Gönderen Konu: [Çözüldü] Linux Mint 19 - Bumblebee Primusrun Komutu ile Steam Uygulaması Açılamama Sorunu  (Okunma sayısı 4889 defa)
Çevrimdışı orkuun
  • İleti: 17
  • Dağıtım: Linux Mint 19
  • Grafik Kartı: Amd RX 470 (MSI Gaming 4GB) - Nvidia 540M
  • İşlemci: Intel i5 6402p - Intel I7 2670QM
optirun -vvv glxgears çıktısı
[ 1950.014038] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 1950.014753] [DEBUG]optirun version 3.2.1 starting...
[ 1950.014793] [DEBUG]Active configuration:
[ 1950.014819] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 1950.014846] [DEBUG] X display: :8
[ 1950.014871] [DEBUG] LD_LIBRARY_PATH: /usr/lib/x86_64-linux-gnu:/usr/lib/i386-linux-gnu
[ 1950.014904] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 1950.014921] [DEBUG] Accel/display bridge: auto
[ 1950.014930] [DEBUG] VGL Compression: proxy
[ 1950.014935] [DEBUG] VGLrun extra options:
[ 1950.014941] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 1950.015027] [DEBUG]Using auto-detected bridge primus
[ 1951.080102] [INFO]Response: Yes. X is active.
[ 1951.080123] [INFO]Running application using primus.
[ 1951.080327] [DEBUG]Process glxgears started, PID 6369.
301 frames in 5.0 seconds = 60.158 FPS
301 frames in 5.0 seconds = 60.159 FPS
301 frames in 5.0 seconds = 60.162 FPS
301 frames in 5.0 seconds = 60.156 FPS
301 frames in 5.0 seconds = 60.160 FPS
primus: warning: dropping a frame to avoid deadlock
XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
      after 35 requests (35 known processed) with 0 events remaining.
primus: warning: timeout waiting for display worker
[ 1979.729187] [DEBUG]SIGCHILD received, but wait failed with No child processes
[ 1979.729252] [DEBUG]Socket closed.
[ 1979.729297] [DEBUG]Killing all remaining processes.
cat /etc/bumblebee/bumblebee.conf çıktısı:
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=
# Xorg binary to run
XorgBinary=/usr/lib/xorg/Xorg
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
[driver-nvidia]
KernelDriver=nvidia
PMMethod=auto
#LibraryPath=/usr/lib/nvidia-current:/usr/lib32/nvidia-current
LibraryPath=/usr/lib/x86_64-linux-gnu:/usr/lib/i386-linux-gnu
# default Xorg modules path
#XorgModulePath=/usr/lib/nvidia-current/xorg,/usr/lib/xorg/modules
XorgModulePath=/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules/input
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
cat /etc/bumblebee/xorg.conf.nvidia çıktısı:
Section "ServerLayout"
    Identifier  "Layout0"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
#   BusID "PCI:01:00:0"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
cat /etc/modprobe.d/bumblebee.conf çıktısı:
