Gönderen Konu: Linux Mint 19 - ASUS N551VW - Yeniden Başlatma Sorunu  (Okunma sayısı 2560 defa)
Çevrimdışı tnhnclskn
  • İleti: 13
    • tnhnclskn
  • Dağıtım: Linux Mint 19
  • Grafik Kartı: Nvidia GTX960M
  • İşlemci: Intel i7 6700HQ
Bilgisayarımı  yeniden başlatığımda kapanış aşamasında takılıyor fakat kapat dediğimde sorunsuz kapanıyor. Yeniden başlatma aşamasında ekran kapandıktan sonra bios ekranından önce takılıyor.
Bumblebee (Intel / Nvidia) kurulu.
tnhnclskn[member=3683]tnhnclskn[/member]-N551VW:~$ inxi -Fxxz
System:    Host: tnhnclskn-N551VW Kernel: 4.15.0-29-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1) dm: lightdm
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: ASUSTeK product: N551VW v: 1.0 serial: N/A
           Mobo: ASUSTeK model: N551VW v: 1.0 serial: N/A
           UEFI: American Megatrends v: N551VW.205 date: 11/13/2015
Battery    BAT0: charge: 24.5 Wh 91.8% condition: 26.7/56.2 Wh (48%)
           volts: 10.8/10.8
           model: ASUSTeK ASUS serial: N/A status: Charging
           hidpp__0: charge: N/A condition: NA/NA Wh volts: NA
           model: Logitech Wireless Mouse M215 2nd Gen serial: <filter>status: Discharging
           hidpp__1: charge: N/A condition: NA/NA Wh volts: NA
           model: Logitech Wireless Keyboard K330 serial: <filter>status: Discharging
CPU:       Quad core Intel Core i7-6700HQ (-MT-MCP-)
           arch: Skylake-S rev.3 cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 20736
           clock speeds: min/max: 800/3500 MHz 1: 1248 MHz 2: 1938 MHz
           3: 1791 MHz 4: 1782 MHz 5: 1864 MHz 6: 1926 MHz 7: 1417 MHz
           8: 2077 MHz
Graphics:  Card-1: Intel HD Graphics 530 bus-ID: 00:02.0 chip-ID: 8086:191b
           Card-2: NVIDIA GM107M [GeForce GTX 960M]
           bus-ID: 01:00.0 chip-ID: 10de:139b
           drivers: modesetting (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.00hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2)
           version: 4.5 Mesa 18.0.5 (compat-v: 3.0) Direct Render: Yes
Audio:     Card Intel Sunrise Point-H HD Audio
           driver: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:a170
           Sound: Advanced Linux Sound Architecture v: k4.15.0-29-generic
Network:   Card-1: Intel Wireless 7265
           driver: iwlwifi bus-ID: 02:00.0 chip-ID: 8086:095a
           Card-2: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: d000
           bus-ID: 03:00.1 chip-ID: 10ec:8168
           IF: enp3s0f1 state: down mac: <filter>
Drives:    HDD Total Size: 1128.2GB (8.8% used)
           ID-1: /dev/sda model: ST1000LM024_HN size: 1000.2GB
           serial: <filter>
           ID-2: /dev/sdb model: KINGSTON_RBU size: 128.0GB serial: <filter>
Partition: ID-1: / size: 117G used: 93G (84%) fs: ext4 dev: /dev/sdb2
           Unused Devices: none
Sensors:   System Temperatures: cpu: 60.0C mobo: N/A
           Fan Speeds (in rpm): cpu: 2000
Info:      Processes: 246 Uptime: 7 min Memory: 1548.8/15939.1MB
           Client: Shell (bash 4.4.191 running in gnome-terminal-) inxi: 2.3.56
Düzenleme: Konu başlığı
« Son Düzenleme: 26 Temmuz 2018, 00:29:20 Gönderen: Butterfly »
Ynt: Linux Mint 19 - ASUS N551VW - Yeniden Başlatma Sorunu
« Yanıtla #1 : 26 Temmuz 2018, 00:31:43 »
Aşağıdaki komutları uçbirimde çalıştırıp, açılışa acpi_rev_override=1 değişkeni ekleyerek, sistemi yeniden başlatmayı deneyiniz.
echo 'GRUB_CMDLINE_LINUX="$GRUB_CMDLINE_LINUX acpi_rev_override=1"' | sudo tee  /etc/default/grub.d/acpi-rev-override.cfg
sudo update-grub
Sorun bu şekilde çözülmezse aşağıdaki komutla değişkeni değiştirmeyi deneyebilirsiniz.
echo 'GRUB_CMDLINE_LINUX="$GRUB_CMDLINE_LINUX acpi_rev_override=5"' | sudo tee  /etc/default/grub.d/acpi-rev-override.cfg
sudo update-grub
