Linux Mint 19'da Bumblebee optirun hatası
« Yanıtla #1 : 24 Temmuz 2018, 00:27:12 »
Aşağıdaki komutla çalıştırınca durum ne oluyor?
__GLVND_DISALLOW_PATCHING=1 optirun glxgears
ya da aşağıdaki komutlarla durum ne oluyor?
primusrun glxgears
__GLVND_DISALLOW_PATCHING=1 primusrun glxgears
« Son Düzenleme: 24 Temmuz 2018, 00:33:30 Gönderen: Butterfly »
  • İleti: 13
    • tnhnclskn
« Yanıtla #2 : 24 Temmuz 2018, 00:33:54 »
Çarkları görebiliyorum fakat 60 fps olduğundan dolayı ekran kartının devreye girdiğini düşünmüyorum.
tnhnclskn[member=3683]tnhnclskn[/member]-N551VW:~$ __GLVND_DISALLOW_PATCHING=1 optirun glxgears
301 frames in 5.0 seconds = 60.042 FPS
301 frames in 5.0 seconds = 60.021 FPS
« Yanıtla #3 : 24 Temmuz 2018, 00:35:19 »
Şu an primus köprüsü kullanıldığı için 60 FPS normal bir durum. Primus ile dikey senkronizasyon etkin olarak geliyor.
  • İleti: 13
    • tnhnclskn
« Yanıtla #4 : 24 Temmuz 2018, 00:40:20 »
Teşekkürler [member=8]Butterfly[/member],  peki bu parametreyi kapalı hale nasıl getirebilirim. Anlatımdaki kısmı yaptım fakat etkin değil anladığım kadarıyla.
tnhnclskn[member=3683]tnhnclskn[/member]-N551VW:~$ cat /etc/environment.d/glvnd.conf
« Yanıtla #5 : 24 Temmuz 2018, 00:48:37 »
Aşağıdaki komutla /etc/environment dosyasını açıp,
sudo xed /etc/environment
dosyanın en altına bu satırı ekleyip, dosyayı kaydetmeyi deneyin.
Ardından sistemi yeniden başlatın.
Bu şekilde sorun çözülürse, aşağıdaki komutla /etc/environment.d/glvnd.conf dosyasını silersiniz.
sudo rm -f /etc/environment.d/glvnd.conf
  • İleti: 13
    • tnhnclskn
Ynt: [Çözüldü] Linux Mint 19'da Bumblebee optirun hatası
« Yanıtla #6 : 25 Temmuz 2018, 20:50:43 »
Teşekkür ederim, sorun çözüldü.
« Yanıtla #7 : 25 Temmuz 2018, 21:12:24 »
Rica ederiz.
Geri dönüşlere istinaden, diğer üyelerimize yardımcı olabilecek bir rehber konuyu da hazırladık. Aşağıdaki bağlantıdan ulaşılabilir.
[info][Nasıl] Linux Mint 19.x - Intel + Nvidia Hibrit GPU İçin Bumblebee Kurulumu[/info]
[okay]Sorun çözüldüğü için konu kilitlemiştir.[/okay]