# This file is installed by bumblebee, do NOT edit!
# to be used by kmod / module-init-tools, and installed in /etc/modprobe.d/
# or equivalent
# do not automatically load nouveau as it may prevent nvidia from loading
blacklist nouveau
# do not automatically load nvidia as it's unloaded anyway when bumblebeed
# starts and may fail bumblebeed to disable the card in a race condition.
# Debian
blacklist nvidia
blacklist nvidia-current
blacklist nvidia-legacy-304xx
blacklist nvidia-legacy-340xx
# Ubuntu
blacklist nvidia
blacklist nvidia-current-updates
# 304
blacklist nvidia-304
blacklist nvidia-304-updates
blacklist nvidia-experimental-304
# 310
blacklist nvidia-310
blacklist nvidia-310-updates
blacklist nvidia-experimental-310
# 313
blacklist nvidia-313
blacklist nvidia-313-updates
blacklist nvidia-experimental-313
# 319
blacklist nvidia-319
blacklist nvidia-319-updates
blacklist nvidia-experimental-319
# 325
blacklist nvidia-325
blacklist nvidia-325-updates
blacklist nvidia-experimental-325
# 331
blacklist nvidia-331
blacklist nvidia-331-updates
blacklist nvidia-experimental-331
# 334
blacklist nvidia-334
blacklist nvidia-334-updates
blacklist nvidia-experimental-334
# 337
blacklist nvidia-337
blacklist nvidia-337-updates
blacklist nvidia-experimental-337
# 340
blacklist nvidia-340
blacklist nvidia-340-updates
blacklist nvidia-experimental-340
# 343
blacklist nvidia-343
blacklist nvidia-343-updates
blacklist nvidia-experimental-343
# 346
blacklist nvidia-346
blacklist nvidia-346-updates
blacklist nvidia-experimental-346
# 349
blacklist nvidia-349
blacklist nvidia-349-updates
blacklist nvidia-experimental-349
# 352
blacklist nvidia-352
blacklist nvidia-352-updates
blacklist nvidia-experimental-352
# 355
blacklist nvidia-355
blacklist nvidia-355-updates
blacklist nvidia-experimental-355
# 358
blacklist nvidia-358
blacklist nvidia-358-updates
blacklist nvidia-experimental-358
# 361
blacklist nvidia-361
blacklist nvidia-361-updates
blacklist nvidia-experimental-361
# 364
blacklist nvidia-364
blacklist nvidia-364-updates
blacklist nvidia-experimental-364
# 367
blacklist nvidia-367
blacklist nvidia-367-updates
blacklist nvidia-experimental-367
# 375
blacklist nvidia-375
blacklist nvidia-375-updates
blacklist nvidia-experimental-375
# 378
blacklist nvidia-378
blacklist nvidia-378-updates
blacklist nvidia-experimental-378
# 381
blacklist nvidia-381
blacklist nvidia-381-updates
blacklist nvidia-experimental-381
# 384
blacklist nvidia-384
blacklist nvidia-384-updates
blacklist nvidia-experimental-384
cat /etc/X11/xorg.conf çıktısı:
dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl' çıktısı:
ii  bumblebee                                  3.2.1-17                            amd64        NVIDIA Optimus support for Linux
ii  libnvidia-cfg1-390:amd64                   390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-390                       390.77-0ubuntu0~gpu18.04.1          all          Shared files used by the NVIDIA libraries
ii  libnvidia-compute-390:amd64                390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA libcompute package
ii  libnvidia-decode-390:amd64                 390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-390:amd64                 390.77-0ubuntu0~gpu18.04.1          amd64        NVENC Video Encoding runtime library
ii  libnvidia-fbc1-390:amd64                   390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-390:amd64                     390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ifr1-390:amd64                   390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  nvidia-390                                 390.77-0ubuntu0~gpu18.04.1          amd64        Transitional package for nvidia-driver-390
ii  nvidia-compute-utils-390                   390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA compute utilities
ii  nvidia-dkms-390                            390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA DKMS package
ii  nvidia-driver-390                          390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA driver metapackage
ii  nvidia-kernel-common-390                   390.77-0ubuntu0~gpu18.04.1          amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-390                   390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA kernel source package
ii  nvidia-prime-applet                        1.0.7                               all          An applet for NVIDIA Prime
ii  nvidia-utils-390                           390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA driver support binaries
ii  primus                                     0~20150328-6                        amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                          0~20150328-6                        amd64        Shared libraries for primus
ii  primus-libs:i386                           0~20150328-6                        i386         Shared libraries for primus
ii  primus-libs-ia32:i386                      0~20150328-6                        i386         Shared libraries for primus (32-bit)
ii  xserver-xorg-video-nvidia-390              390.77-0ubuntu0~gpu18.04.1          amd64        NVIDIA binary Xorg driver
lspci | egrep 'VGA|3D|Display' çıktısı:
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 540M] (rev ff)
cat /proc/cmdline çıktısı:
BOOT_IMAGE=/boot/vmlinuz-4.15.0-29-generic root=UUID=8c3f8d0a-f3cf-4d69-9908-d7a92b1939bd ro nogpumanager quiet splash vt.handoff=1
« Son Düzenleme: 02 Ağustos 2018, 22:33:22 Gönderen: orkuun »
[member=4893]orkuun[/member], lütfen sorunun ne olduğunu açık bir şekilde belirtir misiniz? Şu an paylaştığınız çıktılarda çok karışmış, ne olduğunu anlamak zor.
Çevrimdışı orkuun
  • İleti: 17
Pardon biraz forum acemiliği işte:) Neyse düzelttim çıktıları.
Hata ise optirun yazsamda yazmasamda glxgear 60 fps veriyor. Steamde de primusrun %command% ekleyince başlatma seçeneklerine uygulama hiç açılmıyor. Yardımınız için teşekkürler.
Sorun şu an sadece Steam ile ilgili sanırım, diğer çıktılarda bir sorun görünmüyor. Ayrıca primus köprüsü ile ilgili buradaki açıklamayı inceleyin.
Steam için şunu dener misiniz?
