Gönderen Konu: [Çözüldü] Google Earth - Üstte Küçük Alan İçinde Arama Yapması  (Okunma sayısı 3350 defa)
Çevrimdışı ihsaniye
  • İleti: 108
  • Dağıtım: linux Mint 19
Google Earth de arama yaptığım yer sayfanın sağ üst köşesinde küçük bir ekranda gösteriliyor, sanki program kısıtlanmış gibi. Yardımcı olabilirmisiniz?.
yusuf[member=2001]yusuf[/member]-R530-R730-P590:~$ lspci | egrep 'VGA|3D|Display'02:00.0 VGA compatible controller: NVIDIA Corporation GT218M [GeForce 310M] (rev a2)
yusuf[member=2001]yusuf[/member]-R530-R730-P590:~$ glxinfo | grep render
OpenGL renderer string: NVA8
yusuf[member=2001]yusuf[/member]-R530-R730-P590:~$ inxi -Fx
System:    Host: yusuf-R530-R730-P590 Kernel: 4.15.0-32-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1)
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: SAMSUNG product: R530/R730/P590 serial: N/A
           Mobo: SAMSUNG model: R530/R730/P590 serial: N/A
           BIOS: Phoenix v: 01KQ.M001.20100323.hkk date: 03/23/2010
Battery    BAT1: charge: 21.2 Wh 98.0% condition: 21.6/47.5 Wh (45%)
           model: SAMSUNG status: N/A
CPU:       Dual core Intel Core i3 M 330 (-MT-MCP-)
           arch: Nehalem rev.2 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 8511
           clock speeds: max: 2133 MHz 1: 1064 MHz 2: 1393 MHz 3: 1250 MHz
           4: 1254 MHz
Graphics:  Card: NVIDIA GT218M [GeForce 310M] bus-ID: 02:00.0
           drivers: nouveau (unloaded: modesetting,fbdev,vesa)
           Resolution: 1366x768@60.00hz, 1920x1080@59.93hz
           OpenGL: renderer: NVA8 version: 3.3 Mesa 18.0.5 Direct Render: Yes
Audio:     Card-1 NVIDIA High Def. Audio Controller
           driver: snd_hda_intel bus-ID: 02:00.1
           Card-2 Intel 5 Series/3400 Series High Def. Audio
           Sound: Advanced Linux Sound Architecture v: k4.15.0-32-generic
           driver: ath9k bus-ID: 03:00.0
           IF: wlp3s0 state: down mac: f0:7b:cb:81:23:98
           Card-2: Marvell Yukon Optima 88E8059 [PCIe Gigabit Ethernet Controller with AVB]
           driver: sky2 v: 1.30 port: 5000 bus-ID: 07:00.0
           IF: enp7s0 state: up speed: 100 Mbps duplex: full
           mac: 00:24:54:84:ba:e4
Drives:    HDD Total Size: 250.1GB (10.6% used)
           ID-1: /dev/sda model: SAMSUNG_HM250HI size: 250.1GB
Partition: ID-1: / size: 33G used: 21G (68%) fs: ext4 dev: /dev/sda3
           ID-2: swap-1 size: 4.29GB used: 0.00GB (0%)
           fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 63.0C mobo: 63.0C gpu: 61.0
Info:      Processes: 182 Uptime: 44 min Memory: 1609.8/2926.4MB
           Init: systemd runlevel: 5 Gcc sys: 7.3.0
           Client: Shell (bash 4.4.191) inxi: 2.3.56
yusuf[member=2001]yusuf[/member]-R530-R730-P590:~$ dpkg -l | grep earth
ii  google-earth-pro-stable                    7.3.2.5493-r0                       amd64        Explore, search and discover the planet
yusuf[member=2001]yusuf[/member]-R530-R730-P590:~$ uname -rm
yeniden kurmayı denedim:
yusuf[member=2001]yusuf[/member]-R530-R730-P590:~$ sudo apt-get install google-earth-stable
[sudo] password for yusuf:
E: google-earth-stable paketi bulunamadı
yusuf[member=2001]yusuf[/member]-R530-R730-P590:~$ sudo apt-get install -f
  linux-headers-4.15.0-29 linux-headers-4.15.0-29-generic
  linux-image-4.15.0-29-generic linux-modules-4.15.0-29-generic
  linux-modules-extra-4.15.0-29-generic
Düzenleme: Kod etiketi, konu başlığı ve konu taşıma
« Son Düzenleme: 23 Ağustos 2018, 23:14:45 Gönderen: Butterfly »
Çevrimdışı minteger
  • İleti: 381
Ynt: Google Earth - Sağ Üstte Küçük Alan İçinde Arama Yapması
« Yanıtla #1 : 20 Ağustos 2018, 21:46:18 »
Yukarıda diyor ki :
google-earth-stable paketi bulunamadı.
