Gönderen Konu: [Çözüldü] Linux Mint 19 - Lenovo z570 Ekran Parlaklığı Değiştiremiyorum  (Okunma sayısı 11254 defa)
Çevrimdışı nongliadin
  • İleti: 48
  • İşlemci: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
Daha önce kapanma ve açılmada donma sorunu yaşıyordum şimdi ise ekran parklaklığını değiştiremiyorum.Bilgisayarım Lenovo z570. Şimdiden teşekkürler.
"inxi -Fxxz" in çıktısı:
System:    Host: Buhari Kernel: 4.15.0-20-generic x86_64 bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1) dm: lightdm
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: LENOVO product: HuronRiver Platform v: Ideapad Z570 serial: N/A
           Mobo: LENOVO model: Emerald Lake v: FAB1 serial: N/A
           UEFI [Legacy]: LENOVO v: 45CN38WW date: 10/21/2011
           Chassis: type: 10 v: 0.1 serial: N/A
CPU:       Dual core Intel Core i5-2410M (-MT-MCP-)
           arch: Sandy Bridge rev.7 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9179
           clock speeds: min/max: 800/2900 MHz 1: 803 MHz 2: 802 MHz
           3: 814 MHz 4: 801 MHz
Graphics:  Card-1: Intel 2nd Generation Core Integrated Graphics Controller
           bus-ID: 00:02.0 chip-ID: 8086:0116
           Card-2: NVIDIA GF119M [GeForce GT 520M]
           bus-ID: 01:00.0 chip-ID: 10de:1050
           drivers: modesetting,nvidia (unloaded: fbdev,vesa,nouveau)
           Resolution: 1366x768@60.00hz
           OpenGL: renderer: GeForce GT 520M/PCIe/SSE2
           version: 4.6.0 NVIDIA 390.48 Direct Render: Yes
Audio:     Card Intel 6 Series/C200 Series Family High Def. Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:1c20
           Sound: Advanced Linux Sound Architecture v: k4.15.0-20-generic
Network:   Card-1: Intel Centrino Wireless-N 1000 [Condor Peak]
           driver: iwlwifi bus-ID: 03:00.0 chip-ID: 8086:0084
           Card-2: Realtek RTL8101/2/6E PCIE Fast/Gigabit Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: 2000
           bus-ID: 04:00.0 chip-ID: 10ec:8136
Drives:    HDD Total Size: 500.1GB (3.3% used)
           ID-1: /dev/sda model: WDC_WD5000BPVT size: 500.1GB
           serial: <filter>
Partition: ID-1: / size: 89G used: 6.2G (8%) fs: ext4 dev: /dev/sda6
           ID-2: swap-1 size: 10.24GB used: 0.00GB (0%)
           fs: swap dev: /dev/sda5
           Unused Devices: none
Sensors:   System Temperatures: cpu: 61.0C mobo: 47.0C gpu: 0.0:56C
Info:      Processes: 208 Uptime: 13 min Memory: 1567.6/3858.4MB
           Client: Shell (bash 4.4.191 running in gnome-terminal-) inxi: 2.3.56
"inxi -SMGxx" ın çıktısı:
"glxinfo | grep render" ın çıktısı:
OpenGL renderer string: GeForce GT 520M/PCIe/SSE2
    GL_KHR_robustness, GL_KTX_buffer_region, GL_NVX_conditional_render,
    GL_EXT_multisampled_render_to_texture,
    GL_EXT_multisampled_render_to_texture2, GL_EXT_occlusion_query_boolean,
    GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB,
    GL_NV_blend_equation_advanced, GL_NV_conditional_render,
"lspci | egrep 'VGA|3D|Display' " ın çıktısı:
01:00.0 VGA compatible controller: NVIDIA Corporation GF119M [GeForce GT 520M] (rev a1)
"xrandr" ın çıktısı:
LVDS-1-1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
   1366x768      60.00*+
   1360x768      59.80    59.96
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       59.93    60.00
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
VGA-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
"cat /etc/X11/xorg.conf" ın çıktısı:
"dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl|fglrx' " ın çıktısı:
ii  libnvidia-cfg1-390:amd64                   390.48-0ubuntu3                     amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-390                       390.48-0ubuntu3                     all          Shared files used by the NVIDIA libraries
ii  libnvidia-compute-390:amd64                390.48-0ubuntu3                     amd64        NVIDIA libcompute package
ii  libnvidia-compute-390:i386                 390.48-0ubuntu3                     i386         NVIDIA libcompute package
ii  libnvidia-decode-390:amd64                 390.48-0ubuntu3                     amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-decode-390:i386                  390.48-0ubuntu3                     i386         NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-390:amd64                 390.48-0ubuntu3                     amd64        NVENC Video Encoding runtime library
ii  libnvidia-encode-390:i386                  390.48-0ubuntu3                     i386         NVENC Video Encoding runtime library
ii  libnvidia-fbc1-390:amd64                   390.48-0ubuntu3                     amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-fbc1-390:i386                    390.48-0ubuntu3                     i386         NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-390:amd64                     390.48-0ubuntu3                     amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-gl-390:i386                      390.48-0ubuntu3                     i386         NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ifr1-390:amd64                   390.48-0ubuntu3                     amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  libnvidia-ifr1-390:i386                    390.48-0ubuntu3                     i386         NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  nvidia-compute-utils-390                   390.48-0ubuntu3                     amd64        NVIDIA compute utilities
ii  nvidia-dkms-390                            390.48-0ubuntu3                     amd64        NVIDIA DKMS package
ii  nvidia-driver-390                          390.48-0ubuntu3                     amd64        NVIDIA driver metapackage
ii  nvidia-kernel-common-390                   390.48-0ubuntu3                     amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-390                   390.48-0ubuntu3                     amd64        NVIDIA kernel source package
ii  nvidia-prime                               0.8.8                               all          Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                        1.0.7                               all          An applet for NVIDIA Prime
ii  nvidia-settings                            390.42-0ubuntu1                     amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-utils-390                           390.48-0ubuntu3                     amd64        NVIDIA driver support binaries
ii  xserver-xorg-video-nvidia-390              390.48-0ubuntu3                     amd64        NVIDIA binary Xorg driver
« Son Düzenleme: 22 Eylül 2018, 19:56:21 Gönderen: nongliadin »
Aşağıdaki komutları sırasıyla uçbirimde çalıştırıp sistemi yeniden başlatmayı deneyiniz.
