Gönderen Konu: Intel + AMD/ATI Hibrit GPU - Radeon Sürücüsü Performans Ayarları  (Okunma sayısı 15996 defa)
Çevrimdışı TolgaHan
  • İleti: 39
  • Dağıtım: Linux Mint 19
[member=8]Butterfly[/member] Hocamın sayesinde bilgisayarım Amdgpu desteklenmediğini öğrendim. Android studio kullanıyorum ve yüksek performans da kullanmak istiyorum. Amdgpu desteklemeyen bir bilgisayarı linux'un eski sürümlerine mi geçmemi önerirsiniz yada windows'a geçmem mi gerekir.
tolga[member=5676]Tolga[/member]:~$ inxi -Fxxz
System:    Host: tolga Kernel: 4.15.0-34-generic x86_64 bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.9 (Gtk 3.22.30-1ubuntu1) dm: lightdm
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: SAMSUNG product: 350V5C/351V5C/3540VC/3440VC v: P09ABE.012.CP serial: N/A
           Mobo: SAMSUNG model: NP350V5C-S0KTR v: BOARD 00 serial: N/A
           UEFI: American Megatrends v: P09ABE date: 07/04/2013
           Chassis: type: 9 v: 0.1 serial: N/A
Battery    BAT1: charge: 45.8 Wh 100.0% condition: 45.8/48.8 Wh (94%)
           volts: 12.5/11.1
           model: COMPAL PABAS0241231 serial: <filter>status: Full
CPU:       Dual core Intel Core i5-3230M (-MT-MCP-)
           arch: Ivy Bridge rev.9 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10375
           clock speeds: min/max: 1200/3200 MHz 1: 1197 MHz 2: 1204 MHz
           3: 1200 MHz 4: 1199 MHz
           Card-2: Advanced Micro Devices [AMD/ATI] Thames [Radeon HD 7500M/7600M Series]
           bus-ID: 01:00.0 chip-ID: 1002:6840
           drivers: modesetting,ati,radeon (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.07hz
           OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile
           version: 4.2 Mesa 18.1.7 - padoka PPA (compat-v: 3.0) Direct Render: Yes
Audio:     Card Intel 7 Series/C216 Family High Def. Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:1e20
           Sound: Advanced Linux Sound Architecture v: k4.15.0-34-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: 2000
           bus-ID: 02:00.0 chip-ID: 10ec:8168
           Card-2: Qualcomm Atheros AR9485 Wireless Network Adapter
           driver: ath9k bus-ID: 03:00.0 chip-ID: 168c:0032
Drives:    HDD Total Size: 750.2GB (1.4% used)
           ID-1: /dev/sda model: Hitachi_HTS72757 size: 750.2GB
           serial: <filter>
Partition: ID-1: / size: 687G used: 9.6G (2%) fs: ext4 dev: /dev/sda2
           Unused Devices: none
Sensors:   System Temperatures: cpu: 51.0C mobo: N/A gpu: N/A
Info:      Processes: 208 Uptime: 1:53 Memory: 1647.5/7868.8MB
           Client: Shell (bash 4.4.191 running in gnome-terminal-) inxi: 2.3.56
tolga[member=5676]Tolga[/member]:~$ DRI_PRIME=1 glxinfo | grep "OpenGL renderer"
OpenGL renderer string: AMD TURKS (DRM 2.50.0 / 4.15.0-34-generic, LLVM 6.0.0)
Düzenleme: Konu başlığı
« Son Düzenleme: 26 Eylül 2018, 17:33:00 Gönderen: Butterfly »
Çıktılara göre zaten Mesa kütüphanesinin güncel sürümünü PPA deposundan kurduğunuz görünüyor. Ayrıca buradaki öneriyi uygulayabilirsiniz.
Harici GPU ile başlatmak istediğiniz uygulamayı aşağıdaki kalıba göre başlatmalısınız.
DRI_PRIME=1 uygulama-adı
Çevrimdışı TolgaHan
  • İleti: 39
Firefox'u
DRI_PRIME=1 uygulama-adıBu kodla başlattığım halde hafif kasmalar var akıcı değil
Bu arada bu kodu denedim fark görmedim
Identifier  "Radeon"
Driver "radeon"
Option "AccelMethod" "glamor"
        Option "DRI" "3"
        Option "TearFree" "on"
        Option "ColorTiling" "on"
        Option "ColorTiling2D" "on"
Düzenleme sonrası sisteminizi yeniden başlatmanız gerekiyor.
Çevrimdışı TolgaHan
  • İleti: 39
Yeniden başlattığım halde aynı sorun var
Önceki mesajınızdaki alıntılar komut değil bu arada, bunları yapılandırma dosyasına eklediniz değil mi?