Hmmm.
Sanırım
sudo apt-get purge google-earth-stable
Komutunu kullanmayı denemişsin ancak doğrusu: (Eğer pro paketi kullanıyorsan)
sudo apt-get purge google-earth-pro-stable
sudo apt-get autoremove
Şeklinde olmalıydı. Buradaki gibi uyguladıysan;
Bu şekilde kalmasın orada olduğu gibi biz aoutoremove komutunu kullanlalım öncelikle. Yoksa yukarıdaki komutu uygulayabilirsin.
Şimdi bu komutla paketin tam ismini öğrenip paketi kaldırmayı deneyelim.
dpkg --list 'google-earth*' | cat
paket ismi xyz olsun.
sudo dpkg -P xyz
xyz yerine ilk çıktıdan elde ettiğimiz paket ismini yazacığız.
Arkasından googledan yeni dosyayı edinip indirelim ve paketi kur diyerek yeniden kuralım.
Dipnot düşelim:
Yalnız çalışmak için 'lbs-core' gibi güncel pakete ihtiyac  duyuyor. Kurulum eksiksiz yaptığına eminmisin ?
Normal koşulda sisteminizde bulunması gerek...
dpkg -l |grep lsb-core
Sisteminizde bulunan lbs-core hakkında bilgi vermesi gerek.
[member=35]ihsaniye[/member] Bende iki tane çıktı aldım google eart olarak.  İkisinide kaldırmak gerek.
rc  google-earth-pro-stable                                     7.3.2.5491-r0                                     amd64        Explore, search and discover the planet
ii  google-earth-stable                                         7.1.8.3036-r0                                     i386         Explore, search and discover the planet
sudo dpkg -P google-earth-pro-stable
şifremizi giriyoruz. Abe yes..
sudo dpkg -P google-earth-stable
yine şifremizi girip abe yes..
Yukarıda söylediğim gibi kurulumu yapıyoruz. Paketi kur demeden kenarda ' Durum :  Tüm bağımlılıklar sağlanmış ' bilgisini gördüğümüzde sağlam bir kurulmu gerçekleştirebiliriz diye düşünüyorum.--
Eğer yeniden kurulumdan istediğimiz sonucu alamazsak. Yukarıdaki paket kaldırma işlemlerini uygulayıp arkasından terminalden :
sudo apt-get install google-earth-stablekomutu ile kurulum yapalım. proya göre daha stabil çalışacaktır.
« Son Düzenleme: 20 Ağustos 2018, 22:44:47 Gönderen: minteger »
Çevrimdışı ihsaniye
  • İleti: 108
« Yanıtla #2 : 23 Ağustos 2018, 08:30:19 »
Çok teşekkür ederim, sanırım beceremedim. Denemeye devam ediyorum.
« Yanıtla #3 : 23 Ağustos 2018, 13:01:11 »
Burada bahsedilen sorun sanırım, Nouveau sürücüsü ile uyumsuzluk sorunu varmış. Aşağıdaki komutlarla Nvidia-340 sürücüsünü yükleyip sistemi yeniden başlatmayı deneyiniz.
sudo apt update
sudo apt install nvidia-340 nvidia-settings
Çevrimdışı ihsaniye
  • İleti: 108
Hocam, teşekkürler, sorun çözüldü, Google Earth ' e tam ekran bakabiliyorum.
Ynt: Google Earth - Üstte Küçük Alan İçinde Arama Yapması
« Yanıtla #5 : 23 Ağustos 2018, 23:13:06 »
Rica ederiz.
Çözüme ulaşan sorunlar için konu başlığını etiketlemek gerekiyor, bu seferlik etiketi ben ekliyorum, bilgi için aşağıdaki konumuzu inceleyebilirsiniz.
[info]Çözülen başlıkların etiketlenmesi hakkında.[/info]