echo 'GRUB_CMDLINE_LINUX="$GRUB_CMDLINE_LINUX acpi_osi=! acpi_osi=\"Windows 2012\""' | sudo tee  /etc/default/grub.d/nvidia-acpi.cfg
sudo update-grub
  • İleti: 48
Hiç bir fark olmadı.  :(
cat /proc/cmdline
  • İleti: 48
cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-4.15.0-34-generic root=UUID=3074b5dc-d5cd-4e2f-9050-ae8f8219f7ed ro acpi_osi=! "acpi_osi=Windows 2012" quiet splash vt.handoff=1
echo 'GRUB_CMDLINE_LINUX="$GRUB_CMDLINE_LINUX acpi_osi="!Windows 2012""' | sudo tee  /etc/default/grub.d/nvidia-acpi.cfg
sudo update-grub
  • İleti: 48
sudo update-grub
Sırası ile çıktıları :
/usr/sbin/grub-mkconfig: 1: /etc/default/grub.d/nvidia-acpi.cfg: 2012: not found
Ayrıca önemli mi bilmiyorum ama şu anda dual boot kullanıyorum win 8.1 yüklü.
« Son Düzenleme: 22 Eylül 2018, 13:41:29 Gönderen: nongliadin »
Aşağıdaki komutlarla yeniden dener misiniz?
echo 'GRUB_CMDLINE_LINUX="$GRUB_CMDLINE_LINUX acpi_osi=\"!Windows 2012\""' | sudo tee  /etc/default/grub.d/nvidia-acpi.cfg
sudo update-grub
Windows yanına kurulumla doğrudan ilgisi olacağını sanmıyorum.
  • İleti: 48
sudo update-grub
Yine işe yaramadı. Çıktılar:
Grub yapılandırma dosyası oluşturuluyor ...
Bulunan linux kalıbı: /boot/vmlinuz-4.15.0-34-generic
Bulunan initrd kalıbı: /boot/initrd.img-4.15.0-34-generic
Bulunan linux kalıbı: /boot/vmlinuz-4.15.0-20-generic
Bulunan initrd kalıbı: /boot/initrd.img-4.15.0-20-generic
Bulunan Windows 8, /dev/sda1 üzerinde
bitti
Birde deepin desktop enviroment ı kurduğumda ekran parlaklığını fonksiyon tuşları ile değiştiremiyor fakat ayarlardan değiştirebiliyorum.
Yukarıdaki komutlardan sonra, açılış değişkenini etkin olması için sistemi yeniden başlattınız mı?
Deepin masaüstünü Linux Mint'e mi kurdunuz, yoksa ayrıca dağıtım olarak kurdunuz?
  • İleti: 48
Ynt: Linux Mint 19 - Lenovo z570 Ekran Parlaklığı Değiştiremiyorum
« Yanıtla #10 : 22 Eylül 2018, 16:30:55 »
Evet sistemimi yeniden başlattım. Deepini de mint e kurdum.
« Yanıtla #11 : 22 Eylül 2018, 16:38:56 »
Aşağıdaki komutla değişkeni acpi_osi= olarak ayarlamayı deneyebilirsiniz. Sisteme özel bir ayar var mı bir bakınalım.
echo 'GRUB_CMDLINE_LINUX="$GRUB_CMDLINE_LINUX acpi_osi="' | sudo tee  /etc/default/grub.d/nvidia-acpi.cfg
sudo update-grub
Sistemi yeniden başlattığınızda sorun çözülmediyse, aşağıdaki komutla Intel GPU'ya geçiş yapıp sistemi yeniden başlatmayı deneyebilirsiniz.
sudo prime-select intel
Ayrıca aşağıdaki komutun çıktısına da bakalım.
ls /sys/class/backlight/
  • İleti: 48
« Yanıtla #12 : 22 Eylül 2018, 17:30:20 »
sudo update-grub
Yine bir işe yaramadı.Çıktı ise:
acpi_backlight=vendorYine işe yaramayınca başka bir şey daha denedim. "sudo gedit /etc/default/grub" dosyasında GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"  değişikliğini yaptım şu anda ekran parlaklığını deepindeki gibi değiştirebiliyorum fakat fn tuşları işlevsiz :( An itibari ile bu da işlevini yitirdi yine parlaklığa hiç bir etki edemiyorum:(.
« Son Düzenleme: 22 Eylül 2018, 17:41:17 Gönderen: nongliadin »
« Yanıtla #13 : 22 Eylül 2018, 18:42:08 »
Aşağıdaki komutlarla Grub yapılandırma dosyasını silip,
sudo rm -f /etc/default/grub.d/nvidia-acpi.cfg
sudo update-grub
sistemi yeniden başlatınız. Ardından aşağıdaki komutn çıktısını yeniden paylaşınız.
  • İleti: 48
« Yanıtla #14 : 22 Eylül 2018, 18:57:22 »
Hata devam ediyor.
acpi_video0  intel_backlight