LD_PRELOAD="libpthread.so.0 libGL.so.1" __GL_THREADED_OPTIMIZATIONS=1 primusrun %command%
Çevrimdışı orkuun
  • İleti: 17
steam uygulaması başlangıç seçeneklerine bunu ekledim ama oyun yine açılmadı.
Aşağıdaki şekilde dener misiniz?
primusrun steam steam://rungameid/OYUN-IS-NO'SU
Eğer hata çıktısı alırsanız paylaşırsınız.
Bir de Steam uygulamasını nasıl kurdunuz? Depodan deb paketi olarak mı yoksa Flatpak olarak mı?
« Son Düzenleme: 01 Ağustos 2018, 12:45:50 Gönderen: Butterfly »
Çevrimdışı orkuun
  • İleti: 17
orkun@orkun-K53SV-mint ~ $ primusrun steam steam://rungameid/227300
/usr/bin/primusrun: satır 41: uyarı: komut değiştirme: girdi olarak yoksayılmış boş bayt
Running Steam on linuxmint 19 64-bit
Pins up-to-date!
[2018-08-01 13:13:48] Startup - updater built Jun  8 2018 22:22:23
Steam, mintin kendi deposundan kuruldu.
Linux Mint 19u daha dün v2 isodan sıfırdan kurdum.
Tüm güncellemeleri yaptım.  Oyun da ETS 2,
Bu şekilde Steam bile açılmadı.
primusrun için 32 bit uyumluluk paketlerini kurdunuz mu?
Çevrimdışı orkuun
  • İleti: 17
Evet  kurdum.
sudo apt install primus-libs-ia32 -y
Steam uygulamasını aşağıdaki komutla başlatmayı dener misiniz?
primusrun steam -steamos
Bir de aşağıdaki komutun çıktısına bakalım.
cat /etc/environment
Eğer olmazsa Prime'ı denemenizi tavsiye ederim. Bumblebee tek seçenek değil.
Çevrimdışı orkuun
  • İleti: 17
orkun@orkun-K53SV-mint ~ $ primusrun steam -steamos
Pins up-to-date!
[2018-08-01 14:14:49] Startup - updater built Jun  8 2018 22:22:23
orkun@orkun-K53SV-mint ~ $ cat /etc/environment
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
__GLVND_DISALLOW_PATCHING=1
Nvidia Prime iyi hoşta, oturum aç kapa uzun iş. Ayrıca bumblebee çok rahat ve hiç de yavaş gelmedi bana( Mint 18.3 kullanırken hepsini test etmiştim)
orkun@orkun-K53SV-mint ~ $ primusrun glxgears
primus: fatal: failed to load any of the libraries: /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1
/usr/lib/x86_64-linux-gnu/mesa/libGL.so.1: cannot open shared object file: No such file or directory
orkun@orkun-K53SV-mint ~ $ __GLVND_DISALLOW_PATCHING=1 primusrun glxgears
« Son Düzenleme: 01 Ağustos 2018, 14:27:14 Gönderen: orkuun »
Aşağıdaki şekilde primusrun yerine optirun kullanmayı dener misiniz? Sanırım primusrun ile ilgili bir sorun var.
optirun -b primus steam
Eğer bu şekilde çalışırsa Steam içinde kullanacağımız komutu aşağıdaki şekilde düzenleyin.
optirun -b primus %command%
Çevrimdışı orkuun
  • İleti: 17
Bu şekilde kesinlikle  çok fark etti. ETS2de 2-3 fps alırken şimdi 30-40 civarında fps alabiliyorum. Yalnız aklıma takılan bir şey var, bu komutları çalıştırdığımda  NVİDİA ekran kartımı kullandığını nasıl tam emin olabilirim. Yardımlarınız için çok teşekkürler.
Steam uygulamasını bu şekilde açtığınızda lsmod komutunun çıktıları arasında nvidia ile ilgili sürücü modüllerini görebilmeniz gerekir.
Ayrıca Bumblebee kurulum konusunda bahsedilen Bumblebee-ui uygulamacığı da GPU kullanım bildirimi yapabiliyor. Bunu Cinnamon, MATE ve Xfce masaüstü ortamlarında kullanabilirsiniz.
Cinnamon masaüstünü kullanıyorsanız buradaki uygulamacık işe yarayabilir.
MATE masaüstünü kullanıyorsanız, mate-optimus paketi ile kurulan uygulamacığı panele eklemek denenebilir.
Bu konu ile ilgili sorun çözüme ulaştıysa, başlığı etiketlerseniz konuyu kilityebiliriz.
[warning] Çözülen başlıkların etiketlenmesi hakkında.[/warning]