Firefox için buradaki öneri, Cinnamon için buradaki öneri denenebilir.
Ayrıca aşağıdaki komutla, Intel GPU için klasik Intel sürücüsü ile UXA hızlandırmayı etkinleştirmek denenebilir. Sonrasında sistemi yeniden başlatmalısınız.
Not: Firefox tarayıcı için ATI GPU kullanmaya gerek yok aslında, Intel GPU bu tür uygulamaları çalıştırmak için oldukça yeterli.
« Son Düzenleme: 26 Eylül 2018, 21:20:08 Gönderen: Butterfly »
Çevrimdışı TolgaHan
  • İleti: 39
Aynen yapılandırma dosyasına ekledim zaten. Firefox ve Cinnamon önerilerinizide uyguladım işe yaramadı. Ekranda yırtılmalar sinir bozucu bir şekilde
 var ve Mint menüsünün arayüzünde kasmalar var
Bunu da uygulayıp sistemi yeniden başlattım değişen birşey olmadı hocam
NOT: Önerdiğiniz ayarları yaptım fakat işe yaramadı tekrar eski haline getirmeme gerek var mı ilerde bi sıkıntı çıkarır mı.
« Son Düzenleme: 27 Eylül 2018, 19:01:31 Gönderen: TolgaHan »
Güncelleme yaptığınız Padoka PPA deposundaki paketlerde sorun olabilir. Aşağıdaki komutlarla bu PPA depsosundan yaptığınız güncellemeyi geri alıp sistemi yeniden başlatmayı dener misiniz?
sudo apt-get install ppa-purge
sudo ppa-purge -d bionic ppa:paulo-miguel-dias/mesa
Diğer düzenlemelere şu an dokunmaya gerek yok.
Çevrimdışı TolgaHan
  • İleti: 39
Hocam kodları sırasıyla uyguladım halen aynı
Sizi isterseniz MATE masaüstüne yönlendirelim, masaüstü ortamı farketmeyecekse belki yırtılma/dalgalanma bu şekilde çözebilirsiniz. Yeniden kurulum yapmanız gerekmeyecek.
Çevrimdışı TolgaHan
  • İleti: 39
MATE masaüstüne yeniden kurulum yapmadan nasıl geçicez hocam ?
Burada paylaştığınız çıktı hala PPA deposundan kurulmuş kütüphanelerin etkin olduğunu gösteriyor. Sistemi yeniden başlattınız mı?
Aşağıdaki komutla gerekli paketleri kurup,
sudo apt-get install mint-meta-mate caja-extensions-common caja-open-terminal caja-sendto caja-wallpaper caja-admin
ardından oturumu kapatın ve giriş ekranından MATE masaüstünü seçip oturum açmayı deneyiniz.
Ayrıca burada anlatıldığı biçimde Compton'u etkinleştirin.
« Son Düzenleme: 28 Eylül 2018, 00:21:31 Gönderen: Butterfly »
Çevrimdışı TolgaHan
  • İleti: 39
Evet hocam başlatmıştım. Şimdi tekrar yaptım çıktısı:
tolga[member=5676]Tolga[/member]:~$ sudo apt-get install ppa-purge
[sudo] password for tolga:
ppa-purge zaten en yeni sürümde (0.2.8+bzr63).
0 paket yükseltilecek, 0 yeni paket kurulacak, 0 paket kaldırılacak ve 28 paket yükseltilmeyecek.
tolga[member=5676]Tolga[/member]:~$ sudo ppa-purge -d bionic ppa:paulo-miguel-dias/mesa
Updating packages lists
PPA to be removed: paulo-miguel-dias mesa
Warning:  Could not find package list for PPA: paulo-miguel-dias mesa
Yazılım Kaynakları => Bakım => Dış paketlerin sürümünü düşür seçeneğinden tüm paketleri seçip, resmi depodaki paketlere dönmeyi deneyebilirsiniz.
MATE masaüstündeki durum ile ilgili dönüş yaparsınız.
Çevrimdışı TolgaHan
  • İleti: 39
Hocam bu şekilde de denedim olmadı PPA depsosunu nasıl eski haline getire bilirim bu yaptıklarımız olmadığından dolayı
Hocam Mate geçtim Openbox ve Compton kurulumlarını yaptım, pencere yöneticisinin bütün seçeneklerini denedim halen Cinnamon gibi yırtılmalar oluyor ekranda  :'(
« Son Düzenleme: 28 Eylül 2018, 01:57:49 Gönderen: TolgaHan »
